Rolled TJ??? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Rolled TJ???
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.comBUMPERS by Rough Country! SOLD at ROCKRIDGE 4WD!! AWESOME
Unread 11-05-2004, 06:31 AM   #1
Baas
Rolled TJ???
Has anyone ever rolled a TJ? I mean flipped it all the way over the roof?
I am doing a trail this weekend that is notorious for roll overs – especially short wheel base vehicles.
I am thinking that the stock safety belt will not hold you in your seat and you will get a knock on the head.
Any one that have rolled over, survived and is coherent to answer this please tell me.
[FONT=Verdana]04 Sport
4" Currie lift with Anti-Rock
Rock Krawler 4 link rear
Skyjacker 2" body lift
Safari Snorkel
35" Procomp X-terrain
Mickey Thompson Classic lock
Aussie locker front & rear
4.88 gears
CV Drive shaft
4WD SYE
215 Ponies I6[/FONT]
Baas is offline   Reply With Quote
Unread 11-05-2004, 06:41 AM   #2
JeepKidd
Not in a TJ, but in a CJ. We were driving down the road at 45 and made a slight turn, the CJ rolled over sliding and sparking on the road. I was knocked out cold while the driver was punching me in my arm. The only injury was to me, scraped knuckels. It was...fun? (since im not dead and all)
[B][COLOR=Navy]Hurricane Jeep Club Member # 4[/COLOR]
[COLOR=DarkRed]Under 18 Jeep Club Member # 5[/COLOR]
[COLOR=DarkGreen]Green Jeep Club Member # 127[/COLOR][/B]
98 Green TJ
RE BB
Rubicon Springs
31X10.5 BFG A/Ts
15x8 AR-767
AtoZ Rocksliders
2 Hella 500 Driving Lighs
2 Delta Fog Lights
JeepKidd is offline   Reply With Quote
Unread 11-05-2004, 06:44 AM   #3
Wheelman
[SIZE=1][FONT=Tahoma][B][U]2006 Silverstone Nissan 350Z[/U][/B][/SIZE][SIZE=1][I][FONT=Century Gothic]
6 Speed|Bone Stock[/FONT][/FONT][/I][/SIZE]
Wheelman is offline   Reply With Quote
Unread 11-05-2004, 07:54 AM   #4
honaker
Baas,
Back in '85 I was driving a Toyota pick up truck when I was broadsided by a Ford Pinto. The truck flipped twice, buckling the cab down between the driver and passenger side. Seat belts saved our lives. I bought a CJ7 after that and felt safer! This last summer we had a jeeper in Colorado that rolled off Black Bear Pass, it was a long way down and seat belts were not an issue. Back in my kayaking days we had a rule of thumb for tackling tough water, we would scout the rapid on foot first and if you couldn't work up enough saliva to spit because it was too scary then you didn't do it. Go slow and keep your arms and legs inside. Post some pictures too!
'04 Unlimited
'99 Sport
honaker is offline   Reply With Quote
Unread 11-05-2004, 07:57 AM   #5
OlllOTJ
saw a yj roll all the way so all 4 tires were in the air. wasnt pretty the driver had some pretty serious adreneline going. wasnt somthing i would try to do or try to come close to. also if you do roll it's quite a recovery process and isnt as simple as firing it back up. good luck
1998 Jeep TJ SE,35x12.50. 15, 8.8, 4.88, Detroits
HacknTap SYE. Fabtech Rocker Protection.
OlllOTJ is offline   Reply With Quote
Unread 11-05-2004, 08:01 AM   #6
Wheelman
When a jeep rolls, assuming its not but a few feet, ie; not down a mountain or anything, does the rollbar usually holdup, or does it bend and total the jeep??
Unread 11-05-2004, 08:01 AM   #7
dakuda
Admin, Jeep in Pieces
dakuda's Avatar
I was at the badlands and a guy I was with rolled his TJ with a regular seatbelt. Flipped a few times, landed on his cage. The cage was a through-the-dash-bolt-to-the-floor variety. Cage survived, as did he. He was shaken up, but no worse for the wear.
