Rough Country 2.5" spring & 3/4" spacers extended sway bar links? - JeepForum.com
post #1 of 25 Old 11-03-2009, 06:02 PM Thread Starter
drewtj05
Right now I have rough countrys 2.5" springs on my 05 TJ, but I am wanting to go a little higher to run 33s. I was wondering if I get the 3/4" spacers would I have to run extended sway bar links or could i get away with running the stock ones. Also, I was considering only putting the spacers up front to level it out because I am pretty sure that 33s would fit in the rear without the spacers, but i figured i found the 3/4" spacers for $35 on 4wd.com for all 4 spacers instead of just the fronts. should i run all spacers or just fronts? Anyone know about this setup or running similar setup?
drewtj05 is offline
post #2 of 25 Old 11-03-2009, 06:24 PM
emev0l
Will you be running a hard top or soft top?
Will you be carrying a full sized 33" spare on the tailgate?
Do you have a back seat or carry a lot of heavy stuff in back?
I run all of the above so I have the 2.5" lift with the .75" spacers on the front and back.
If your not going to be real heavy out back the .75 just up front will work great and get you enough lift to run 33's.
If you plan to off road this jeep I would suggest getting longer sway bar end links up front, sway bar disconnects will let you flex 30% more up front.
JKS makes really nice sway bar discos for the front but they are a little expensive $140.
There are also some write ups on the forum that show you how to make your own disconnects, if you do a search you should come up with quite a bit.
$35 for a pair of .75" spring spacers is a good price, just make sure to calculate shipping, you can also try ebay, fatbobsgarage, or even a google search.
2001 TJ 4.6 Auto 4.5" AEV suspension 35's
2002 TJ 4.0 Manual 3" BDS suspension 33's
1987 Chevy 1 Ton 12" suspension 44's
1970 Cutlass 442 468CID TH400
1999 7.3 Powerstroke
emev0l is offline
post #3 of 25 Old 11-03-2009, 06:27 PM
SKIBUMM
You could also do a simple 1 inch BL which would than allow you to do a tummy tuck. Just food for thought to give you more ideas to run through.
SKIBUMM is offline
post #4 of 25 Old 11-03-2009, 06:33 PM
mcg311TJ
They are very nice, I love mine.
mcg311TJ is offline
post #5 of 25 Old 11-03-2009, 06:33 PM
Weeeee
I have the RC 2.5 and not long after installing one of the sway bar links failed so I got the JKS quicker discos and love them. I also added the .75" spacers up front to account for a winch that I added.
Weeeee is offline
post #6 of 25 Old 11-03-2009, 06:43 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
front extended sway bars are a must, even with 2.5" lift. Rears are suggested at 2.5" of lift, but it won't kill you to use the stock ones.
I have 2.5" OME springs and 0.75" spacers in front only. I have JKS discos in front and have yet to install a set of RE rear links (9.5" eye to eye).
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #7 of 25 Old 11-03-2009, 06:45 PM Thread Starter
drewtj05
I still in the process of getting all the stuff I am planning on running, but some of the things I will have is the 33" spare cooper discoverer stt on a rock crawler bumper with tire carrier. I have my rear seat in the back, and have a soft top. Up front planning on getting either a fabtech or smittybilt bumper and a smittybilt xrc8 winch. Also wanting to carry a jerry can on the bumper so that would be maybe a little extra weight.
As of right now though i have stock bumpers, no winch, and soft top. Just concerned about if i put those extra spacer would i need the longer swar bar links and if i would need to get the rear trac bar relocation bracket. I realize now that i should have just orginally bought the 3.25" rc instead of just the 2.5"
drewtj05 is offline
post #8 of 25 Old 11-03-2009, 06:47 PM Thread Starter
drewtj05
Right now i would actually prefer getting a bit more suspension lift rather than just a BL. if the cost for a more sus*****on lift to 3.25 from 2.5 is going to be that much more expensive i may just go with the bl
drewtj05 is offline
post #9 of 25 Old 11-03-2009, 06:51 PM Thread Starter
drewtj05
so running a 3.25 with stock swar bar links would be no very smart in other words? and in the rear if i run 3.25 are they critical to have? right now if i can get away using stock links i would probably not be doing too much wheeling until i have all the right equipment because i dont want to screw up my jeep.
drewtj05 is offline
post #10 of 25 Old 11-03-2009, 06:53 PM Thread Starter
drewtj05
how does it sit with the winch? does it sit nice and level or is there some rake?
i am concerned about this if i put spacers in both front and back i am not sure if adding a winch will cause me to have to put a larger spacer up front to level it out with the rear.
drewtj05 is offline
post #11 of 25 Old 11-03-2009, 06:54 PM
Boodyrider
A spacer is NOT a suspension lift, no matter what the idiots selling them say. No more travel, it is NOT a suspension lift.
97 TJ Sport - 4.0/HP D30 w ARB/8.8 w LS/4.88s; 35s and flat fenders on 2.5 lift
84 CJ7; frame off restoration in progress.
The technical advice you get from me here is worth exactly what you paid me for it. Warranty issues will be reimbursed at double what you paid me for the advice.
Boodyrider is offline
post #12 of 25 Old 11-03-2009, 06:57 PM Thread Starter
drewtj05
so if there was a kit that came with 2.5" spacers, extended length shocks, t case drop, and trac bar bracket it would NOT be considered a lift kit because they are spacers rather than springs?
drewtj05 is offline
post #13 of 25 Old 11-03-2009, 06:59 PM
Weeeee
Who said it was?!?!?
Weeeee is offline
post #14 of 25 Old 11-03-2009, 07:01 PM
Unlimited04
did you even read what I posted?
Read again:
Read again:
why not do it all at once and do it right? Or you can risk inverting your front sway bar and breaking stuff. Your choice.
Useful Write-Ups:
Funny:
post #15 of 25 Old 11-03-2009, 07:02 PM
Weeeee
It sits fairly level, if I had the m in the rear it wouldn't be. If you don't have a winch it should be ok, but every jeep is a little different.
Weeeee is offline
Buying a 2.5" Rough Country spring lift... do i need anything esle ?? 09WRANGLER JK Wrangler Technical Forum 15 08-13-2009 06:11 AM
Rough country 2.5" coil spring kit: what else did you need? shiftless06 Wrangler General Discussion 10 06-20-2009 06:26 AM
jeep pics before and after rough country 2 1/2" lift and 1" boom shackles boaty1 YJ Wrangler Technical Forum 16 11-15-2008 06:03 PM
Sway Bar Extended End Links DixiesCJ3B TJ Wrangler Technical Forum 1 02-19-2008 11:55 AM
4" rough country w/ 2" spacers????? tjwhlr00 TJ Wrangler Technical Forum 17 11-07-2006 10:58 PM
