Quantcast Rough Country 2.5 inch TJ lift kit. - Page 229 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Rough Country 2.5 inch TJ lift kit.
Old 11-16-2009, 02:20 PM   #3421
Sobie
Bolt-on Maniac
Sobie's Avatar
The pucks are the same as the seat riser ones.Just take out the factory seat frame bolts,put the pucks under the rail where the bolts go and get 1" longer bolts to bolt the seat back down.You would need 2 extra pucks (8) to do that.Performance Accessories sells the BL pucks for .99 cents.
The PA pucks are 1 inch so youll need washers to build up 1/4 inch over that to match the RC pucks.
My Golden Eagle Build
USAF
Sobie is offline   Reply With Quote
Old 11-16-2009, 03:51 PM   #3422
B2CARPEN
Jeep Junky
B2CARPEN's Avatar
Seat risers or extended bumpstops.
Ditto... I used my TC pucks (along with 2 additional from a local guy that was getting rid of his pucks) as seat risers. The RC TC drop kit pucks are 1.25" which is the exact same as the 1.25" BL pucks.
You'll need to replace the factory bolts with longer bolts.
(2) 7/16-20x2 hex-head bolts and (6) m8-60 hex-head bolts
JFI member #1
Built not bought member #153
IndyORV
Extreme Jeep Club
Down and Dirty Off-Road
My Build Thread - axle swaps and long arm madness
B2CARPEN is offline   Reply With Quote
Old 11-16-2009, 03:57 PM   #3423
TheBoogieman
Demonic Jeep Freak!
TheBoogieman's Avatar
Good call.
TheBoogieman is offline   Reply With Quote
Old 11-17-2009, 06:06 PM   #3424
TxFireman1972
TxFireman1972's Avatar
Originally Posted by RCXTREME View Post
Those are the DC-1 rims with the rcx rings that we sell here.
Do you have any pics of what the rock rings would look like on a black DC-1 ?
TxFireman1972 is offline   Reply With Quote
Old 11-18-2009, 09:27 AM   #3425
BloodThirsty
Blue On Black
BloodThirsty's Avatar
I'm probably ordering mine today for my black DC1's. I don't care too much what they look like cause I gouged the CRAP out of one of mine a few weeks ago in the rocks. These would have saved it.
BloodThirsty is offline   Reply With Quote
Old 11-19-2009, 11:19 AM   #3426
SaltyJeeper
thanks Mitz, that worked.
Anyone install a RC front adjustable track bar? I did and the steering wheel is turned to the right by 90 deg, when I called RC they informed me that I needed a Drop Pitman Arm. Wish they would have told me when I ordered it the first time. Anyone else have this issue?
jeff
MilitaryJeepers.com
Hull #102
SaltyJeeper is offline   Reply With Quote
Old 11-19-2009, 11:58 AM   #3427
Peanut72
I installed the 3.25 lift and mine was off 90* as well. I did not install an adjustable trac bar or drop pitman arm. I relocated the stock trac bar as described in the instructions. To adjust the steering wheel, there is a collar on the drag link with two 15 mm bolts on it. With the wheels on the ground, loosen both bolts with a deep well socket and simply turn the collar until the steering wheel is in the correct position again. Take it for a drive and you may have to readjust it again, but its that easy. Helps to have someone watch the wheel as it turns, it took me a few times of getting up and down until i finally got it right.
THE LINK TO MY REBUILD
Peanut72 is offline   Reply With Quote
Old 11-19-2009, 12:08 PM   #3428
B2CARPEN
Jeep Junky
B2CARPEN's Avatar
Odds are that the alignment is off as well. Mine was WAYYY off after I installed the lift. It's manditory to get an alignment after any lift install
JFI member #1
IndyORV
Extreme Jeep Club
Old 11-19-2009, 01:17 PM   #3429
05beryltjx
05beryltjx's Avatar
Its good to hear such a positive response overall to this kit, i'm picking one up from Jeeperz Creeperz in Wyandotte MI, this weekend, I cant wait to get some altitude under my rig!
05beryltjx is offline   Reply With Quote
Old 11-19-2009, 01:18 PM   #3430
Peanut72
true that, mine was/is way off. Im not too concerned right now as im still not ready for the highway. I drove it around the subdivision a little bit just to check it out and it drives ok, but the toe is way out. Not surprised ad I had both axles completely off. Once I get ready to put new rubber under it and drive it for real, I will have it lined up. I tried to adjust the toe by a write up I found here, but I cant get it to break loose. But yeah, its most likely a must to get an alignment.
Old 11-21-2009, 06:52 AM   #3431
SaltyJeeper
my local tire shop told me the angle was too far off to do a standard adjust. This is because of the front adjust track bar putting too much stress on tie rods and he recommended DPA. When I called RC to check, he said "if you have our adjust track bar you will need a DPA" and sold me one. Just wish they would have told me in the beginning, wouldnt have made me balk at the purchase, would have saved me a week of my jeep sitting in my driveway waiting for part. beside that, and the poor directions, the kit has been great. need to get a transmisson skid that wont hit driveshaft now.
thanks for the help everyone,
jeff
MilitaryJeepers.com
Hull #102
Old 11-21-2009, 06:57 AM   #3432
TxFireman1972
I assume DPA means dropped pitman arm. I thought someone told me hat those were a no no on TJ's. May I'm dreaming LOL
Old 11-21-2009, 12:33 PM   #3433
SaltyJeeper
I read same thing, but in the end RC said I needed one with the Front Adjust Trackbar.
jeff
MilitaryJeepers.com
Hull #102
Old 11-21-2009, 02:44 PM   #3434
jerseyjeep22
how often do you need a front adjust trackbar? i mean im getting the 2.5 and rear bracket but i was under the impression the front didnt shift?
jerseyjeep22 is offline   Reply With Quote
Old 11-21-2009, 02:54 PM   #3435
CTTJ
Did TB relocate on my 3.25 kit
Did the toe in my garage my self 3600 miles later tire wear is perfect.
Save your money for gas
Thumbs up for Jeffry at RC emailed him on leaking rear shocks with 3600 miles and sent me replacements you cant squek about that kind of service.
Rust Never Sleeps
CTTJ is offline   Reply With Quote
2.2 performance shocks, 2.5" lift, progressive, rc, rc 2.5, rcxtreme, rough country
Glock Forum
