Rough Country 2.5 inch TJ lift kit. - Page 104 - JeepForum.com
post #1546 of 5128 Old 02-21-2009, 07:26 PM
timmyt
Originally Posted by mdcj7 View Post
Do you have spacers on your wheels do the 285 rub when turning.
i haven't rubbed yet, haven't turned to full lock yet either.
2006 LJ Rubicon. 2.5"RC BB/BL kit. 285/75/16 BFG KM2's on Moabs.
timmyt is offline
post #1547 of 5128 Old 02-21-2009, 07:26 PM
BloodThirsty
Originally Posted by JONIG View Post
looks good Brent!
Dave
Ha! I was wondering if you got my text! Thanks man. Did you get that email I sent you about the Rally? I called and signed up today.
Bout time you posted on here!!!!
BloodThirsty is offline
post #1548 of 5128 Old 02-22-2009, 12:00 PM
TSM_88YJ
Originally Posted by timmyt View Post
my lift is all done and got 285/75/16 bfg km2's
before
after
Hows the ride versus stock? I have the same jeep and am wondering if you notice any difference?
TSM_88YJ is offline
post #1549 of 5128 Old 02-22-2009, 12:02 PM
mouse
Looking goood man!!
mouse is offline
post #1550 of 5128 Old 02-22-2009, 01:09 PM
timmyt
the ride is a lot better with the RC set-up. i need to lower the psi on the km2s
it's pretty stiff at 35psi.
timmyt is offline
post #1551 of 5128 Old 02-22-2009, 01:24 PM
emev0l
Originally Posted by EZEC View Post
your guy is wrong.
rc sells a 1.25" bl which really is all you need for 33's.
He's not wrong if were talking about doing it the right way...
Sure you can run a TJ with 3.5" of suspension lift with stock control arms and stock track bars, stock sway bar end links, but it's not the right way to do it. The higher your springs are the farther off center your axles become, and if you don't have longer control arms it pulls your axles in closer to the center of the Jeep. If you don't run longer sway bar end links your sway bars will be at the wrong angle and it will not handle as well on the road and not flex as well as it could off road.
You really want longer control arms after 3" of suspension lift.
2001 TJ 4.6 Auto 4.5" AEV suspension 35's
2002 TJ 4.0 Manual 3" BDS suspension 33's
1987 Chevy 1 Ton 12" suspension 44's
1970 Cutlass 442 468CID TH400
1999 7.3 Powerstroke
emev0l is offline
post #1552 of 5128 Old 02-22-2009, 06:17 PM
MedicJK
2015 JK Wrangler
would I be able to run 33x12.5 MTZ's with just the 2.5 lift??
Sienna Pearl Coat Club Member #24
/l ,[____],
l---L-OlllllllO-
()_)-()_)-o-)_)
MedicJK is offline
post #1553 of 5128 Old 02-22-2009, 07:35 PM
fr0st_m0nkey
I am also wondering this. I wish there were more 2.5" kit pictures I need to see the tire combos!
White 2006 TJ X - 6 Speed - 4.0L i6 - 2.5" Rough Country - 33x12.5 Toyo Open Country M/Ts
fr0st_m0nkey is offline
post #1554 of 5128 Old 02-22-2009, 07:41 PM
jrb470
You could. But for MY tastes, it would be too much of a squeeze. Not too much more to add the 1.25" BL/1"MML combo to give you 3.75" of lift.
____
(OlllllO)
65th Anniversary Edition TJ
Jeep Green
Rough Country 3.25" Suspension Lift
JKS 1.25" Body Lift & 1" Budget Motor Mount Lift
33x12.50/15 BFG All-Terrain's on 15x8 ProComp Series 51 w/ 3.75" BS
jrb470 is offline
post #1555 of 5128 Old 02-22-2009, 07:46 PM
fr0st_m0nkey
Well I have to buy new tires by tomorrow and I'm only running on 2.5" of lift. I want to add a 2" body lift when I have more money, or just call that guy back and have him install the 1" spacers and buy the other parts needed as soon as I get the money. Is it possible to run that extra 1" coil for a few weeks without problems? I'm not going to be offroading it until everything is finished.
post #1556 of 5128 Old 02-22-2009, 07:51 PM
jrb470
The unlimited would probably look better with the 35's. I think you could add the 1" spacers and run the 35's then add the BL to give you more clearance.
____
(OlllllO)
Jeep Green
jrb470 is offline
post #1557 of 5128 Old 02-22-2009, 07:56 PM
eaglejeep
I just ordered the rc 2.5" susp lift + 1.25 bl combo. i also ordered the rear track bar bracket and stabilizer. Just curious, i have seen in this thread that alot of people combine the body lift with the 1" mml. the kit comes with the t-case spacer. will i need the mml? if yes, could you explain why? i spend too much time on the hwy and dont want any vibrations. Thanks!
eaglejeep is offline
post #1558 of 5128 Old 02-22-2009, 07:56 PM
fr0st_m0nkey
I only want 33s though. You're sure I can safely add that spacer?
post #1559 of 5128 Old 02-22-2009, 08:00 PM
jrb470
Sorry.. I misunderstood. A bit too much wine this evening, perhaps.
You could definately add those spacers. I guy I work with has a
2"BB ONLY and running 33x12.50 Swampers. Looks a bit weird but it works none the less.
I'm adding .75" spacers to the 2.5" springs... like i said I ordered that 3.25" kit!
____
(OlllllO)
Jeep Green
jrb470 is offline
post #1560 of 5128 Old 02-23-2009, 10:54 AM
timmyt
i think i'm going to need spacers. rubbed last night when i backed out of my parking spot. i'm going to try adjusting my steering stops first and see if that helps.
timmyt is offline
Closed Thread
2.2 performance shocks , 2.5" lift , progressive , rc , rc 2.5 , rcxtreme , rough country
rough country 4 inch lift kit mossman07 TJ Wrangler Technical Forum 89 03-11-2017 11:44 PM
4 inch rough country lift for $500? tonythehazelnut YJ Wrangler Technical Forum 18 12-27-2009 07:41 PM
OME or rough country 2.5 inch lift? erhenriques TJ Wrangler Technical Forum 13 11-11-2009 09:44 AM
Rough Country 4 inch X Lift 06tjSPORT TJ Wrangler Technical Forum 20 07-31-2009 07:29 PM
anyone got the Rough Country 4 inch lift?? hiram TJ Wrangler Technical Forum 14 03-08-2007 07:05 PM
