Rough Country 2.5 inch TJ lift kit. - Page 54 - JeepForum.com
 1Likes
post #796 of 5128 Old 11-17-2008, 12:44 PM
Si1ver03Rubicon
Originally Posted by ActionJackson00 View Post
I have the 2.5l 4 cyl, what sort of differences would it make for the lift kit if i got it for the 4.0?
Send RCJEEP or XTREME a pm.
Si1ver03Rubicon is offline
post #797 of 5128 Old 11-17-2008, 02:03 PM Thread Starter
RCXTREME
It might ride a little stiffer with the 6 cyl coils on the 4 cyl jeep. Might just sit a little higher in the front too.
800-222-7023
www.roughcountry.com
RCXTREME is offline
post #798 of 5128 Old 11-18-2008, 08:50 AM
stoneyredneck
Originally Posted by 95BadBoy View Post
So what I read into how this kit settles in, with a 1" BL you would yield about 2.5" tire to flair on 33's if your rig is the normal results. I was thinking about giving this a try on my 01 DD, just because this spring lift was so inexpensive. That changes things big time. Is this about what everyone is ending up with ? I ask this because with the 2.5" + BL that I am running on my 05 - I've got 6" tire to flair on 33 STT's after a year and a half with a hardtop. No settling at all.
I think you may have misread my post. With the 1" BL I should have 4.5" from tire to flair with my 31s (I would estimate 3.5" with 33s). I have 3.5" of room now (with 31s), and do not have a BL. I am measuring the front, I still have a small rake going, and the back is .5" to 1" more clearance. I would be surprised if any 2.5 inch lift would be any different at all on mine. The bumper, winch plate, and winch probably add somewhere close to 200 lbs to the front end.
stoneyredneck is offline
post #799 of 5128 Old 11-19-2008, 01:56 PM
stadleroux
stadleroux's Avatar
Originally Posted by Si1ver03Rubicon View Post
1,000 mile update! The ride has improved slightly riding even better. Still no issues running without bumpstop extensions on 31's. (this kit flexes like CRAZY).
Do you still have the stock brake lines too or did you extend them?
stadleroux is offline
post #800 of 5128 Old 11-19-2008, 02:03 PM
easytim
1974 CJ5
My 2.5in Rough Country lift
http://webpages.charter.net/easytims/jeep.htm
Thanks everyone for your help,
I'm having my front and rear bumpers sprayed today with the same stuff they spray in bed liners
What if the hokey pokey really is what its all about
easytim is offline
post #801 of 5128 Old 11-19-2008, 03:17 PM
Fargo
At one time there was talk about a Heavy Duty version that would be better suited for Rubicons, LJs, and armored Jeeps. Is their still a possibility of seeing a HD version?
6spd manual
LJ Owners Group member #110
Fargo is offline
post #802 of 5128 Old 11-19-2008, 03:37 PM
Si1ver03Rubicon
Heh thanks. I'm still running the stock brake lines. They're close but nothing to worry about. I've flexed this kit out plenty now and I've had zero problems.
Nice write up dude.
There's a few LJs in here that look GREAT with their normal springs.
post #803 of 5128 Old 11-19-2008, 03:41 PM
Fargo
I guess I'll have to look again. I thought I saw in another thread where Rubicons were only getting about 1 1/2" of lift out of their lift. Since I have a Rubi LJ I was worried about it. I really want the full 2.5".
6spd manual
Fargo is offline
post #804 of 5128 Old 11-19-2008, 03:52 PM
Si1ver03Rubicon
I got the full 2.5" with my Rubicon.
post #805 of 5128 Old 11-19-2008, 04:05 PM
tobyw
Me too... Although, I haven't had mine out yet to let the springs settle in.
Jeeps. Lotsa Jeeps...
tobyw is offline
post #806 of 5128 Old 11-19-2008, 04:08 PM
Si1ver03Rubicon
What size and kind of tires are those!! Yours looks sick!
post #807 of 5128 Old 11-19-2008, 04:14 PM
Fargo
Glad to hear it. That sounds promising. Let us know how they look after they settle in a little.
6spd manual
Fargo is offline
post #808 of 5128 Old 11-19-2008, 04:55 PM
athos76
After my install on saturday, I took a look at the pictures and I got just over 3". I had a 3" BL on the rig already...so I measured...then installed the SL and measured... 3". The jeep rides great. I have to tweak the alignment a little since I get a little wander on the roads. By rear axle shifted about 1/4" or so.
No vibes, but I did get a lot of transfer lever binding since the PO had a humongous drop bracket on already
2006 I6 6-Speed X, 33" Goodyear Duratrac, 8.8.
athos76 is offline
post #809 of 5128 Old 11-19-2008, 07:36 PM
95BadBoy
So who's kit do you have now that yeilded so much lift and why do you want to get rid of it after only 1 year?
Fargo, I'm running DPG's Trailgunner coils with OME shocks on my 05. Veerryy happy with that. Not getting rid of it at all. I picked up a 01 as a DD this summer & was looking to get it a little cheap lovin for it's tired springs. But if I only net what I'm reading here, I'll probably spend a more to get close to what the 05 is yeilding. I would be bumming with only a couple of inches of clearence. Kinda like your quote from OMAN in your sig.
95BadBoy is offline
post #810 of 5128 Old 11-19-2008, 07:46 PM
-Rudy-
6"? Think your calculations are a bit off.
04 WJ Limited 4.7/QD: 245/70R17 Firestone A/T + Trimming
-Rudy- is offline
Closed Thread
2.2 performance shocks , 2.5" lift , progressive , rc , rc 2.5 , rcxtreme , rough country
rough country 4 inch lift kit mossman07 TJ Wrangler Technical Forum 89 03-11-2017 11:44 PM
4 inch rough country lift for $500? tonythehazelnut YJ Wrangler Technical Forum 18 12-27-2009 07:41 PM
OME or rough country 2.5 inch lift? erhenriques TJ Wrangler Technical Forum 13 11-11-2009 09:44 AM
Rough Country 4 inch X Lift 06tjSPORT TJ Wrangler Technical Forum 20 07-31-2009 07:29 PM
anyone got the Rough Country 4 inch lift?? hiram TJ Wrangler Technical Forum 14 03-08-2007 07:05 PM
