Rough Country 2.5 inch TJ lift kit. - Page 337 - JeepForum.com
 1Likes
post #5041 of 5128 Old 09-15-2013, 03:00 PM
canadiantj1999
Anyone know the free length of the 2.5 liter, 2.5" spring?
1999 jeep tj 4.0 custom longarm 40 mtr/k
1998 jeep tj 5.3 daily driver 2.5" lift. 37s highline
canadiantj1999 is offline
post #5042 of 5128 Old 09-15-2013, 03:06 PM
NYGLT56
Your Local Body Builder
NYGLT56's Avatar
Not off the top of my head. But I can measure. I know they stay seated with the 14"s at full flex.
2014 TJOTY Winner
IG: overlanding_racingdriver_
A Daily Driven Lowrider Adventure TJ on 40s.
NYGLT56 is offline
post #5043 of 5128 Old 09-15-2013, 03:12 PM
canadiantj1999
From looking at your jeep you modified your existing shock mount, which is a great mod to get balanced suspension travel. I already have the spring installed and I have the bilstiens for a 4" lift in place. I am not worried about unseating. Just trying to get some numbers down for different coil springs and cannot for the life of me find this info online. And I do not want to pull them off the jeep. You have a working build thread for your jeep NYGLT56?
post #5044 of 5128 Old 09-15-2013, 07:03 PM
jscusmcvet
Installed this kit about a year ago... The springs are solid and work as advertised. I did ditch the front 2.2 shocks for some bilstein 5100's great ride with this combo. Running 33x12.50 on 3.5 bs. I did add .75 spacers in the back.
jscusmcvet is offline
post #5045 of 5128 Old 09-15-2013, 07:56 PM
NYGLT56
NYGLT56's Avatar
I see. I used to. It's gone now.
2014 TJOTY Winner
NYGLT56 is offline
post #5046 of 5128 Old 01-07-2014, 07:09 AM
CPFLIP
with this lift what size of tires do you guys run could you fit a 31x10.5r15 or even a 33x10.5r15
CPFLIP is offline
post #5047 of 5128 Old 01-07-2014, 07:24 AM
NYGLT56
NYGLT56's Avatar
I fit 31s. 35s. 37s. Pick your poison.
2014 TJOTY Winner
NYGLT56 is offline
post #5048 of 5128 Old 01-07-2014, 07:29 AM
bobdog
Without the lift I run 31's just fine. So, larger would fit, up to a point, with the lift.
Black Jeep Society
New Mexico Jeep Club
Atheist Jeep Society
Micro-Trailer Club
bobdog is offline
post #5049 of 5128 Old 01-08-2014, 09:13 AM
mgdmeyers
If you are actually gonna wheel it you might want to consider the other factors as well that are more important than tire clearance. Not sure what rig you're running, but Steering upgrades, Differential/axel upgrades, gearing, etc. all go along with bigger tires. On a factory D35 differential with 3.07s you really don't want to go any bigger than 33 anyway. I have 3.73 gearing and 33x12.5s and it's even pretty sluggish. Best thing to do (but the least fun, unfortunately) is design a plan for your jeep, what you're ultimate setup (tire size, lift, fenders, etc.) and work your way inside out. Do all the upgrades you need to have a bulletproof rig with your chosen tire size and trail difficulty. Then, once you have the interior components to support them, purchase the tires.
Just my humble two cents after doing my build a bit out of order and regretting it a bit.
2004 TJ RME, 3:73s D30/44, RC 2.5", Factory Alcoas wrapped in 33x12.5 Pro Comp Xterrains spaced 1.5" (3.75" total BS), Smittybuilt stinger, Procomp Rear Bumper, ToughStuff Onboard Air/11 Gal Tank, Skids galore
"Funny coincidence, I just dug a money pit and parked it outside my house."
mgdmeyers is offline
post #5050 of 5128 Old 01-09-2014, 07:00 PM
flashpointmax
I bought a set of BFG 31's after I installed this lift kit a couple years ago... still running them and like them just fine for what I do. However, there is plenty of room for at least 33's too... any larger than that though and I'm of the opinion that you'd be better off with more lift.
flashpointmax is offline
post #5051 of 5128 Old 04-21-2014, 04:24 PM
Kayakfisher
I installed this same kit this past weekend. Still need to get alignment and track bars adjusted correctly but it feels very much like stock shocks. Once I get some more miles on them I will write more. As for now, I need to install the t-case drop kit and installing a drop pitman arm.
Kayakfisher is offline
post #5052 of 5128 Old 04-21-2014, 04:27 PM
McLovin
If you drop the pitnam arm you will need to drop the front track bar as well or you will get bumpsteer. The best, IMO, choice is to just not install the drop pitnam arm.
I have 4 new zone hydro shocks for sale...PM for a price.
McLovin is offline
post #5053 of 5128 Old 04-21-2014, 05:05 PM
4wdjeepguy
Spend your money on a 1/2" BL and 1" mml... Money would be a hell of a lot better spent
IG: CS_OFFROAD
YOUTUBE: CS OFFROAD
4wdjeepguy is offline
post #5054 of 5128 Old 04-22-2014, 05:37 PM
tjoffroadr
I've got the 2.5" lift and the 1.25" body lift with 1" mml. Here's the end result! 2004 Sport
tjoffroadr is offline
post #5055 of 5128 Old 04-28-2014, 07:47 PM
Kayakfisher
I ended up skipping the drop pitman arm. After getting it aligned, it rode fine. I looked and the track bar and the bar that links to the pitman arm are parallel to each other. All is good now except for the fact that all of my bolts to the skid plate are rusted so bad they basically welded themselves. I broke one free but it just sits there and turns. Nothing is ever easy...lol Once the t-case drop kit is on, I believe the drive line vibration will be next to nothing. It will be easier to clean also..
Closed Thread
2.2 performance shocks , 2.5" lift , progressive , rc , rc 2.5 , rcxtreme , rough country
rough country 4 inch lift kit mossman07 TJ Wrangler Technical Forum 89 03-11-2017 11:44 PM
4 inch rough country lift for $500? tonythehazelnut YJ Wrangler Technical Forum 18 12-27-2009 07:41 PM
OME or rough country 2.5 inch lift? erhenriques TJ Wrangler Technical Forum 13 11-11-2009 09:44 AM
Rough Country 4 inch X Lift 06tjSPORT TJ Wrangler Technical Forum 20 07-31-2009 07:29 PM
anyone got the Rough Country 4 inch lift?? hiram TJ Wrangler Technical Forum 14 03-08-2007 07:05 PM
