Rokmen vs. BDS Control Arms? - Page 4 - JeepForum.com
post #46 of 54 Old 09-08-2009, 10:30 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Originally Posted by 05RedRME View Post
If I were to get Rokmen arms with jj at each end, how would it ride on the street vs having the jj at only one end?
The JJ's would ride better.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #47 of 54 Old 09-09-2009, 08:15 AM
05RedRME
OK, thanks Blaine
05RedRME is offline
post #48 of 54 Old 09-10-2009, 10:25 PM
Deacon
Shining Adonis
Deacon's Avatar
Originally Posted by imped4now View Post
Ideally, you want to set your wheelbase so that, when stuffed, the tire is centered in the wheel well. Therefore, the rear needs to be a little forward and the front a little rearward when sitting neutral.
I'd like to learn more about this. Why is that the case, exactly? I mean, isn't that what happens automatically when you add a suspension lift on stock arms, where the wheelbase is sucked in so that it's less than stock? Why wouldn't you simply want to push the wheelbase out to stock? Or beyond stock for that matter?
I've got the Teraflex 3" lift, and I'd always assumed that the reason you go with long arms or otherwise adjustable short arms is to help push out the wheelbase as far as you can practically go in order to have a better highway ride and waterfall tackling ability, etc. But since I really don't know what's going on here, an education would be appreciated
Deacon is offline
post #49 of 54 Old 09-10-2009, 11:22 PM
Apex
Recon death squad
Apex's Avatar
I pushed mine about 1/2" past stock with my adjustable SA...am I in the wrong here?
Apex is offline
post #50 of 54 Old 07-23-2010, 03:42 AM
LKrux
i would say, as long as you have your drive train angles right..pinion yoke to driveshaft angle, etc..
or before the slip yoke falls out
4.0, 5sp, bfg33's, 3 1/2 lift
LKrux is offline
post #51 of 54 Old 07-23-2010, 06:17 AM
fowfiddy
when the suspension is at compression the arm comes up and therefore gets longer. this pushes the tire to the front of the wheelwell or the opposite for the rear and you will lose up travel
fowfiddy is offline
post #52 of 54 Old 07-23-2010, 07:25 AM
ekim
Originally Posted by lumpster View Post
Ive never heard of anyone bending or breaking a currie. Yeah i would agree that maybe the Rokmens are extra weight, but if you like to overbuild, then having that extra weight that much lower is better than running steel corner armor or steel tube fenders like a lot of people do.
I've bent a Currie lower. I bent it back in a press. Now, it seems to be more prone to bending. I've had to bend it back 2 or 3 more times since the initial bend. I'll probably replace it with something beefier at some point. I've only had a "problem" with the one arm and don't feel a need to go and replace the others - just the problematic one.
ekim is offline
post #53 of 54 Old 07-23-2010, 08:41 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
It's going to fail with the repeated bending. When Gerald gets back, give him a call and explain things to him and he may be able to help.
I am Savvy
mrblaine is offline
post #54 of 54 Old 07-23-2010, 08:47 AM
UncleWilson
UncleWilson's Avatar
The more times you bend it the weaker it will get. Try it with a paper clip. If you bend it a bunch of times it will break (also heats up-kinda cool). After you bend metal you need to do other manufacturing techniques to help it regain its material properties. I can't remember the term's and i'm not going to go find that book either. In the end when something bends it looses strength.
2006 LJ Rubi JKS BL/MML, Curries Arms, 3", UCF Skids, Riddler, 35 GY MTR W/K, Black Rock 909's, Black Magic, Rokmen Sliders, Savvy GTS, Cloaked, 4.88
o[__Q_]o
(OIIIIIO)
[]==O==[]
UncleWilson is offline
bds , control arms , currie , rokmen
JKS vs. ROKMEN vs. Currie vs. Rokkrawler control arms jmalys TJ Wrangler Technical Forum 125 08-02-2011 10:41 AM
rokmen or currie short arms pumpman55 TJ Wrangler Technical Forum 7 12-25-2009 11:03 AM
Fixed control arms>Stock control arms $lick TJ Wrangler Technical Forum 12 03-21-2009 04:08 PM
Rokmen vs Currie Adjustable Control Arms illinijeep TJ Wrangler Technical Forum 14 01-15-2009 07:33 PM
regular control arms vs. heim joint control arms. lucasinpsj TJ Wrangler Technical Forum 7 10-27-2004 02:35 AM
