Rough Country 2.5 inch TJ lift kit. - Page 52 - JeepForum.com
 1Likes
post #766 of 5128 Old 11-09-2008, 06:00 PM
JeepIJoe
how much could i get like a 4" lift for? and what would it come with?
JeepIJoe is offline
post #767 of 5128 Old 11-09-2008, 06:09 PM
dbbd1
dbbd1's Avatar
Sorry, since I do not have a BL, I do not know what does or does not come with a kit. If it already comes with a bracket, great.
The opinions of worthless people, are worthless.
The only problem that you have with anyone in this world, is what you expect of them.
Society is no match for a stupid person.
"Life Is tough but it is tougher when you are stupid"
-John Wayne
dbbd1 is offline
post #768 of 5128 Old 11-10-2008, 05:51 AM
PDoyle
PDoyle's Avatar
Wondering if I'm the only one with this problem. I have the 4 by shift bracket and that can be adjusted.
But, is everybody driving around without their shift boot? Easiest thing to do is move the console back 2", I think.
2003 X, 5 speed, FT/RR bumpers by Eddie Reighard. JKS 1" body lift, JKS disco's, 2 1/2" Rough Country lift, 8k Warn, w/class 3 receiver FT & RR hitch. GA 8 rims riding 33's- GY Kevlar.
SOLD- 1985 CJ7 soft top , fiberglass body, 5" total lift258-6- Howell TBI, Full Roll cage.
PDoyle is offline
post #769 of 5128 Old 11-10-2008, 09:55 AM Thread Starter
RCXTREME
You can loosen up the console and should be able to move it back enough to clear. Might also want to check with the body lift that your body didnt shift any when putting it on.
800-222-7023
www.roughcountry.com
RCXTREME is offline
post #770 of 5128 Old 11-10-2008, 09:59 AM
Thrust
Hey Jeffery,
I installed my 2.5" with 1.25" BL over the weekend and had a small issue with the x-fer case relocation bracket. Since I have an LJ I didn't need to install the TC drop, however, after the BL install I had difficulty engaging 4-Lo. The directions specifically say NOT to install the TC relocation bracket unless you've also installed the TC drop. I was able to adjust the linkage just enough to get it to stay in 4-LO, but it is still more difficult to engage than I would like.
I should mention, I tried installing the TC lowering bracket to see if it would cure the problem but was unable to get everything aligned with the bracket. It was late and I had put ~8 hours in already so I gave up and just went back to the stock configuration with the aforementioned linkage adjustment.
Thoughts?
Prior to the lift, a TJ has the aerodynamics of a brick. After the lift it has the aerodynamics of a brick 2.5 inches higher.
Thrust is offline
post #771 of 5128 Old 11-10-2008, 04:13 PM Thread Starter
RCXTREME
Install the brackets. For some reason I dont know why the instructions say that. Have you adjusted the linkage down?
800-222-7023
RCXTREME is offline
post #772 of 5128 Old 11-10-2008, 05:01 PM
azcoyote
azcoyote's Avatar
$35 for the AA shifter linkage bracket from RedRock4x4 was the best $35 I ever spent...
Install the bracket foh sho...
JEEPLESS... :(
azcoyote is offline
post #773 of 5128 Old 11-11-2008, 09:55 PM
Brandon97TJ
I just got my 2.5" lift. I will be installing it tomorrow and posting all the pics of before during and after to my build thread.
Brandon97TJ is offline
post #774 of 5128 Old 11-12-2008, 04:58 AM
Thrust
Thanks. I ordered the AA bracket last night.
Thrust is offline
post #775 of 5128 Old 11-12-2008, 05:18 AM
easytim
1974 CJ5
I would like to use those pictures here if that will be OK with you.
http://webpages.charter.net/easytims/jeep.htm
easytim is offline
post #776 of 5128 Old 11-12-2008, 08:00 AM
tobyw
Got mine installed... Still have to dial in the pinion angle and install the CV rear shaft, then the new meats.
Jeeps. Lotsa Jeeps...
tobyw is offline
post #777 of 5128 Old 11-12-2008, 08:41 AM
ActionJackson00
^^^ {tobyw} ^^^looks pretty, what do you have on it now, and what will she have?
ActionJackson00 is offline
post #778 of 5128 Old 11-12-2008, 10:30 AM
tobyw
Thanks! It's pretty basic...
1.25" BL
1" MML
Nth/AEV TT
2.5" RC suspension lift w/ Perf 2.2 shocks
Currie Anti-Rock
Currie rear adj uppers
TW CV rear d/s
35" Krawlers
15x8 faux locks w/ 3.75" bs
Staun internal beadlocks
XD9000i
York OBA
blah blah blah
Pics are with the BL and suspension lift on the stock 245-16 MTR's...
tobyw is offline
post #779 of 5128 Old 11-12-2008, 12:31 PM
Si1ver03Rubicon
1.25" BL
1" MML
Nth/AEV TT
Currie Anti-Rock
TW CV rear d/s
35" Krawlers
XD9000i
York OBA
blah blah blah
You call that basic
Si1ver03Rubicon is offline
post #780 of 5128 Old 11-12-2008, 12:40 PM
tobyw
Well, all things are relative I guess. Basic for me, considering it's 100% bolt together. I'm used to the cut/burn/fab methodolgy. So far, I'm really enjoying the "build".
tobyw is offline
Closed Thread
2.2 performance shocks , 2.5" lift , progressive , rc , rc 2.5 , rcxtreme , rough country
rough country 4 inch lift kit mossman07 TJ Wrangler Technical Forum 89 03-11-2017 11:44 PM
4 inch rough country lift for $500? tonythehazelnut YJ Wrangler Technical Forum 18 12-27-2009 07:41 PM
OME or rough country 2.5 inch lift? erhenriques TJ Wrangler Technical Forum 13 11-11-2009 09:44 AM
Rough Country 4 inch X Lift 06tjSPORT TJ Wrangler Technical Forum 20 07-31-2009 07:29 PM
anyone got the Rough Country 4 inch lift?? hiram TJ Wrangler Technical Forum 14 03-08-2007 07:05 PM
