Rokmen - Tummy Tuck for 97-02 Released - JeepForum.com
post #1 of 30 Old 09-06-2009, 01:15 PM Thread Starter
ROKMEN
We bet many of you are are saying "It's About Time"....... But good products take time and testing. We wanted to make sure we made an optimized skid plate for the 97-02 TJ's - instead of a compromised 1 size fits all skid plate.
Think we did a pretty good job...
For more information:
http://www.jeepforum.com/forum/f43/r...ilable-852400/
Follow us on :
- When only the best will do!
ROKMEN is offline
post #2 of 30 Old 09-06-2009, 01:49 PM
-Rudy-
My jeep may see part of my enlistment bonus afterall...
04 WJ Limited 4.7/QD: 245/70R17 Firestone A/T + Trimming
-Rudy- is offline
post #3 of 30 Old 09-06-2009, 02:04 PM
PullMeSideways
PullMeSideways's Avatar
2010 JK Wrangler
Why did I buy that TeraFlex skid...UGH!
Great stuff guys. If I can sell mine I will be ordering yours!
2010 2dr Rubicon - Mango Tango!
Colorado Jeep Club Member #11
Former Jeeps:
2002 TJ Sahara, 2007 JK Unlimited Sahara, 2004 WJ & 1986 CJ-7
PullMeSideways is offline
post #4 of 30 Old 09-06-2009, 02:09 PM
tehub
So I would need to get a BL and MML along with the skid. I have a 2" lift, and they recommend a SYE and a CV driveshaft, but are they really necessary?
--Yellow '00 TJ 2.5L Auto, 2" Rusty's Lift, 31" Maxxis Buckshots--
tehub is offline
post #5 of 30 Old 09-06-2009, 02:10 PM
JeSimmers
JeSimmers's Avatar
This is great! Good job guys!
Red Jeep Club Member #454
JeSimmers is offline
post #6 of 30 Old 09-06-2009, 02:35 PM
Boodyrider
Depends. Can you live with broken rear DS U-joints every few days and constant vibration?
Yes, you will need an SYE and double cardan diriveshaft.
CV is something else entirely.
97 TJ Sport - 4.0/HP D30 w ARB/8.8 w LS/4.88s; 35s and flat fenders on 2.5 lift
84 CJ7; frame off restoration in progress.
The technical advice you get from me here is worth exactly what you paid me for it. Warranty issues will be reimbursed at double what you paid me for the advice.
Boodyrider is offline
post #7 of 30 Old 09-06-2009, 02:40 PM
prd_cdn
prd_cdn's Avatar
Just curious, how much of a height difference between the Stock and yours?
Could it also be fitted with LA for future lift mod?
Thanks !! Looks really good
prd_cdn is offline
post #8 of 30 Old 09-06-2009, 03:33 PM
tehub
Hmm, that about doubles the price of the upgrade. I'll probablly hold off.
tehub is offline
post #9 of 30 Old 09-06-2009, 03:35 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
nice!!! you guys make the best stuff
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #10 of 30 Old 09-06-2009, 03:41 PM
Imped
Imped's Avatar
It's common knowledge that tummy tucks require more than just the skid. Lifting the transfer case is the exact equivalent of lift. So, you have 2" of lift now and this gives approx. 2-2.5" over stock. So, that's around 4.5" of lift the driveshaft angles are seeing. Therefore, that calls for a SYE. When running a SYE, you must be able to point the pinion up at the t-case output, so that calls for a minimum of adj. rear uppers. No way around that at all. You will also need to either create space or do a 1" body lift and a 1" MML (not mandatory but recommended for driveline angles). The benefit of 2+" of extra belly clearance without any other suspension height change is massive and worth the costs. Wheel enough to get stuck on your belly a few times and you'll realize the benefit.
OlllllllO
IndyORV
Imped is offline
post #11 of 30 Old 09-06-2009, 04:11 PM
tehub
I'd like to do the upgrade, but I dont ahve all the money now. What would be the best way to start without buying everything at once? BL and MML?
tehub is offline
post #12 of 30 Old 09-06-2009, 04:27 PM
Pillswoj
Stage 1: Body lift and MML and adjustable uppers
Stage 2. SYE and Driveshaft
Stage 3. Tummy Tuck Skid Plate.
Friends don't let Friends run Bosch
Pillswoj is offline
post #13 of 30 Old 09-06-2009, 08:18 PM
never monday
how far below the frame?
Can we see more pics of the front and rear lip's?
never monday is offline
post #14 of 30 Old 09-06-2009, 08:39 PM
blackruby56
so I have a 2 inch bb which is temporary till mid winter and have ordered the tummy tuck for my 06 rubicon. I wasnt planning on buying a new drive shaft. Do you think i will have to? If so is that same drive shaft going to work for the same set-up with a 4 inch lift rather than my 2 inch in the future? It would also be important to say i have the jks motor mount lift installed.
blackruby56 is offline
post #15 of 30 Old 09-06-2009, 08:43 PM
phylodog
I'm basically interested in the same info. I would like to put one on my 05 Rubi and I have a 4" Full Traction short arm lift. What all would I need to do if I wanted to add this pan?
Edit: Just looked at the link on Romken's post and it says a 1" BL is required. I can live with that and was considering doing one anyway. Anything else?
phylodog is offline
Tummy Tuck on a YJ? KRenegade YJ Wrangler Technical Forum 22 12-31-2011 01:35 AM
Tummy Tuck AustinCJer TJ Wrangler Technical Forum 11 09-11-2009 04:53 AM
Tummy Tuck ?? tdog522 TJ Wrangler Technical Forum 5 10-29-2008 06:29 PM
tummy tuck, without tuck chadsmeltzer TJ Wrangler Technical Forum 26 01-28-2008 05:31 AM
Tummy Tuck..Whose to get? DFWCook TJ Wrangler Technical Forum 27 09-16-2006 02:09 PM
