Rock Track Transfer Case In A 2000
| Spartan Lockers FREE SHIPPING Excellent Prices | Free Shipping on TIRES at KrawlOff-Road | Black Magic Brakes - 5% Off, No Minimum Purchase Required |
#1 | |
I have a 2000 TJ Sport nv3550 trans Dana 44 rear and a Rubicon 44 going in the front. I have a 1 inch body lift 1 inch mortor mount lift and soon to have a 4 inch suspension lift. Will a Rubicon 4:1 transfer case bolt right in as long as i get the shifter and the drive shafts? Will i need an aftermarket rear drive shaft? I was told they are alot biger will it fit now that I have a body lift? Will the spedo plug in can I switch spedo gears to correct for my 488 gears. Thanks for any info
#2 | |
2006 TJ Sport Red 6-speed; D30/D44 w/3.73; 33"x12.5 MTRs; Skid Row Engine/Steering Skids; AtoZ Rockers and Rear Bumper/Tire Carrier; Rockcrusher and T&J Diff Covers; 4WheelCustoms 2.25" BB; M.O.R.E 1" MML; PA 1" BL; Mike Green LCA Skids; Uniden Pro510XL w/2' Firestik; Husky Floor Liners Lone Star Jeep Club |
#3 |
Savvy Off Road
Speedo plug is the same. The dealer can adjust your speedo. The 4WD indicator plug is different. The shift linkage is slightly different. The 241 TC sits lower than the 231 so the stock trans skid will need minor modifications.
You will need a 1330 rear D44 pinion yoke or a combo 1310/1330 u-joint for the rear drive shaft. The 241 TC has a flat flange so you will need a new DS. The front Rubi drive shaft will work OK.
Email me for the fastest response: gman@savvyoffroad.com Follow us on Facebook FACEBOOK.COM/SAVVYOFFROAD The ONLY place to get Savvy/Currie Lifts and parts! The best price and support! PM MrBlaine for Black Magic Brakes! http://www.savvyoffroad.com 2006 LJ Unlimited Black Hole 2005 LJ Test Mule 2003 TJ Project Unrolled 2003 TJ Project Click Here |
#4 |
Just did the 241OR swap, in my 2000 TJ 4.0 auto, a couple of months ago. I also swapped both axles. I had no problem with clearance with the skid. The 97-98 and I'm not sure on 99, skids are different and need a slight mod, but the 2000 has room to spare. Well at least with the auto but I don't think there is a hugh length difference between auto and manual so you should be alright. The only problem I faced was the auto needs a long shaft input on the tcase and the 241OR is a short shaft. Used a teraflex seal extender to fix that. I don't think the manual has this problem. The speedo plugs right in. I already had a Superlift TruSpeed Speed Sensor Recalibrator installed when I went to bigger tires. I just had to adjust it to correct for new gears. The driveshafts will work as previously stated in the above post. Front will bolt right in. Another option with the rear is to take the rubi driveshaft and yours to a shop and have then make you one. I went ahead and got a TW's shaft to fix the problem and also get rid of my tcase drop. I haven't hooked up the engage sensor on top yet but it works the same as the 231, it's just two wires coming from a switch. I've been trying to find the rubi pigtail for it but may have to mod up a connection.
#5 |
You can get the 4wd switch pigtail for a rubi from the dealer. Part# 5161918-AA. It's like 13 bucks.
06 tj locked on 36's. |
#6 |
#7 |
Cut to Fit-Paint to Match
I just did this swap and the dealer where I got the speed sensor didn't get the bolt, even though when I called I was told that "all my parts were in." Can of you guys tell me the diameter, thread type or pitch, and length of the bolt that hold the speed sensor to the 241 t-case?
We save dogs: http://www.secondchanceshepherds.org/ |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
