07-07-2010, 04:14 PM
#4246
Originally Posted by SFT2
I thought he was a gynecologist. Must be diversifying his resume.
This is where a lot of people get confused because he received his doctorate in physics, but decided that he wanted to be a gynecologist so he just started practicing without going to school or anything, I think he ended up getting in a little bit of trouble, but not until he had his share of fun
2005 Wrangler TJ, 3 1/4" RC lift, Cragar Soft 8's 32" BFG Mud Terrains, Smittybilt SRC D-Ring bumpers, Smittybilt XRC8 winch, Body Armor Rockcrawler side guards
[URL="http://www.jeepforum.com/forum/f22/my-05-tj-build-916271/"][SIZE="3"][COLOR="Red"]My Build Thread[/COLOR][/SIZE][/URL]
[COLOR="Red"][_l_[COLOR="black"],[/COLOR][____][COLOR="Black"],[/COLOR]
l----L - [COLOR="Black"]O[/COLOR]lllllll[COLOR="Black"]O[/COLOR]-[/COLOR]
(o)_) (o)_)--)_)
[COLOR="Green"]Wife≥Jeep>GF
Relearn your priorities.[/COLOR]
WANTED: SYE and cv shaft...good condition and good price. for a TJ with about 5-6" of lift.
07-07-2010, 04:27 PM
#4247
Ah, gotcha. Kinda where I am in my life
Mine- 2k TJ, RC 2.5 lift, .75 spacers, Soft 8s, 33" KM2s, winch, lights, and so on
Hers- 06 WK, bone stock until she leaves it and the credit card with me for an unsupervised weekend
You're the retarded offspring of five monkeys having butt sex with a fish-squirrel.
07-14-2010, 06:40 PM
#4248
Did anyone have to replace their bump stops? Mine look pretty worn.
07-14-2010, 08:45 PM
#4249
Which bumpstops are you talking about? The RC ones on the shocks? I cut them off and tossed them in the trash because the shock absorber is not intended to act as a bumpstop. I installed the correct 2" bumpstops front and rear to keep the shocks from bottoming out.
07-14-2010, 09:16 PM
#4250
^ this is true, and the shocks are about perfect length for the 3.25" kit with 32's. Have you taken the rubber jouncers off and properly bump-stopped the rear, because that alone will give out around an inch of up-travel.
I'm assuming they have to be cut off?
98 XJ 4-door, 6.5" lift, SYE, sliders, locked HP30, welded 29-spline 8.25, 35" buck shots.
07-14-2010, 10:52 PM
#4251
Nah, you can gnaw them off, it just takes longer.
97 TJ Sport - 4.0/HP D30 w ARB/8.8 w LS/4.88s; 35s and flat fenders on 2.5 lift
84 CJ7; frame off restoration in progress.
The technical advice you get from me here is worth exactly what you paid me for it. Warranty issues will be reimbursed at double what you paid me for the advice.
07-15-2010, 09:56 AM
#4252
Which 2" bump stops did you use? Did they require the removal of the factory bump stops?
07-16-2010, 01:47 PM
#4253
I used the energy suspension polyurethane bump stops in place of my TERRIBLE CONDITION factory ones. $20 a pair. My lift is done. I am very happy with the lift I got. I did not measure, but getting in and out is sure more difficult, lol. The ride is nice. The springs were a bear to get in. I used ratchet straps. I added the rear trackbar bracket and the steering stabilizer. Jeffrey from Rough Country was great. I am really glad I did it myself, not only for the money I saved, but it was a good time working with my brothers. Tomorrow I am going to get an alignment. The steering wheel is only off by a hair. Here are some pictures.
07-16-2010, 08:53 PM
#4254
The rear bumpstop extensions I bought from RC for about $19 or 20. They go between the OEM bumpstop and the top coil spring bucket. Unbolt the OEM stop, insert the extension, put the OEM back in place, then tighten the new longer bolt.
The front bumpstop "extensions" go on the axle side and required me to drill a hole in the mount to bolt it on. It looks just like a hockey puck, which many use. I believe these are OME from Quadratec.
07-16-2010, 08:55 PM
#4255
What size are those tires? My 31's look tiny on mine right now.
07-16-2010, 09:50 PM
#4256
Come on Jeffery!! lets get the long arm upgrade out there! I would buy it next week if you could promise me the availability!
(o)_) (o)_)--)_)
07-19-2010, 10:02 PM
#4257
Anyone have this problem with there 2.5 Rough Country Lift??
Beep Beep, who got da keys to the JEEP???
Red Jeep Club #556 - "DA 4-$LANGER"
1997 Flame Red TJ 4-Banger (2.5L) 4.0 TB 62mm Bored w/ Spacer -- 31x10.50 D. Cepek "Crushers" -- 15" Black Rock Crawlers -- AEM DryFlow -- Dynomax Super Turbo Cat-Back -- EBC Brake System -- Rough Country 2.5" Lift w/ Discos -- RC Adj Track Bars -- Currie HD Steering -- Rugged Ridge Diff Covers - DDM 6000K HID
07-19-2010, 11:33 PM
#4258
What's the problem we're looking at here? I must be overlooking the obvious.
07-20-2010, 05:02 AM
#4259
Is it supposed to be resting on the skid plate ?
It seems to be setting up a little.
Mine does the same thing and is it ment to be that way ?
Thanks.
07-20-2010, 09:23 AM
#4260
4 coils and 4 shocks have nothing to do with the skid plate....What makes you think there is something wrong??
97 tj-Locked up on 33's
