11-02-2009, 01:42 PM
#1
Rock Krawler Steering help
So, I went to take apart my steering because I think the hole in the steering knuckle has bored itself out, and now am trying to remove the drag link from the bolt that goes through the knuckle and it won't come off... anyone have any ideas how to get it off? the drag is under the knuckle and the nut was removed so that's not in the way... I didn't install it myself but I didn't think there was anything else holding the joint in
2004 Black Rocky Mountain Edition, Clayton 4 Linked w/ 4" Pro Comp Springs, 37" Iroks (lost to TJ. RIP Krystal)
11-02-2009, 01:48 PM
#2
Are you saying you can't get the drag link out of the knuckle?
If so, give the knuckle a sharp rap on the end with a hammer. Don't hit the stud! Hit the knuckle where the stud goes through at a 90 degree angle to the stud. It may take a couple of solid whacks, but it should drop out.
My RHD TJ - Savvy equipped... And loving it! - Durty Rok Carolina Offroad
I drive on the right side, what's wrong with you?
Be very careful with the wife mod. Uninstallation can be extremely expensive. Wife mods have been known to take the Jeep and all other mods during the uninstall process. Also, make sure you service your wife mod properly as often as humanly possible. Wife mods not properly serviced may malfunction or uninstall themselves at any time.
11-02-2009, 01:51 PM
#3
Here's a pic...
Ignore the red and green arrows (they were for another purpose).
And ignore the fact that my drag link is on top.
Remove the nut and hit the knuckle where the purple arrow is...
11-02-2009, 01:59 PM
#4
Originally Posted by NotURMailman
Here's a pic...
X2. Make it ring like a dinner bell
11-02-2009, 02:12 PM
#5
how old is the kit? the new kits have a spacer that the drag link slides on to like this pictured below from my jeep
In a ZUK now....
11-02-2009, 02:16 PM
#6
OOPS... you can ignore my post if you have that type of steering with rod ends and a through bolt...
11-02-2009, 02:24 PM
#7
no such luck.... and it's a heim not a ball joint
11-02-2009, 02:25 PM
#8
yarmish that's what mine looks like, are you saying it slides completely over the spacer? i was banging on it and the bottom part fell off, but the drag link is still stuck
11-02-2009, 02:29 PM
#9
Yeah, oops. Good luck chandlerr!
11-02-2009, 02:37 PM
#10
Savvy Off Road
Got a picture? I'm trying to get a visual on your problem.
11-02-2009, 03:12 PM
#11
notice the angle of the bolt in the knuckle.... (the bolt moves around a lot and I think it is the source of my vibes)
11-02-2009, 04:59 PM
#12
did you do the install? i wonder if the used the wrong size drill bit? mine is as tight as can be. If you look at yours and mine and you can see that they are different. i wonder if yours is the older style? mine has a 2 piece spacer that slides in to the drag link. one on top and one on bottom. i would definitely give jeremy at Rockkrawler a call. he will help you out..maybe even send you the new style spacer
In a ZUK now....
11-02-2009, 05:41 PM
#13
no I didn't do the install, but I was there when he was installin it, he used the same bit on both sides, and the drivers side is tight
Any other ideas, cause it's still not coming off
11-02-2009, 05:46 PM
#14
i would put a tie rod puller on it and ease it off..i bet you have a bad heim joint
In a ZUK now....
11-03-2009, 10:18 AM
#15
How about using some PB Blaster on there....looks rusted pretty bad if ya ask me...
