Rough Country 2.5 inch TJ lift kit. - Page 334 - JeepForum.com
post #4996 of 5128 Old 05-26-2012, 03:50 PM
wranglerTX
nice looking jeep. ^
wranglerTX is offline
post #4997 of 5128 Old 05-26-2012, 04:11 PM
texas-hooligan
Thanks!
texas-hooligan is offline
post #4998 of 5128 Old 05-27-2012, 07:27 AM
texas-hooligan
A few more shots after getting the Jeep all cleaned up
Attachment 404273
Attachment 404274
Attachment 404275
post #4999 of 5128 Old 05-28-2012, 12:13 AM
WsRpAoNrGtLtEjR
^ That's a good lookin Jeep, sweet color. I'm also liking those rockers, which look frame-mounted if I'm not mistaken. What kind are those?
WsRpAoNrGtLtEjR is offline
post #5000 of 5128 Old 05-28-2012, 06:31 AM
texas-hooligan
They mount to the frame bolts and I got them from 4wheelparts.com
post #5001 of 5128 Old 05-28-2012, 09:21 AM
flashpointmax
Tex... looks like the lift install went well. Did you do a "touch up" to the front end alignment? It's usually a good idea to check the toe-in even with a relatively short lift like this 2.5" kit. You may be getting more tread-scrub than you need if you don't adjust the tie-rod length.
flashpointmax is offline
post #5002 of 5128 Old 05-28-2012, 09:29 AM
texas-hooligan
Yep I did the alignment as well. Drives pretty straight right now and no DW yet. Will do a professional alignment next time I get new tires.
post #5003 of 5128 Old 06-14-2012, 11:45 AM
Alberto4x4
Alberto V. P.
Jeep TJ Sport 4.0 Auto 00
Land Rover Discovery 300Tdi ES 97
Alicante (Spain)
Alberto4x4 is offline
post #5004 of 5128 Old 08-16-2012, 11:54 AM
duckalot
Originally Posted by RCXTREME View Post
We now have our 2.5 inch lift kit out for the Jeep TJ. It consist of four progressive rate coils, four 2.2 performance shocks and t case spacers.
This kit retails at 299.95 but when you call me and mention being a jeepforum.com member you will recieve 10% off.
I will have video up shortly of how good the coils work.
Is the 10% off offer still good??
Thanks
duckalot is offline
post #5005 of 5128 Old 09-23-2012, 12:39 PM
camc91
Hey guys i just bought a 05 jeep with 6spd 4.0. This is my first jeep and want to know some things before i order this kit...
The Jeep has 265 70 17 on it already.
Do i need to buy a tc kit for this lift? Do i need a MML as well?
Thanks
camc91 is offline
post #5006 of 5128 Old 09-23-2012, 02:16 PM
dscabra
Thanks
My recommendations if this is the kit you plan to buy (I have it as well):
1. The need for the TC drop kit is a case-by-case, and it was included in my kit
2. Not shure about the need for a MML, but I'm not using one
3. Do NOT buy the RC shocks!!! Get a set of Bilstein 5100s and you will be much happier.
4. Get the rear track bar relocation bracket
dscabra is offline
post #5007 of 5128 Old 09-23-2012, 09:47 PM
Heath
2014 JK Wrangler
Thanks
You need to know the shocks suck and typically are not only the wrong length for their respective springs, but their shocks also have a mismatched collapsed to extended ratio, meaning you have an extra 2"+ of body that you don't get back in shaft or cycle. IE a 13" body shock will have like 8" of travel iirc.
You also need to know that their springs will sag after a while and even faster as you add more weight to the scenario.
I'm not bashing RC, I'm just telling the truth. I haven't tried any of their shocks or control arms on anything in about a year, so some improvements may have been made.
2013 JKU Rubicon
Heath is offline
post #5008 of 5128 Old 10-17-2012, 09:40 PM
JoeDoogN
Just installed my lift, so far so good. As a DD and weekend offroader it has done well for me. You're buying a $300 suspension lift, don't expect the quality and performance to be comparable to the big name brands.
Now onto the search for the cause of my DW! Can't go 50mph+ grrrrr..
JoeDoogN is offline
post #5009 of 5128 Old 10-18-2012, 05:44 AM
PDoyle
PDoyle's Avatar
I bought my kit in 2006. 0 problems and no sag. 100% on road no dirt
2003 X, 5 speed, FT/RR bumpers by Eddie Reighard. JKS 1" body lift, JKS disco's, 2 1/2" Rough Country lift, 8k Warn, w/class 3 receiver FT & RR hitch. GA 8 rims riding 33's- GY Kevlar.
SOLD- 1985 CJ7 soft top , fiberglass body, 5" total lift258-6- Howell TBI, Full Roll cage.
PDoyle is offline
post #5010 of 5128 Old 10-18-2012, 06:29 AM
TheRealKTrain
JK Wrangler
Probably worn out control arms.
"We are what we repeatedly do. Excellence, then, is not an act, but a habit." Aristotle
Μολὼν λαβέ
TheRealKTrain is offline
Closed Thread
2.2 performance shocks , 2.5" lift , progressive , rc , rc 2.5 , rcxtreme , rough country
rough country 4 inch lift kit mossman07 TJ Wrangler Technical Forum 89 03-11-2017 11:44 PM
4 inch rough country lift for $500? tonythehazelnut YJ Wrangler Technical Forum 18 12-27-2009 07:41 PM
OME or rough country 2.5 inch lift? erhenriques TJ Wrangler Technical Forum 13 11-11-2009 09:44 AM
Rough Country 4 inch X Lift 06tjSPORT TJ Wrangler Technical Forum 20 07-31-2009 07:29 PM
anyone got the Rough Country 4 inch lift?? hiram TJ Wrangler Technical Forum 14 03-08-2007 07:05 PM
