Rough Country 2.5 inch TJ lift kit. - Page 103 - JeepForum.com
post #1531 of 5128 Old 02-21-2009, 10:13 AM
BloodThirsty
Originally Posted by RCXTREME View Post
For the guys running the DC-1 wheels we also offer a bolt on ring for those wheels too.
Got a link to it?
BloodThirsty is offline
post #1532 of 5128 Old 02-21-2009, 10:17 AM
BloodThirsty
Originally Posted by timmyt View Post
235.00 each total was around 1,300ish.
i put the big one under the hood.
Pic?
10.......
post #1533 of 5128 Old 02-21-2009, 10:24 AM
timmyt
Originally Posted by BloodThirsty View Post
Pic?
10.......
it was dark when i got home last night. i'm working today so when i get off i'll snap some pics of the sticker and new tires
2006 LJ Rubicon. 2.5"RC BB/BL kit. 285/75/16 BFG KM2's on Moabs.
timmyt is offline
post #1534 of 5128 Old 02-21-2009, 12:16 PM Thread Starter
RCXTREME
Got a link to it?
They are not on the web. Here is the only pics I have on photobucket.
Not the best pis but gives you an idea.
800-222-7023
www.roughcountry.com
RCXTREME is offline
post #1535 of 5128 Old 02-21-2009, 12:42 PM
4U2NV
I have been watching your Ebay posting for the trim rings and was looking at buying a set... However the more I look at them the more I see thay take away from the look of the wheel plus I'm not sure i want to be taking the bolts on ad off. I don't want them to get stripped.
"A Boss says GO... A Leader says LET'S GO"
4U2NV is offline
post #1536 of 5128 Old 02-21-2009, 01:05 PM
BloodThirsty
So if I disconnect with these 32's and no BL I'm going to rub right? What is the smallest body lift I can get and not rub? I'm just VERY happy with the overall look right now.
post #1537 of 5128 Old 02-21-2009, 02:46 PM
crawlr
If I were you id just use the recommended bl 1.25". That’s what i have right now. I’m putting on 32x10.5x15 super swampers. I just bought the 2.5" rough country; ill put it on next weekend with my dad.
/l ,[____],
l---L –OlllllllO-
()_)-()_)-o-)_) 98 TJ (Crawlr) ax15trans,3.73gears,32/10.5/15 super swampers,2.5" coil lift,1"body lift,1"motor mount lift,lots of body armour
86 cj7 (havent figured out a name yet) 4" leaf lift,33/12.5/15 bfg at ko's,im getting him in the spring!!! i cant wait!!! ;)
crawlr is offline
post #1538 of 5128 Old 02-21-2009, 03:00 PM
fr0st_m0nkey
I just installed the 2.5 kit with steering stabilizer. I couldn't add the 1" coil spacers because the guy who put it on said I'd need control arms and a trackbar relocation bracket. I'll take pics tomorrow if it's not raining.
So now that I can't use these spacers, I think I'm going to add a 1.5" body lift if I can find one that size. If not then it's going to be a 2". I need the tires now though, if I throw the 33s on there now will I have to get a realignment after the body lift? I wouldn't think so but it can't hurt to ask.
White 2006 TJ X - 6 Speed - 4.0L i6 - 2.5" Rough Country - 33x12.5 Toyo Open Country M/Ts
fr0st_m0nkey is offline
post #1539 of 5128 Old 02-21-2009, 05:26 PM
timmyt
my lift is all done and got 285/75/16 bfg km2's
before
after
timmyt is offline
post #1540 of 5128 Old 02-21-2009, 06:33 PM
BloodThirsty
Looks great! I might throw my sticker under the hood as well.
Question for you guys on the post lift steering. I did not do the Steering Stab. After my lift the steering seems a little "floaty" if that makes sense to anyone. I do think I need a slight alignment cause it was a little off to begin with. Should I go ahead and try a new stab? Any other suggestions?
post #1541 of 5128 Old 02-21-2009, 06:46 PM
EZEC
2017 JK Wrangler
your guy is wrong.
rc sells a 1.25" bl which really is all you need for 33's.
EZEC is offline
post #1542 of 5128 Old 02-21-2009, 06:52 PM
razorback84
razorback84's Avatar
I have 33's on my 2.5 RC lift. I am also using their 1.25BL
06 TJ Sport
Build Thread
razorback84 is offline
post #1543 of 5128 Old 02-21-2009, 07:00 PM
mdcj7
Vendor
1981 CJ7
before
after
Do you have spacers on your wheels do the 285 rub when turning.
81 cj7 258 HEI, TBI fuel injected,Clifford header,4WDH 4" lift, 33" tires, T-177, D300, 4:10 gears, aussie lockers, Toyota axles, Longfield 30 spline chromoly superaxles
mdcj7 is offline
post #1544 of 5128 Old 02-21-2009, 07:20 PM
JEB74
I ordered the front and rear adjustable track bars from RC and am wondering if they will work correctly. I bought the bars because I didn't want to install the bracket, and want to do this right. I additionally purchased the RC BPE's and RC wheel spacers (cheaper than Spider Trax). I am planning on running 285/75/16's on my stock moabs. I kinda want to see if I can avoid having to install the BL or MML. I use my TJ as a DD.
JEB74 is offline
post #1545 of 5128 Old 02-21-2009, 07:23 PM
JONIG
looks good Brent!
Dave
JONIG is offline
Closed Thread
2.2 performance shocks , 2.5" lift , progressive , rc , rc 2.5 , rcxtreme , rough country
rough country 4 inch lift kit mossman07 TJ Wrangler Technical Forum 89 03-11-2017 11:44 PM
4 inch rough country lift for $500? tonythehazelnut YJ Wrangler Technical Forum 18 12-27-2009 07:41 PM
OME or rough country 2.5 inch lift? erhenriques TJ Wrangler Technical Forum 13 11-11-2009 09:44 AM
Rough Country 4 inch X Lift 06tjSPORT TJ Wrangler Technical Forum 20 07-31-2009 07:29 PM
anyone got the Rough Country 4 inch lift?? hiram TJ Wrangler Technical Forum 14 03-08-2007 07:05 PM
