#1 | |
Rocker Guard advice
Its time for me to get a set. I'm looking for advice/opinions on what some of you guys are running, what you like and don't like about them, etc. Should I go with the tub only mounting or tub/body mount style? Any opinions/info is much appreciated.
Thanks
'98 TJ, G2 33 spl. D44, HP D30,ARBs,4.10s, RE 4.5 LA,33in Mickey Thompson MTZs w/Pro Comp 15x10 alloys,Smittybilt XRC8 w/Amsteel rope, LED tail lites, Rampage top Link to my Hemi build thread http://www.jeepforum.com/forum/f9/so-begins-5-7-hemi-conversion-1277803/ FOR SALE: 4.0 motor & TF999 trans, Premier Power Welder 195 amp,Fabtech Rockers PM me for details....... |
#2 |
Running Secretly Amok!
Tub/Body type! Do a search under rockers,or check out the review section! Lots of info.
#3 |
Try here, there great!http://www.genright.com/category.aspx?categoryID=143
#4 |
Some Call me RockDog
I have the A to Z Full rockers they are nice.
Stretched TJ Future, Coil overs, 40s, 60/14 bolt My Build Thread. www.kifourwheelers.com www.indyorv.com For Sale: TJ 44 Combo, 4.88s, detroit, Alloy USA shafts, Disc Brakes, HD lower mounts, Clayton tube Truss 35" procomp tires with Aluminum wheels $650 (4) 5x4.5 steel beadlocks $200 3 11"& 2 13" BBCS shocks Ford Dana 60 Rear $150 Big Daddy Offroad HD tie Rod (4) 15x8 5x4.5 TJ, YJ, XJ, etc bolt pattern Aluminum wheels $175 |
#5 |
x2
do a quick search on rockers , tons of info and pictures on this very question.
-my build thread- |
#6 |
dont have the money right now but when i do i will be getting either the a to z or shrockworks.
#7 |
I have the Smittybilt sliders. pretty good at a great price
#8 |
If you have a Sahara edition, do not get Rock Hard sliders. They are pretty well made and would be fine but I didnt realize when I ordered them that they are not tall enough to cover the rivets from the original Sahara rocker trim (even though northridge told me I would probably be fine after I called and asked
#9 |
98 XJ classic - 3" rustys springs, 2" tnt shackle and spacer, RK 3 link longarms, 33 x 12.5 BFG MT's, buncha other stuff. Totaled, will be missed 99 TJ Sahara - 3" FT economy lift, JKS disco's, 33 x 12.50 BFG MT's on silver D-windows, 1" BL/MML, smittybilt tire carrier |
#10 |
A to Z are good quality at a good price. Lots of coverage underneath.
gmb08 |
#11 |
why not go with the LoD sliders? make your stuff match
#12 |
A to Z for me . I have all the coverage i need. Plus, if you call Zach at A to Z and tell him you are a JF member he will give you a discount.
Everything i have done in my life that was worthwhile......i caught hell for ! |
#13 |
Sniper Fab FTW, customer service is great as well as all their products. plus you have lots of options (ie, tube step, no tube step, welded tube step, un welded tube step, custom anything)
"the guy who decided to use torx bits on jeeps should be severely beaten" |
#14 |
Wrangler
rockmen all the way...they are a lil more expensive but the quality is amazing. wheel well to wheel well coverage. hands done one of the best.
you can check out pics in my build the link is in my signature line
MY NEVER ENDING BUILD! http://www.jeepforum.com/forum/showthread.php?t=659464&highlight=jboy%27s+2000+bu ild |
#15 |
ARB has some nice one's too. I also agree with running body mounted sliders.
![]() I definitely want the extra outer bar too, for door protection.
DPG OFF-ROAD |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
