Quantcast Rotella T 15W40 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Rotella T 15W40
FREE shipping on Rugged Ridge Soft tops @thejeephut.comGR8TOPS Introduces the Exogate HD Tire CarrierJcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!
Old 11-22-2009, 08:44 AM   #1
Bubba3200
Rotella T 15W40
Any thoughts on using it in a 05 4.0. What about Deleo 15W40 I think it is?
Bubba3200 is offline   Reply With Quote
Old 11-22-2009, 08:45 AM   #2
never monday
no problem
Get Savvy
never monday is offline   Reply With Quote
Old 11-22-2009, 08:46 AM   #3
Bubba3200
Benefits???
Old 11-22-2009, 08:49 AM   #4
never monday
suposedly it's better for flat tappet engines because it had ZDDP in it. The new "low emissions" formulas of Delo, Rotella and Delvac don't have ZDDP, IIRC. I use it by the galon, so it's handy.
Get Savvy
Old 11-22-2009, 08:58 AM   #5
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
Does it come in a little lower W rating as in 10W-40? If it has a higher zinc content, I'd be interested in running it in my 4.0L.
Gone to King of the Hammers, back Sunday!
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is online now   Reply With Quote
Old 11-22-2009, 09:02 AM   #6
robncar
Here's some info on Shell Rotella T Triple:
http://www.shell.com/home/Framework?siteId=rotella-en&FC2=/rotella-en/html/iwgen/leftnavs/zzz_lhn2_0_0.html&FC3=/rotella-en/html/iwgen/products/products_home.html
DON'T FEAR THE RE-GEAR!!!
______
|_____|
(O|||||||O)
|______|
[]===o==[]
RED JEEP CLUB MEMBER #430
robncar is offline   Reply With Quote
Old 11-22-2009, 09:02 AM   #7
never monday
30 w or 15w40 are the only ones i know of
Get Savvy
Old 11-22-2009, 09:15 AM   #8
Unlimited04
Unlimited04's Avatar
Even the diesel oils are cutting down on ZDDP, its all due to emissions regulations.
good readings:
The SAE publication from 1977 that started everyone thinking about ZDDP:
Cam and Lifter Wear as Affected By Engine Oil Zdp Concentration and Type
More:
Oils: What motor oil should I use? Which oil is best for my Porsche or aircooled engine?
http://www.andersonautomotiveenterprises.com/PDFs/techtips/new_oils_and_old_cars.pdf
GM also makes EOS (Engine Oil Supplement) to supplement ZDDP in all oils, which seems to be the recommended thing to achieve 1200-1400ppm. Look for 0.12% Zn on the oil bottle itself if possible tho.
Unlimited04 is offline   Reply With Quote
Old 11-22-2009, 09:42 AM   #9
Bubba3200
Valvoline high mileage oil good for the 4.0? I see in the high mileage oils there is some additive's that swell the seals etc. Any good amounts of zddp in these oils. There is so much read for the oils after a while it gets a little confusing. I know that most any oil will prevent engine failure but what is truely the best oil for the 4.0. I have tried a few different brands of oil and rotella 15W40.....the jeep just seems to like it the best so far. Had the dealership fix the rear main seal before it went out of warranty and I took a look at the oil pan and bottom of the engine and no signs of sludge or anything. Mechanic said it looked like it had 500 miles on it. 70,000 miles and running like a top and I would like to keep it that way for 200,000-300,000 miles. Thanks!
Old 11-22-2009, 09:54 AM   #10
Jerry Bransford
Absolutely. Valvoline is a top-top tier motor oil manufacturer, it's tough to beat. I run Valvoline myself, it's a highly recommended brand.
Getting Savvy...
Old 11-22-2009, 10:12 AM   #11
CTTJ
I was informed by a NAPA rep. that I've done buisiness with for the last 25 years that NAPA motor oils were in fact Valvoline Oil bottled in a different package.
This way Valvoline creates thier own compatition thus generating more revenue
Rust Never Sleeps
CTTJ is offline   Reply With Quote
Old 11-22-2009, 11:57 AM   #12
jondotcom
I ran delo in mine first oil change which coincided with lower mpg due to bigger tires and a lift.. so I've switched back to 10-30 for now but notice no mpg improvement. I will likely go back to delo or whatever 15w-40 heavy duty oil once I clear out my stock in 10w-30 I bought from wally world. As a side note, wally world sells the 5-qt packs of delo and others for ~9-10 bucks!
jondotcom is offline   Reply With Quote
Old 11-22-2009, 01:37 PM   #13
TJW909
TJW909's Avatar
I have been thinking about switching to 15W-40 I always have it around for the Ford 7.3. This summer after interstate driving in 95 degree heat with Valvoline 10W-30 in my oil psi was lower than I had ever seen before and really low at idle.
TJW909 is offline   Reply With Quote
Old 11-22-2009, 02:02 PM   #14
wushaw
Rockin jeep
wushaw's Avatar
Rotella 15-40 has worked fine for me for over 100k in my 4.0.
wushaw is offline   Reply With Quote
Old 11-23-2009, 01:02 PM   #15
aaonms
aaonms's Avatar
Rotella T 15W40 – that’s the non-synthetic one, correct?
There is a 5W-40 in synthetic.
Also, can’t comment on the conventional NAPA oil, but their synthetic is Valvoline-made.
aaonms is offline   Reply With Quote
Glock Forum
