Quantcast rock krawler steering - JeepForum.com
EGGERS BROS. INC YOUR JEEP SOURCE
CALL 1-800-274-2460
Competitive pricing!
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > rock krawler steering
Old 07-02-2007, 05:05 PM   #1
jeepgirl1272
ok, so i have finally gotten everything fixed on the jeep and i am ready to work on my steering now. i want to replace the whole system and i was looking at what would be the best system for on road stability. i use my jeep as a daily driver. the steering stability is very important but i dont want something that is gonna such off road either because i take it quite often. i'm running 38's so it needs to be strong. what do ya thing?
jeepgirl1272 is offline   Reply With Quote
Old 07-02-2007, 05:20 PM   #2
blacktjsport
I have the Currie system and it's very beefy and easy to install.
-Matt
~~2000 Black TJ Sport~~
-Parts list keeps growing...
blacktjsport is offline   Reply With Quote
Old 07-02-2007, 07:08 PM   #3
freedom5
-Matt
I too am running 38s and love the currie system.
freedom5 is offline   Reply With Quote
Old 07-02-2007, 07:09 PM   #4
jeepgirl1272
does it help solve the bumpsteer problems at interstate speeds? ive heard a lot of good things about the system
Old 07-02-2007, 07:12 PM   #5
blacktjsport
The bumpsteer is probably a result of your drag link and track bar being at different angles. If they are at different angles, you will have bumpsteer with MOST ANY steering system. It is just easier to keep the stock steering geometry and upgrade at the same time with the Currie system than the others. There are other choices, they just require a few more mods than the Currie system. HTH
-Matt
Old 07-02-2007, 07:15 PM   #6
freedom5
It feels tighter now with the system.
Old 07-02-2007, 07:17 PM   #7
jeepgirl1272
i have a trackbar relocation bracket, but still have yet to get an adj trackbar which im sure would help a ton. but... if i put the adj trackbar on, should i remove the relocation bracket? i know the trackbar and draglink are supposed to be close to parrallel like when stock right?
Old 07-02-2007, 07:30 PM   #8
PullMeSideways
2010 JK Wrangler
Yes the trackbar and drag link should be as close to parallel as possible.
In addition, when you put in an adjustable trackbar, you will want to remove your relocation bracket.
2010 2dr Rubicon - Mango Tango!
Colorado Jeep Club Member #11
Former Jeeps:
2002 TJ Sahara, 2007 JK Unlimited Sahara, 2004 WJ & 1986 CJ-7
PullMeSideways is offline   Reply With Quote
Old 07-02-2007, 10:07 PM   #9
Tumble
I recently spoke with Joe @ Absolute Offroad in Phoenix about upgrading my lift to an RK 5.5 and we started talking about steering systems. He mentioned that the RK steering system is VERY beefy but requires a lot of maintenance in order for it to work properly but the trade off is it's nearly indestuctible.
BTW - Joe is one of the largest RK dealers in the country.
HTH
Tumble is offline   Reply With Quote
Old 07-03-2007, 08:02 AM   #10
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
The RK steering system uses heim joints and solid stock.
98 TJ
Wheelin98TJ is offline   Reply With Quote
Glock Forum
