Rookie Question About Lockers - JeepForum.com
post #1 of 3 Old 05-19-2004, 12:59 PM Thread Starter
cwbyup
I'm still new at this jeep thing and everything I learn is from this forum for the most part, so here is my new question. What are the lockers and what is their function?
1998 Black Wrangler Sport
John Deere Floormats
Set of 30 x 9 Dunlop Mud Rovers
4 Eagle One Off Road Lamps
CB
4' Wilson Antenna
-had not Firesticks in Stock:(
Sirius Sattelite Radio
Saving up for more toys
cwbyup is offline
post #2 of 3 Old 05-19-2004, 01:18 PM
DogHouse
DogHouse's Avatar
Lockers actually lock both sides of your axles so that both will spin wether you have one wheel in the air or not. Most 4 wheel drives don't come with lockers so you pretty much have a posi-trac style axle where the wheel with the least amount of tension will turn. Some people have fron and rear and some just have fron or just rear. It will help quite a bit in your offroad adventures. The only Jeep that comes stock with lockers is your Rubicon. Hope that helps.
DogHouse is offline
post #3 of 3 Old 05-19-2004, 01:21 PM
offthewall42
Can't say this will answer you question, but maybe it will help untill someone else can explain it. http://auto.howstuffworks.com/differential10.htm
offthewall42 is offline
rookie question dabrogger TJ Wrangler Technical Forum 7 05-14-2008 11:45 PM
Another rookie question Smitty06TJ TJ Wrangler Technical Forum 8 11-25-2006 09:41 AM
Just ordered my lockers....how long to install for a rookie kcphilaflyer TJ Wrangler Technical Forum 7 04-21-2006 05:22 AM
Rookie question Highlander357 TJ Wrangler Technical Forum 3 03-30-2005 02:49 PM
Rookie Question TJarrard TJ Wrangler Technical Forum 2 10-30-2003 10:30 PM
