rotor size - JeepForum.com
post #1 of 27 Old 04-02-2011, 12:42 PM Thread Starter
GOrton
rotor size
I need to change the front rotors on my 2002 jeep wrangler and apparently they come in two sizes. How do I determine the correct size of 82mm or 78mm? Any help would be appreciated.
GOrton is offline
post #2 of 27 Old 04-02-2011, 02:02 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
You have the 78mm versions.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #3 of 27 Old 04-02-2011, 04:12 PM
iceman1947
How about a 1999 Sahara?
iceman1947 is offline
post #4 of 27 Old 04-02-2011, 04:33 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
The 99 is the split year. It can have either the 78 or 82 mm versions and it's too bad the manufactures use the overall height dimension which can easily confuse folks.
Here is the only correct way to measure the rotors for the TJ front applications.
That number won't correspond to the 78 or 82mm meaurements but you will be able to identify the rotor correctly with the measurement you get.
If the measurement is 2.75" like the picture or 70mm, you have the later 2000 and up rotor.
If the measurement is 3.00" or 76mm, then you have the earlier 97-mid 99 rotor.
The reason the dimension is so confusing is if you have the earlier and taller composite rotors on a 99 and measure the overall height, it's really close to the same height as the later and shorter full cast rotor due to how thin the rotor hat is.
Since the only dimension between the two rotors that matters is how deep it is because the unitbearings are different heights, they need to be measured like the picture.
I am Savvy
mrblaine is offline
post #5 of 27 Old 04-02-2011, 04:54 PM Thread Starter
GOrton
Thanks, seeing how this is my only vehicle I didn't want to have to buy both to be sure, you saved me a trip and the hassle of a return.
GOrton is offline
post #6 of 27 Old 09-01-2012, 05:54 AM
Muddeprived
Muddeprived's Avatar
Is there a specific manufacturing date we can go by to determine which rotor we have? I got a coupon for $50 off a $100 order at advance and want to put the order through but I have no way to check the jeep's rotor size at this time.
2001 XJ Sport 4.5" LA
1999 TJ 2.5L 5spd 2" lift
Muddeprived is offline
post #7 of 27 Old 09-01-2012, 06:21 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Not that I have found. My 99 was built in 3/00 and has the taller rotors. I've worked on earlier ones that had the shorter ones.
If you pull a tire and take a picture of the rotor, I can likely identify it.
I am Savvy
mrblaine is offline
post #8 of 27 Old 09-01-2012, 08:36 AM
tj98
We went through this with my sons 99 a few months ago. His was built 12/98 and has the shorter rotors. Autozone uses the same part number for my 98 and his 99 for the Duralast rotors.
2000 and up fit just fine.
98 TJ - Sold
99 TJ - Mine
10 JKU - Sold
14 JK Unlimited - Wife's
tj98 is offline
post #9 of 27 Old 09-03-2012, 05:23 AM
Muddeprived
How do you identify which is which by looking? Taller or shorter hub center? Just curious....
post #10 of 27 Old 09-03-2012, 05:59 AM
Muddeprived
I went to where my jeep was and took it apart real quick. I found that I have the 2.75" hat rotors which are the later 2000 and up rotors BUT my hub center (that sticks out) measures 3/4" out. Isn't the 3/4" hub for the taller rotor? I thought I saw a picture of the two hubs and the difference was 3/4" and 1 1/8" or something like that.
If I'm right, the shop that did the work on this jeep (before i owned it) put the wrong rotors on. I am noticing some weird wear on the rotors. The outside of the rotor is worn evenly and smooth while the inside only is worn in the middle about an inch and the rest of it is untouched. Rotors and pads look pretty new.
So am I correct that I have pre-99 hubs but post-99 rotors?
post #11 of 27 Old 09-03-2012, 06:28 AM
tj98
We ran the old rotors on his for about five miles before removing them. Iirc the inside had a groove in it from where it made contact.
The rotor didn't sit straight either, where it hit pushed it out some.
Not sure about the measurements its been a few months.
98 TJ - Sold
99 TJ - Mine
10 JKU - Sold
tj98 is offline
post #12 of 27 Old 09-03-2012, 06:33 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
The two pilot dimensions are 7/16" and 3/4" with the shorter one being the early unitbearing.
I am Savvy
mrblaine is offline
post #13 of 27 Old 09-03-2012, 07:04 AM
Muddeprived
So the measurements of this pix are wrong?
post #14 of 27 Old 09-03-2012, 07:31 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Even though that is my picture, I didn't think to measure that part when I took it, it was merely taken to show the most important difference which is the height from the 3 bolt flange to the 5 bolt WMS flange.
When I re-wrote all the instructions for the Vanco kits, I did carefully measure the pilot height and referencing those shows them to be what I said above. There is a link to them on the Vanco site, page 4 of the 15" kit instructions.
I used a pair of known TJ unitbearings to take the measurements.
I am Savvy
mrblaine is offline
post #15 of 27 Old 09-03-2012, 08:09 AM
Muddeprived
So now it seems I do have the right hub/rotor combination but still gotta figure out the strange brake wear on the inside of the rotors. Hmm.....
brakes
Front Rotor Size? DutchmanAZ TJ Wrangler Technical Forum 26 03-13-2011 11:25 PM
7yr 35k Cap and Rotor pic JeffBowser TJ Wrangler Technical Forum 8 02-17-2011 06:35 PM
Rotor Lug Nut Hole Size justin_76 TJ Wrangler Technical Forum 4 02-09-2011 02:26 AM
Wrong Rotor Size Fix? efr523 TJ Wrangler Technical Forum 9 09-14-2009 07:47 PM
2000 SE Front Rotor Size als2000 TJ Wrangler Technical Forum 3 04-28-2006 04:17 PM
