#1 | ||
rocker panel..
2002 WJ Limited Quada-drive, 4.7 v8, stock everything else... Mods to be installed: UC coils, bilsteins, 31" kumhos, 08 wk wheels, tow hooks, rear addco swaybar |
#2 | |
IX, X, XIII, XIV, XL
Your gonna see a million different opinions on this subject, as it is a very popular topic of conversation. I went with the Shrockworks rock sliders, but there are other good ones as well...Rock-it Man, A to Z, etc...
-Bob '98 Black TJ Sport 4.0L/Auto Trans -(O|||||||O)- my rig: http://i9.photobucket.com/albums/a95/steelman_d/P1010315.jpg _____________________________________________ Quote:
Dare to dream! |
#3 |
i know but i want to get the jeepermans that mount to the frame, but im looking for something to cover the rocker panel below the door. i know im gonna end up drilling into it, i just like how the jeepermans look.
#4 |
About the only thing I can think of then if your not wanting a rocker such as Shrockworks etc...it a Posion Spyder Crusher corner which will more or less cover the area your talking about..but they are designed to work in conjunction with a rocker guard to cover the entire area...dont know if that helps.
#5 |
If I understand you correct, you want the functionality and convenience of the Jeeperman frame mounted skids, but the protection and look of the body rocker guards, right?
If so, then the Rubicon rocker guards might be okay for you as you are protected with the Jeeperman skids from serious damage. The Rubicon ones would protect and cover the rockers from scratches and such. Just don't expect them to protect for much more. Personally, I went with rocker guards with tube rails on them. They function as a step and as protection w/o mounting to the frame. If mounting height is an issue for you or your s/o, you could get those stirrup things (like what you use to get on a horse) and keep them up and out of the way when driving.
-Paul Green Jeep Member #155 Low Output 4 Cylinder Jeep Member #35 Keep moving forward. But keep an eye on history, for if you don't, you are doomed to repeat it. |
#6 | |
#7 |
anyone anyone?
#8 |
Im goin for A to Z within a few months, theyre nice. If you want to go with the jeepermans ill sell you my rubi guards
Semper Fi |
#9 | |
If so that is original older style Sahara trim from the factory. |
#10 |
If this is what you are looking for, I have a set of white guards that came off my 99 saraha. I'ld let them go cheap. If your interested, PM me
Peter
99 Sahara 4.0 6 Cyl Auto White 4.5RE ATLAS II & TW shaft, BFG 33's, Jeeperman Rear bumper tire carrier, Rokmen Rockers, Warn M8000 Powertrax no-slip in front & Rear |
#11 |
BD(Big Daddy Offroad),They are wide enough to function as mud/spray diverters/3/16 steel and can be used as steps,give great ground clearance and have close to the same pattern or look of the factory flares,,,,,,,,,,but they are not connected to the frame and the tub must be drilled. Works for me though ! 4WD is having a 10% off sale as we speak.
White 01 WJ (stock 4.7 limited) White 08 MK Patriot (minor mods) -SOLD- Looking for a White (ultralite?) project Jeep -FOUND- White 09 JK "X" |
| Thread Tools | |
| Thread | Thread Starter | Jeep Forums | Replies | Last Post |
| Rocker Panel Guards | digizure | YJ Technical Forum | 5 | 11-13-2009 09:31 PM |
| Step-on Rocker Panel | DeL2000 | TJ Technical Forum | 2 | 06-01-2009 11:03 AM |
| Rocker Panel | bidderking | TJ Technical Forum | 2 | 11-29-2008 07:51 PM |
| Opinions on this rocker panel set. | ChrisMan | TJ Technical Forum | 8 | 11-20-2006 09:11 PM |
| Hole in rocker panel ??? | MichiganTJ | TJ Technical Forum | 1 | 07-10-2002 12:57 PM |
The time now is 09:52 AM.
Jeep®, Wrangler, Cherokee, Grand Cherokee, and other models are copyrighted and trademarked to Jeep/Chrysler Corporation. JeepForum.com is not in any way associated with Jeep or the Chrysler Corp. |
