Roll Bar Padding on a 99 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Roll Bar Padding on a 99
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineNEW JK WRANGLER GRAB BARS NOW at ROCKRIDGE4WDROCKRIDGE4WD Introduces a NEW Jeep Wrangler JK *led* tail
Unread 03-01-2015, 05:36 PM   #1
iNate24
Whats up guys? Finally have a little extra cash to spend on my 99 Sport. I'm ordering a new top from Quadratec this week and I'm also looking to replace my roll bar covers/padding because they have faded. I was wondering if I could put thicker covers/padding on? I dont mind the skinny look of them right now but I prefer the thicker look. I have heard of people having to do some modification but it can work. Just looking for some feed back if anybody has done it! Also, I'm looking for some new fender flares. What are you guys opinions on getting them a bit wider than the stock ones?
iNate24 is offline   Reply With Quote Quick reply to this message
Unread 03-01-2015, 09:47 PM   #2
iNate24
Anybody??
Unread 03-01-2015, 10:33 PM   #3
JeepnBlake
The 03-06 roll bar padding is thicker (plastic spacer) than the earlier stuff. It isn't structurally stronger, just looks bigger.
Fender flare options vary far and wide, pun intended. Some folks like the stock look, others like the flat flare looks. Pick one or the other, or tube or metal fenders, and try to narrow it down from there.
-Blake-
Build Thread: http://www.jeepforum.com/forum/f22/j...thread-985907/
Dad's Build Thread: http://www.jeepforum.com/forum/f22/d...build-1474170/
OEM Fog Light Connectors, Conversions, and Extension Info:http://www.jeepforum.com/forum/f20/o...ngler-1008928/
JeepnBlake is offline   Reply With Quote Quick reply to this message
Unread 03-01-2015, 11:22 PM   #4
aagill225
I got the rugged ridge ones last summer. The fit was nice,Easy install. The only thing I didn't like we're the main hoop to the window frame. Very thin padding and both sides ripped. Other than that it was a fair price.
'99 WJ, 4.7L, completely bone stock, except for 245/65/16 tires
'76 Jeep Grand Waggy, 360cid Edle 660cfm/edle intake Quadratrac
'02 Exterra 3.3L, 5-spd, traded YJ for it :(
'89 YJ 2.5L, 5-spd, Borla header, dynomax super turbo muffler, Big-O XT 30x9.5r15
2004 Jeep Liberty Renagade 3.8L 2wd
'86 XJ 2.8L V6, 5-spd manual tranny (My 1st)
aagill225 is offline   Reply With Quote Quick reply to this message
Unread 03-02-2015, 08:20 AM   #5
JWebber
Pull off old covers and hand wash or machine wash zipped up. Then get a can of duplicolor fabric spray.
JWebber is offline   Reply With Quote Quick reply to this message
Unread 03-02-2015, 07:42 PM   #6
Bhoude
What's the biggest tire I can put on a stock rim. I have a 99 with 15" rims.
Bhoude is offline   Reply With Quote Quick reply to this message
Unread 03-02-2015, 11:28 PM   #7
Line58
Line58's Avatar
If you do this, DO NOT machine dry! My pad covers fell apart in the dryer. The duplicolor works great.
AX5 to YJ AX15 Swap
Line58 is offline   Reply With Quote Quick reply to this message
Unread 03-02-2015, 11:29 PM   #8
Line58
Line58's Avatar
It depends on what stock rim you have. If you don't know, I would recommend posting a picture of your wheel in a new thread. Welcome to the Forum.
AX5 to YJ AX15 Swap
Unread Yesterday, 06:42 AM   #9
NHfireLJ
Jeeper Creeper
NHfireLJ's Avatar
Or look here... http://www.jeepforum.com/forum/f9/st...1/#post4121478
LUCY...2005 Unlimited "LJ" Rubicon Sahara #495
BETTY...94 SE, Stroker 4.6, 4.5,lift,35"s,D30 Aussie, 8.8. Sold
Hummer Intake
http://www.jeepforum.com/forum/f12/h...style-1257285/
NHfireLJ is offline   Reply With Quote Quick reply to this message
