roof rack (homemade) - JeepForum.com
post #1 of 9 Old 04-18-2011, 05:21 PM Thread Starter
mcb11695
hey Ive seen many homemade roof racks and im thinking about doing this. i searched for write ups. couldn't find any can someone please make one this would help me and give many people a great idea.
mcb11695 is offline
post #2 of 9 Old 04-18-2011, 05:34 PM
pdangerp
pdangerp's Avatar
search for junk yard rack. or explorer rack
pdangerp is offline
post #3 of 9 Old 04-18-2011, 07:31 PM
bigwahini
someone did a write up on using a Cherokee rack. Also you may check the thread by Jeff Sherb on his custom Safari roof. I think he used a Cherokee rack.
ifyoubegintothinkyou'relosingcontrol...it'salready gone
bigwahini is offline
post #4 of 9 Old 04-18-2011, 08:07 PM
rondak46
Top Five. Best TJ roof-rack. IMHO
Mine is off now and for sale.
rondak46 is offline
post #5 of 9 Old 04-18-2011, 08:37 PM
motojunkie
I got bored one weekend and made a rack/basket that attaches to my hardtop. It is definately light duty only, but seems to work well for tossing camp chairs/sunshade/tent/ect on the roof.
I can't remember the cost, but it was a pretty simple project.
Materials:
Rattle can for paint
a few 10' lengths of PVC pipe (I ended up with an extra one
8x 3 way corners (two directions are smooth fittings and the third was threaded)
6x T fittings
8x threaded corner pipe adapter things
PVC glue
foam pipe insulation
6x bolt/nut/washer combos
bag of pipe hangers
rubber washers/silicone
- Assembly was easy, measure how wide/long you want it and cut PVC to length. The nice thing is that you can assemble it and set it on the top to get a feel for it when it is all together. When you are happy, take it apart and glue it together with the pipe glue.
- When that dries, spray a couple coats of paint for some color.
- After it dries, set it on your hard top and tape off the points where you will drill the mounting holes. Then mark and drill for mounting. This is where my install got tricky. The pipe mounts were bigger than my pipe, meaning my rack would rattle and just be sloppy. I did a little creative bending/reshaping and added the insulation to the bottom of the rack which took up the extra space and added some protection between the rack and the hard top.
- Last step is bolting it down with the rubber washers on top to prevent any leaks. I was not successful my first go-round so I added some silicone and have been through some good rain since then without any leaks.
Pics after it was on the Jeep:
http://www.flickr.com/photos/54301619@N03/5633553792/
03 TJ sport, 4" Procomp lift running 33x10.50 BFG KM2's--09 dodge 6.7 cummins QC/SB 3500--08 Yamaha Nytro with a Boondocker Turbo
Air Force Jeep Club member #92
motojunkie is offline
post #6 of 9 Old 04-18-2011, 09:07 PM Thread Starter
mcb11695
yeah thats alll im looking for thanks motojunkie
mcb11695 is offline
post #7 of 9 Old 04-19-2011, 01:16 PM
motojunkie
Your welcome, glad I could help!
post #8 of 9 Old 03-13-2012, 12:13 PM
sabbathsdad
tj roof rack
I recently made a rack out of uni-strut and pipe clamps, which is all available at large chain hardware stores i.e. Lowes, home depot and the like. It works with a bikini top or topdown. which is all I needed. I can throw my kayak up there and no longer tug a trailer behind me...just an idea. I have a 99 tj and for the front bars I used 1 1/2" clamps and the back I used 2" clamps I cut a 10' stick of uni-strut in half and it fit perfectly.I then mounted the j-hooks for my yak. The front bar fits right in front of the speaker bar and the back bar I put right before the rollcage bends down. I tie the bow and stern to the bumpers. It works like a charm, and it cost less than $50 including primer and top coat.
sabbathsdad is offline
post #9 of 9 Old 03-13-2012, 01:45 PM
AKGeo
A PVC roof rack is just begging for failure. What good is a roof rack of that volume if you can't carry anything heavier than an action packer filled with pillows? Because you're going to have huge fatigue failures from the load (even secured) stressing the mounting points.
AND you mounted it directly to the hard top, without any support bracing?
Wow.
AKGeo is offline
ski rack options spare tire or roof rack Therou TJ Wrangler Technical Forum 17 01-04-2010 11:02 AM
Anybody have homemade mounts for Kargo Master roof rack? linexrandy TJ Wrangler Technical Forum 1 03-30-2009 01:58 PM
What is the better roof rack, Garvin Exp. Rack or Kargo Master Drew99 TJ Wrangler Technical Forum 6 03-17-2009 04:33 PM
Alternatives to roof rack or hitch rack waterboarder JK Wrangler Technical Forum 17 02-10-2008 05:58 PM
Homemade: Light bar, Rockers, Roof Rack tmwoodall TJ Wrangler Technical Forum 12 01-12-2007 04:35 PM
