-   TJ Wrangler Technical Forum (http://www.jeepforum.com/forum/f9/)
-   -   rokmen tummy tuck now exhaust hits. (http://www.jeepforum.com/forum/f9/rokmen-tummy-tuck-now-exhaust-hits-1076079/)
grnsporty 07-25-2010 11:06 AM
installed tummy tuck, very straightforward. nice skid to. Now the exhaust is hitting on the front passenger side upper control arm bracket. I have searched all over the forum and google and cant find anything on how people are getting the clearance. a writeup would be great. Ive tried bending the exhaust bracket with a big prybar but it wont budge. thanks in advance for the help.
Knuckelhead 07-25-2010 11:19 AM
Relocate the cat hanger mount on the transmission bracket?...
http://i42.photobucket.com/albums/e3...ad/kmount1.jpg
grnsporty 07-25-2010 05:07 PM
bump...trying to fix tonight. couldnt get the bracket to budge.
Knuckelhead 07-25-2010 05:18 PM
You have to cut it off and reweld it...
Unlimited04 07-25-2010 05:35 PM
take a block of wood, BFH and pry bar and move the exhaust....mine used to hit...i bent it out of the way.
mrblaine 07-25-2010 06:02 PM
Not sure what you were searching with, but whatever it was, it sucked.
http://www.jeepforum.com/forum/f9/ex...mount-1075109/
RubiconRazorbac 07-25-2010 06:05 PM
Straight from the Rokmen website:
What about exhaust clearance near the upper passenger control arm?
This is common with all high clearance belly pans - Your jeep may require minor modification of the exhaust near the front passenger upper control arm for clearance. We have seen vehicles that have not required this, and ones that have. A quick trip to an exhaust shop after installation or sometimes just modification to the exhaust bracket (lowering it by 5/8") has provided the required clearance with no need for further modification.
LGriffith 07-25-2010 07:34 PM
Call anyone at rokmen and they will be more than happy to explain several ways to fix you issue. I had the same problem with mine, and ended up just taking it to an exhaust shop for $60. Rokmen -- 303-907-6303
grnsporty 07-25-2010 08:02 PM
yea i was going to call them tomorrow when there open. I was not able to bend the bracket tonight. thanks for all the help
SKINUM 03-13-2012 02:29 PM
Where are you hitting the exhaust to move it over? The hanger at the transmision mount :confused:
I can pull the exhaust down and also towards the drivers side to make space. So, I know it should be an easy fix. The exhaust shop I went too didn't want to mess with cutting a small section out in front of the oil pan and rewelding. They were adamant that it wouldn't work which I disagreed with highly.
I'd actually like to avoid exhaust shops because they all want me to leave the jeep there for the day which isn't convenient at all for me.
Imped 03-13-2012 03:20 PM
Measure, cut, drill, reassemble.
http://i460.photobucket.com/albums/q...w/IMAG0065.jpg
You want to drop the exhaust the amount you raised it up so it's back to 'neutral.'
EDIT: Damnit Skinum, really? The thread is 2 years old.
SKINUM 03-13-2012 03:42 PM
Better then creating a new thread and you answered didn't you? Lol
SKINUM 03-17-2012 07:05 PM
I just dropped the transfer case skid. Pulled the transmission mount bracket off then took a hammer and bent the bracket over towards the transmission . Then remounted everything and all is good.
yellowismellow 03-17-2012 07:20 PM
Cut the cat converter hanger in between he 2 hole. Line those 2 holes up and run a bolt and nut through the holes.
Keith_C 03-17-2012 08:02 PM
X2.
You can also enlarge the holes to 1/2" and use a 3/8" bolt to give a little fine adjustment.
The time now is 05:55 AM.
