rokmen tummy tuck now exhaust hits. - JeepForum.com
post #1 of 15 Old 07-25-2010, 11:06 AM Thread Starter
grnsporty
installed tummy tuck, very straightforward. nice skid to. Now the exhaust is hitting on the front passenger side upper control arm bracket. I have searched all over the forum and google and cant find anything on how people are getting the clearance. a writeup would be great. Ive tried bending the exhaust bracket with a big prybar but it wont budge. thanks in advance for the help.
grnsporty is offline
post #2 of 15 Old 07-25-2010, 11:19 AM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Relocate the cat hanger mount on the transmission bracket?...
Knuckelhead is offline
post #3 of 15 Old 07-25-2010, 05:07 PM Thread Starter
grnsporty
bump...trying to fix tonight. couldnt get the bracket to budge.
post #4 of 15 Old 07-25-2010, 05:18 PM
Knuckelhead
AFSOC Retired
You have to cut it off and reweld it...
post #5 of 15 Old 07-25-2010, 05:35 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
take a block of wood, BFH and pry bar and move the exhaust....mine used to hit...i bent it out of the way.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #6 of 15 Old 07-25-2010, 06:02 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Not sure what you were searching with, but whatever it was, it sucked.
http://www.jeepforum.com/forum/f9/ex...mount-1075109/
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #7 of 15 Old 07-25-2010, 06:05 PM
RubiconRazorbac
RubiconRazorbac's Avatar
Straight from the Rokmen website:
What about exhaust clearance near the upper passenger control arm?
This is common with all high clearance belly pans - Your jeep may require minor modification of the exhaust near the front passenger upper control arm for clearance. We have seen vehicles that have not required this, and ones that have. A quick trip to an exhaust shop after installation or sometimes just modification to the exhaust bracket (lowering it by 5/8") has provided the required clearance with no need for further modification.
Your shaft isn't long enough to handle that kind of droop...
2003 TJ Rubicon:
2017 JKU Rubicon:
RubiconRazorbac is offline
post #8 of 15 Old 07-25-2010, 07:34 PM
LGriffith
Call anyone at rokmen and they will be more than happy to explain several ways to fix you issue. I had the same problem with mine, and ended up just taking it to an exhaust shop for $60. Rokmen -- 303-907-6303
04 LJ|2.5" OME|RE arms|1" BL|ROKMEN|Savvy|33" MTZ's
LGriffith is offline
post #9 of 15 Old 07-25-2010, 08:02 PM Thread Starter
grnsporty
yea i was going to call them tomorrow when there open. I was not able to bend the bracket tonight. thanks for all the help
post #10 of 15 Old 03-13-2012, 02:29 PM
SKINUM
Where are you hitting the exhaust to move it over? The hanger at the transmision mount
I can pull the exhaust down and also towards the drivers side to make space. So, I know it should be an easy fix. The exhaust shop I went too didn't want to mess with cutting a small section out in front of the oil pan and rewelding. They were adamant that it wouldn't work which I disagreed with highly.
I'd actually like to avoid exhaust shops because they all want me to leave the jeep there for the day which isn't convenient at all for me.
SKINUM is offline
post #11 of 15 Old 03-13-2012, 03:20 PM
Imped
Imped's Avatar
Measure, cut, drill, reassemble.
You want to drop the exhaust the amount you raised it up so it's back to 'neutral.'
EDIT: Damnit Skinum, really? The thread is 2 years old.
OlllllllO
IndyORV
Imped is offline
post #12 of 15 Old 03-13-2012, 03:42 PM
SKINUM
Better then creating a new thread and you answered didn't you? Lol
SKINUM is offline
post #13 of 15 Old 03-17-2012, 07:05 PM
SKINUM
I just dropped the transfer case skid. Pulled the transmission mount bracket off then took a hammer and bent the bracket over towards the transmission . Then remounted everything and all is good.
SKINUM is offline
post #14 of 15 Old 03-17-2012, 07:20 PM
yellowismellow
Custom User Title
yellowismellow's Avatar
Cut the cat converter hanger in between he 2 hole. Line those 2 holes up and run a bolt and nut through the holes.
2006 TJ Sport
2004 WJ Special Edition
yellowismellow is offline
post #15 of 15 Old 03-17-2012, 08:02 PM
Keith_C
X2.
You can also enlarge the holes to 1/2" and use a 3/8" bolt to give a little fine adjustment.
Keith_C is offline
rokmen , tummy tuck , exhaust
Rokmen - Tummy Tuck for 97-02 Released ROKMEN TJ Wrangler Technical Forum 29 09-28-2009 05:55 PM
AEV Tummy Tuck outlawjosywales TJ Wrangler Technical Forum 6 03-20-2009 01:31 PM
Tummy Tuck Skid Exhaust Question J-Mox TJ Wrangler Technical Forum 7 07-17-2008 08:02 PM
tummy tuck, without tuck chadsmeltzer TJ Wrangler Technical Forum 26 01-28-2008 05:31 AM
tummy tuck/ exhaust 06flex TJ Wrangler Technical Forum 9 01-07-2008 07:55 PM
