Rocker guard rehab - JeepForum.com
post #1 of 8 Old 09-18-2007, 08:31 AM Thread Starter
joo
Rocker guard rehab
We'll I picked up a set of AtoZ rocker guards last night, and now comes the process of rehabing them. They are a little bent up, which isn't a problem because I've got all the stuff I need to fix it. I talked to Zach this morning and got the sizes for bolts to be able to attach them.
Right now, just in the planning stages thinking about what I'm gonna do. Plan is that I'm going to bend them back straight and make sure they will fit right. I will then clean them up with a grinder and take all the scrapes and such out of them.
After that the descision is do I paint them, have them powerdercoated (I'm gonna guess around $100), or do I put some rhino lining or durabak (or the like) on it.
I personally am not a fan of the powerdercoating on the rocker guards because it's kind of expensive, and once it scratched it's very hard to touch up.
Looking for some feeling on these questions...
What have you guys done to your rockers? Have you rhino lined or put some sort of bed liner on them?
Did you just paint them when you got them new? How is the paint holding up?
If you bed linered them, how are they holding up?
Any thoughts or comments are greatly appreciated.
joo is offline
post #2 of 8 Old 09-18-2007, 08:38 AM
Rescue06
Rescue06's Avatar
I have been using the Dupli-color spray on truck bed coating in a spray paint can on my Warn sliders and both bumpers for about a year now and it still looks just as good as the day I put it on. Best part is when I do scrape it up I just mask off a little bit and hit it again and you cannot tell it was ever done. It is only like $7 a can and is found at most auto parts stores.
01 TJ , 04 WJ
Rescue06 is offline
post #3 of 8 Old 09-18-2007, 09:06 AM
ThUmPeRcOn
I think powdercoating sux! I have never had anything powdercoated that will not flake off and rust like mad in a short amount of time. Although I live in the rust belt and salt and wet =RUST... So I am looking at options as well. I just dropped the hitch off the back of the new jeep and the powdercoating just flaked right off...I wonder if the process of powdercoating causes moisture under the coating???hmmmmm? Anyhow I am looking to paint or??? this hitch soon so keep the ideas coming! p.s. I have some kind of rocker guards and it would appear that they were re-powdercoated and it's starting to bubble up so I am guessing a refinish on those as well... Hmmmm I wonder what line-x would charge to spray them rockers/hitch if I did all the prep work????
ThUmPeRcOn is offline
post #4 of 8 Old 09-18-2007, 09:21 AM
Chris @ GATR
Chris @ GATR's Avatar
I used 3M Undercoating on my A>Z Rockers. It works VERY well and can be touched up when scratched without knowing its been done.
Chris
Got ignorance? Please see below.
Originally Posted by kd4yor View Post
Chris, I just think your having buyers remorse for all the work in your 8.8 for no added gain (over the Dana 35).
Chris @ GATR is offline
post #5 of 8 Old 09-18-2007, 09:25 AM
ThUmPeRcOn
Does the coating leave a texture got any pics of your rockers?
post #6 of 8 Old 09-18-2007, 09:56 AM
Chris_
That non-slip spray paint stuff works good. I have it on my rocker guards, and my bumpers, and it has a good texture to it.
'02 TJ X Apex Edition
'00 XJ Sport
Chris_ is offline
post #7 of 8 Old 09-18-2007, 11:36 AM
175MM BULLDOG
175MM BULLDOG's Avatar
I Have the first set of rockers that Zach (A to Z Fab) made for the '05 Unlimiteds. They are flat black textured powder coated, and still look like new after 2.5 years. I live in New Jersey and the salt used on the roads has not affected them. If the powder coat ever scratches, I will touch it up with Rustolium flat black. No need to re powder coat.
Gun control: "The ability to hit your target"
175MM BULLDOG is offline
post #8 of 8 Old 09-18-2007, 12:45 PM
rubicon35
ive got my bumpers linexed and i would not do it again or on anything else. when it scrapes off in just a small place it just keeps peeling. if you dont plan on using them for what they are menat for go for the rhino or linex but if your gonna use them rattle can all the way, easy to touch up and you usually cant even tell afterwards
rubicon35 is offline
Rocker Guard and Front Bumper, Or Rocker Guard jkoffroadin JK Wrangler Technical Forum 14 08-25-2009 07:00 PM
Rocker Guard digizure YJ Wrangler Technical Forum 10 06-27-2009 09:23 PM
rocker guard help monkeychrist TJ Wrangler Technical Forum 4 08-25-2007 01:57 PM
Looking for a particular rocker guard Hanzo TJ Wrangler Technical Forum 6 06-28-2006 10:31 AM
Looks Of Plastic Rocker Vs. Real Rocker Guard jbpdog TJ Wrangler Technical Forum 12 06-01-2006 10:53 PM