Here are the pics, there is one of the middle of the roll.
Bill's Roll
They start at the bottom of that first page and go into most of the second for the aftermath.
You can do things the right way or the wrong way.
Or you can do it MY way...which is like the wrong way, only faster.
Ramsey Winches | My Gallery | www.dakuda.com
dakuda is offline   Reply With Quote
Unread 11-05-2004, 11:28 AM   #8
JeepCreepn01
$ It's Only Money $
JeepCreepn01's Avatar
my last jeep was a 93 yj i had the good luck of rolling on a jeep jamboree you know the safe 4wheeling. i rolled a onto my totally stock roll cage, all it did was crush the windsheild and bend the spreader bars the factory cage was totally fine after an hour of fender work i was able to drive it back to the trailer, but just to be safe on my new TJ i have a full weld in cage
JeepCreepn01 is offline   Reply With Quote
Unread 11-05-2004, 12:33 PM   #9
yurmom22
Here is a scary video of a TJ rolling (a few times) in MOAB...most of you have already seen this, but if you haven't, definitely check it out.
She doesn't have the stock roll bar and bumpers (all Toys By Troy) and not sure what kind of seatbelt...
http://www.toysbytroy.com/Page_Video.htm
'98 TJ I6 | 3.5" RE SF | 1" PA BL | 33" MT/R's | Borla Cat-back | FABTECH Bumper | Toys By Troy Rocker Guards
"I already made like infinity of those at scout camp." -Napoleon Dynamite
yurmom22 is offline   Reply With Quote
Unread 11-05-2004, 12:49 PM   #10
under_psi
go check out the toys by troy website....he has got some footage of a lady rolling backwards down a pretty serious rock climb....it will give you an idea of how a jeep will hold up with a few enhancements....
What's coming through is alive. What's holding up is a mirror. But what's singing songs is a snake looking to turn this piss to wine. They're both totally void of hate, but killing me just the same. The snake behind me hisses what my damage could have been. My blood before me begs meopen up my heart again. And I feel this coming over like a storm again. considerately. Venomous voice, tempts me, drains me, bleeds me, leaves me cracked and empty. Drags me down like some sweet gravity.
under_psi is offline   Reply With Quote
Unread 11-05-2004, 12:59 PM   #11
TJnTN
Here are a few pics from a cj rollover I saw last weekend. Check out the guys leg sticking out in the first pic and the roll cage in the next two. Yikes! He was ok though.
[COLOR=white][FONT=verdana]The American dream does not happen by asking Americans to accept what is immoral and wrong in the name of tolerance."
-- J.C. Watts[/FONT][/COLOR]
TJnTN is offline   Reply With Quote
Unread 11-05-2004, 02:10 PM   #12
Rommel
I remember seeing a video of a Jeep rolling over like 18 times and landing upright in a tree, and then the cut the branches, dropped the jeep down about six feet, and it actually started up.
I can't remember where I saw it though. Anybody know?
-Romm
"A dreamy horse! This is my 4th jeep since I first drive 12 years ago. I just drive jeep, always..." - Red Bull China
Rommel is offline   Reply With Quote
Unread 11-05-2004, 03:41 PM   #13
jsol95
buy one of these, they sell them off of ebay, in the event of a roll over, all you have to do is hit your switch, and it will roll you back over again.....and the best part, its only 6.50!!!
jsol95 is offline   Reply With Quote
Unread 11-05-2004, 03:55 PM   #14
James04TJ
Nice rockwells. I would be interested to see how the cage was constructed to allow that type of bending.
*2004 TJ (Mine)* 1984 CJ-7 Buggy Project (Mine)* 1977 CJ-7 (Hers)*2005 Nylint Crawler (The Kid's)
RedCell Motorsports
http://www.myspace.com/redcellmotorsports
James04TJ is offline   Reply With Quote
Unread 11-06-2004, 07:11 AM   #15
TJnTN
This was a steep climb and his brakes went out. In order not to go off the edge of this mountain he turned into the enbankment and flipped it. I know those axles weigh like 1000 lbs a piece.
