rough country bar pin eliminator rough ride after?
#1 | |
i installed the rear bar pin eliminators and after i did that my suspension totaly sucks when my rear his a bump it literarly is like spine crushing. when i go under the truck all is well but i can find that between the rc 2.2 shocks and there rubber bump stops i only have about a inch and a half this is because the bar pin elimnator moved the top mount down closer to the bottom thus shortening and screwing up the shocks. any solutions because ive snapped bar pins before and i dont wana have to deal with it.
#2 |
TITS
Sounds like the decreased travel of the shocks have really messed the shock's ability to absorb loads. I would love to do BPE's but the RC shocks just don't have enough piston showing to make me comfortable doing it. With that said, I have had zero problems with the bar pins.
#3 |
add about 3 more inches of lift and you will be good...
#4 |
anyone have a decent solution to this? or ne one have the same issue
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
