Rough Country 2.5 inch TJ lift kit. - Page 105 - JeepForum.com
post #1561 of 5128 Old 02-23-2009, 11:07 AM
CoolContractor
You guys need to post your pictures after your mods. I am waiting impatiently for my 3.25" RC lift.
2006 TJ Rubicon
CoolContractor is offline
post #1562 of 5128 Old 02-23-2009, 11:11 AM
jrb470
DITTO!
I PM'd Jeffrey to see if he knows how long it will be.
Are you adding BOTH sets of spacers or are you only doing one set to "level" it out?
____
(OlllllO)
65th Anniversary Edition TJ
Jeep Green
Rough Country 3.25" Suspension Lift
JKS 1.25" Body Lift & 1" Budget Motor Mount Lift
33x12.50/15 BFG All-Terrain's on 15x8 ProComp Series 51 w/ 3.75" BS
jrb470 is offline
post #1563 of 5128 Old 02-23-2009, 11:19 AM
CoolContractor
I just got an e-mail back from Jeffrey and he said that they will receive the back ordered shocks on Feb. 27th. Ship out the next day. I will probably install the entire kit except for the rear spacers. My Rubicon sits about an inch lower in front and that is with the hard top on and stock bumpers and no winch. Looking into the Hanson bumpers and Warn winch.
post #1564 of 5128 Old 02-23-2009, 11:25 AM
fr0st_m0nkey
If a 3/4" spacer will work, does anyone think that an 1/4" inch will make a difference? Do I need longer break lines or anything to put it on?
White 2006 TJ X - 6 Speed - 4.0L i6 - 2.5" Rough Country - 33x12.5 Toyo Open Country M/Ts
fr0st_m0nkey is offline
post #1565 of 5128 Old 02-23-2009, 11:29 AM
CoolContractor
I asked Jeffrey at RC and he said new front brake lines are not necessary on the 3.25" lift. I don't know about higher than that.
2006 TJ Rubicon
post #1566 of 5128 Old 02-23-2009, 11:38 AM
jrb470
I just got a PM from him too about the 27th! I can't wait.
I wasnt planning on running a winch but I do want my jeep to be level... I may just add the spacers up front. Not sure yet!
____
(OlllllO)
Jeep Green
jrb470 is offline
post #1567 of 5128 Old 02-23-2009, 11:40 AM
fr0st_m0nkey
Maybe I'll see if I can just cut them down a bit, haha.
post #1568 of 5128 Old 02-23-2009, 11:53 AM
yellowismellow
Custom User Title
yellowismellow's Avatar
ordered the 3.25" kit.
ok so i ordered the 3.25 kit this afternoon. should be here by friday. question...i have jks quick disco's on my stock height TJ right now. they are for 0-2" lift. does anyone know if they will work after installing this kit? in other words, if i max out the disco's, will the swaybar be 10* like it's supposed to be? or will it be lower than it should?
also, how many of you drilled the hole where the front trackbar mounts? im kinda scared of drilling that hole.
cant wait till the ups guy shows up again, my rims should be coming this week too.
2006 TJ Sport
2004 WJ Special Edition
yellowismellow is offline
post #1569 of 5128 Old 02-23-2009, 12:41 PM
Alexia
Alexia's Avatar
Jeffrey is a very busy person today. I finished ordering my 2.5" kit from him and it is definitely a big savings over the online store.
I had planned on ordering the 4" X kit, but some one close to me convinced me to save my money for other things. :P
2004 Jeep Wrangler Unlimited, Automatic
RC 2.5" Lift - RC 2.5" Rear Track Bar Bracket - JKS 1.25" Body Lift - JKS Front Disconnects - JKS 1" Budget Motor Mount Lift - Spidertrax 1.25" Spacers -
Power Door Locks with Keyless Entry
Alexia is offline
post #1570 of 5128 Old 02-23-2009, 02:02 PM
Crockett
hey jeffrey.i was lookin at the new 3.25 lift. i was wonering if you could substitute some 4in coils in that kit. and i dont need shocks. i already have some of your new lower arms and everything else. I would just like the coils and front disconect and rear links.
Crockett is offline
post #1571 of 5128 Old 02-24-2009, 11:59 AM
hend040
2.5 lift
ordered my kit last week will be here tomorrow hope to throw it on as soon as ups drops it off will post before and after pics
hend040 is offline
post #1572 of 5128 Old 02-24-2009, 12:16 PM
CCJ
Originally Posted by 03Jeeper View Post
would I be able to run 33x12.5 MTZ's with just the 2.5 lift??
It depends on your backspacing. See my profile. I run 33x12.5 mud tires on just 2" BB spacers from teraflex. And stock shocks. The ride is a little bumpier then stock. Cause of the stock shocks being so flexed out (2" remember) but of course my Tire PSI is at 26 all around. So that helps the ride, just not the fuel mileage.
CCJ is offline
post #1573 of 5128 Old 02-24-2009, 12:52 PM
emev0l
A lot of people run there stock sway bar end links, if you max your discos out it will work ok, but it will be better with the longer ones. You might want to try to sell the ones you have to someone on the site and buy new ones. Longer rear JKS end links are only $40, wouldn't hurt to pick those up.
2001 TJ 4.6 Auto 4.5" AEV suspension 35's
2002 TJ 4.0 Manual 3" BDS suspension 33's
1987 Chevy 1 Ton 12" suspension 44's
1970 Cutlass 442 468CID TH400
1999 7.3 Powerstroke
emev0l is offline
post #1574 of 5128 Old 02-24-2009, 10:32 PM
Si1ver03Rubicon
Hoping to have some 265/85/16's (33x10.5) with this setup soon!!!
Si1ver03Rubicon is offline
post #1575 of 5128 Old 02-25-2009, 08:00 AM
Rowingfish87
WOOOOT. just ordered mine with the SS and track bar bracket from jeff. be here middle of next week!! (dang shocks are back-ordered.)
2002 Sahara 4.0L/NV3550/NP231/D30/D44
35x12.50x15 MTRs
RC 2.5" Lift & 1"BL
1998 Dodge Ram 2500 4x4 CTD
Rowingfish87 is offline
Closed Thread
2.2 performance shocks , 2.5" lift , progressive , rc , rc 2.5 , rcxtreme , rough country
rough country 4 inch lift kit mossman07 TJ Wrangler Technical Forum 89 03-11-2017 11:44 PM
4 inch rough country lift for $500? tonythehazelnut YJ Wrangler Technical Forum 18 12-27-2009 07:41 PM
OME or rough country 2.5 inch lift? erhenriques TJ Wrangler Technical Forum 13 11-11-2009 09:44 AM
Rough Country 4 inch X Lift 06tjSPORT TJ Wrangler Technical Forum 20 07-31-2009 07:29 PM
anyone got the Rough Country 4 inch lift?? hiram TJ Wrangler Technical Forum 14 03-08-2007 07:05 PM
