rock krawler long arm question - JeepForum.com
post #1 of 22 Old 09-25-2010, 08:03 PM Thread Starter
BLACKWOLF
I traded my 89 YJ for my 04 TJ it already had a lift on it which I was told is a rock krawler long arm lift, I was looking under the front of the jeep and saw some thing missing, it only has 3 long arms, 2 on one side and just one on the other, is this correct? or is a arm missing?
"IT'S HARD TO GET THE SMOKE BACK IN THE WIRES WHEN YOU LET IT OUT"
2004 TJ
2008 HARLEY ULTRA CLASSIC
2000 GMC TRUCK WITH 2003 VETT MOTOR
2 FORD RANGER'S AND 2010 FORD SPORTRAC
I'M CAR POOR!
SPEEDOMETER CAL FIX:
BLACKWOLF is offline
post #2 of 22 Old 09-25-2010, 08:18 PM
Oldjeepman
That would be a 3-link set up,two lowers and a drivers side upper should flex great
Oldjeepman is offline
post #3 of 22 Old 09-25-2010, 08:34 PM
VTJeePTJ
yep, looks like a rock krawler X factor long arm. Has a 3 link setup up front with two long lowers and one long upper on the driver's side along with a triangulated 4 link in the rear. It is a nice setup and is not supposed to have the arm on the pass. side.
2003 Jeep TJ- 4" Nth LA, 4.88/ARBs, Rubicrawler, 33's, Savvy Steering, Poison Spyder Armor, etc.
VTJeePTJ is offline
post #4 of 22 Old 09-25-2010, 08:36 PM
Climbit
someone stole your passenger upper link.
no really its not part of the kit.
its a semi 3-link.
Climbit is offline
post #5 of 22 Old 09-25-2010, 09:11 PM
WV-TJ
Does it look like something is wrong with the lower arm mount.
WV-TJ is offline
post #6 of 22 Old 09-25-2010, 09:21 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
It sure does!...
Knuckelhead is offline
post #7 of 22 Old 09-25-2010, 09:37 PM Thread Starter
BLACKWOLF
thanks for the info, I had a problem with the pan hard bar bushing, it came loose and gave some DW like I only saw once in a car i thought was gonna turn over but got that fixed and it seemed to have some vibration in it it did not have when I bought it, I think from what I have read I think its in the tire balance but now I know what a "three link" setup is.
2004 TJ
I'M CAR POOR!
post #8 of 22 Old 09-25-2010, 09:45 PM
Knuckelhead
AFSOC Retired
Have you looked at the lower control arm?...
post #9 of 22 Old 09-26-2010, 01:57 AM
conrasm
conrasm's Avatar
Might be from the arm flexing hard. He could loosen the jam nut and twist the link end to get it centered again.
Shawn
'00 TJ Sahara (RC 4" LA kit)
'06 Grand Cherokee Limited
'07 Ram 1500 quad cab
conrasm is offline
post #10 of 22 Old 09-26-2010, 02:14 AM Thread Starter
BLACKWOLF
I see it! looks like I might need another bushing and if its from flexing it twernt me as all I'v done so far is ride the dirt roads in the nat forest , have not even pulled the swaybar discos, I need to look at the other end of that and see if its twisted or not, I might need new bushings on both ends of the arm or a new arm. thanks
2004 TJ
I'M CAR POOR!
post #11 of 22 Old 09-26-2010, 05:55 AM
VTJeePTJ
It is normal and not an issue for the flex joint to be turned like that. The rock krawler joints have a higher degree of misalignment than most so the joint has a different "look" to it and the doesn't have as large of a housing as others (such as currie johnny joints or RE superflex), and thus, is more obvious to see when it is flexed. The joints are designed to move and flex but the axle position does not change because the thru-bolt center of the joint is what controls this, and it stays constant. If it drives you crazy, you should be able to just loosen the jam nut and use a pipe wrench or channel locks on the arm to square the joint back up in the mount and then re-torque the jam nut.
VTJeePTJ is offline
post #12 of 22 Old 09-26-2010, 08:17 AM
Knuckelhead
AFSOC Retired
That is not normal.
"The krawler links have the krawler joints at one end and urethane bushings at the other end to dampen vibration."
The one in the picture is the urethane bushing end...
post #13 of 22 Old 09-26-2010, 11:37 AM
VTJeePTJ
If we are talking about the axle end, that is the RK krawler joint (http://motionoffroad.com/catalog/ind...image&pID=1129). Every RK long arm I have ever seen in person runs the flex joint at the axle end and the bushing on the frame end. However, the pic in this link shows flex joints at both ends so mabye it was different depending on what generation kit you have.
Rock Krawler TJ Wrangler X-Factor Longarm Kit : Motion Offroad, Your Jeep Offroad Source!
If you are referring to the frame end, then you very well may have a point if it has a deformed urethane bushing. I am having a hard time making out that end in the pic. I am simply making the point that it is not unusual for a flex joint to be turned to one side or the other inside the CA mount.
VTJeePTJ is offline
post #14 of 22 Old 09-26-2010, 11:50 AM
jforse
Originally Posted by Knuckelhead View Post
That is not normal.
Wrong.
The Krawler joint is on the axle end. You can even see the retaining plate on the joint.
This happens to my short arms once in awhile. All you have to do is loosen the jam nut and twist the arm/joint back to center and tighten it up.
1997 TJ - Build in process.
2004 WJ Freedom Edition 4.7HO
jforse is offline
post #15 of 22 Old 09-26-2010, 11:53 AM
jforse
If we are talking about the axle end, that is the RK krawler joint (Rock Krawler Krawler Joint - 2.0 RHT (12mm) : Motion Offroad, Your Jeep Offroad Source!). Every RK long arm I have ever seen in person runs the flex joint at the axle end and the bushing on the frame end. However, the pic in this link shows flex joints at both ends so mabye it was different depending on what generation kit you have.
From what I can see from the picture it looks like he has a first gen three link kit. It also looks like he has a Krawler joint at the frame end too.
jforse is offline
Rock Krawler 5.5 long arm questions (3 link front no coilovers) badassjeep04 TJ Wrangler Technical Forum 7 12-02-2009 03:55 PM
rock krawler 4" x factor long arm installed happycamper TJ Wrangler Technical Forum 8 10-26-2007 09:27 PM
Rock Krawler long arm? ILLgreenjeep TJ Wrangler Technical Forum 1 03-03-2007 11:49 AM
Rock Krawler Long Arm Questions? mudmonkey2400 TJ Wrangler Technical Forum 25 11-16-2006 07:35 PM
Rock Krawler 5.5" Long Arm, anyone have one? Stricken TJ Wrangler Technical Forum 29 05-19-2004 09:43 AM
