Rough Country 2.5 inch TJ lift kit. - Page 9 - JeepForum.com
post #121 of 5128 Old 08-15-2008, 07:39 PM
grogie
M-F: Cell Block #4533
grogie's Avatar
Clayton, did you get any shifting on your axles (like your rear axle shifting to the right a bit)?
Red Jeep Club #345
2006 TJ Sport -
2004 KJ Limited
2013 Off-Road Trailer -
from the onslaught of young idealists.” -- Don Colacho
grogie is offline
post #122 of 5128 Old 08-16-2008, 11:41 AM
Claytonfrnk
Hey 03_X, My measurements probably wouldn't be accurate, My front Clip is goobered up due to a drivers side front collision. I will measure but i don't know how accurate it will be. IF you look at the pictures close you can see my fugly front end.
I think the axles did shift a **** hair, they would have to shift a little bit wouldn't they? I mean if you change the distance from the frame to the axles and don't adjust your track bars, then they would have to move a little i think. It doesn't bother me though. Its only a salvage jeep.
94 yj 2'' BDS 3/8 boomerang shackles 31 10.50 BFG AT *SOLD*
01 tj sport, 44 rear,2.5 Rough country coil lift, 35 12.50 tires, 5 spd, 4.0L, DIY Highline, 50,000 miles bought as salvage title for 4 grand.
Build thread:
Claytonfrnk is offline
post #123 of 5128 Old 08-16-2008, 01:09 PM
STW
If you do get 2.5" of lift your rear axle will shift to the passenger side enough to make a driver's side tire on stock backspacing come really close to touching the spring perches. Just reach in there with your fingers and you can feel how close it is. This is why lift kits come with rear track bar relocation brackets. Even if you have aftermarket wheels with less backspacing so your tire's not scraping on the spring perch, it's worth recentering your axle. You can get OME's rear trackbar relocation bracket for about $16 so it won't boost the price of your lift much, but it takes some determination to install. Do a search for tips. I used the OME bracket on a 3" spring lift and it centered the axle well and is still secure and working well. Any lift sold as a kit that doesn't address this, or at least suggest the need to address it, is a problem.
The front axle will not move off center as much as the rear axle with 2.5" of lift. You may not be able to measure much of a shift and probably won't see much difference by sighting along the flares. There are several options for recentering the front axle but I wouldn't bother for 2.5" unless you measure a big shift.
2000 2.5 TJ, 5spd, 33s, 8274
STW is offline
post #124 of 5128 Old 08-16-2008, 03:05 PM
jim_bert
Just picked up this kit along with the steering stab. today. Anyone know where, or have a link to where I can pick up a rear trackbar relocation bracket?
Also, anythng else I should consider purchasing along with this kit, I'm currently running 32x11.5 wheels, with the steering stops adjusted?, would I need backspacing?
jim_bert is offline
post #125 of 5128 Old 08-16-2008, 04:10 PM
bobsled84088
bobsled84088 is offline
post #126 of 5128 Old 08-16-2008, 04:11 PM
jim_bert
thanks, should i go with a bracket or get and adjustable track bar? What about a front one?
2001 Yellow Sport, I6, Dana 44 3.73 gears, 31x10.5 procomp AT on cragar soft 8s, silverstar headlights, black headlight bezels, raingler full netting system, raingler roll bar handles, EK motorsport maglite holder, Tuffy door lockers, Tuffy glovebox, stepshield door entry guards, 130w Halogen KC Daylighters on windhield mounts, kenwood kvt-819dvd, 5.25" front speaker conversion, door switch defeat, U-Pol Raptor liner, Dynomax Super Turbo Cat-Back Exhaust, Iggee seat covers, SAVVY LED Taillights.
jim_bert is offline
post #127 of 5128 Old 08-16-2008, 04:17 PM
bobsled84088
If you can afford both front and rear, get the adjustables.
On the cheap, the bracket.
post #128 of 5128 Old 08-16-2008, 06:31 PM
hotwiredxj
Look at my install thread. Install is now complete.
I am VERY pleased with my purchase.
I just saw the post asking someone if they noticed any shift in the rear axle, and I went outside to investigate. I have less then a half an inch.
hotwiredxj is offline
post #129 of 5128 Old 08-16-2008, 07:23 PM
dualtjs
2011 JK Wrangler
Pics?
dualtjs is offline
post #130 of 5128 Old 08-16-2008, 07:33 PM
jim_bert
what was the total lift you got?
jim_bert is offline
post #131 of 5128 Old 08-17-2008, 01:01 PM
hotwiredxj
Click my link for pics. I got 2.5 in the front and about 2.75 in the rear.
post #132 of 5128 Old 08-18-2008, 12:08 AM
jokermgg1
haha im sorry guys but im new to this how do u post a new thread
jokermgg1 is offline
post #133 of 5128 Old 08-18-2008, 01:17 AM
mahgnillig
This thread has got me interested. I was originally going to buy the 2.25" BB with Skyjacker Hydros. However, my Jeep is a 2001 and I'm having some pretty serious metalwork added to it over the new couple of months (rear bumper/tire carrier/trail rack; front bumper & winch; rocker guards and engine skid). I was thinking that maybe my stock 7-year-old springs would not handle all the extra weight too well. Is it worth the extra cash to get this kit with the new springs if I'm going to be loading it down with an extra 400lbs or so of steel? I'll eventually be running 33x12.5s as well, so the new wheel/tire will also add weight on the back end.
mahgnillig is offline
post #134 of 5128 Old 08-18-2008, 01:50 AM
bman9089
bman9089's Avatar
You would probably be better off getting a kit rated for 3 - 3.5" of lift. That way, should it sink a bit (which it will) you'll be right at where you want to be.
"The American Republic will endure, until politicians realize they can bribe the people with their own money." -- Alexis de Tocqueville
“Sometimes I wonder whether the world is being run by smart people who are putting us on or by imbeciles who really mean it” -- Mark Twain
Romans 12:5 | 1 Peter 3:15 | Matthew 9:37-38
bman9089 is offline
post #135 of 5128 Old 08-18-2008, 03:16 PM
Narwhal
1983 CJ7
I'm planning on ordering this kit also. If I want to add a winch and other stuff could I add a 1" spacer to the front of this lift w/o any other problems to prevent sagging?
Narwhal is offline
Closed Thread
2.2 performance shocks , 2.5" lift , progressive , rc , rc 2.5 , rcxtreme , rough country
rough country 4 inch lift kit mossman07 TJ Wrangler Technical Forum 89 03-11-2017 11:44 PM
4 inch rough country lift for $500? tonythehazelnut YJ Wrangler Technical Forum 18 12-27-2009 07:41 PM
OME or rough country 2.5 inch lift? erhenriques TJ Wrangler Technical Forum 13 11-11-2009 09:44 AM
Rough Country 4 inch X Lift 06tjSPORT TJ Wrangler Technical Forum 20 07-31-2009 07:29 PM
anyone got the Rough Country 4 inch lift?? hiram TJ Wrangler Technical Forum 14 03-08-2007 07:05 PM
