Rock Jock 60 rear fluid capacity - JeepForum.com
post #1 of 10 Old 01-21-2012, 07:59 PM Thread Starter
RockMonster
Anybody know the fluid capacity in a Rock Jock with an ARB?
God... my spelling sux.... +++++++++++++++++++++++OIIIIO+++++++++++++++++++++ ++++
RockMonster is offline
post #2 of 10 Old 01-21-2012, 09:14 PM
dkrajcovic
fill it until it comes out the fill hole
dkrajcovic is offline
post #3 of 10 Old 01-21-2012, 10:12 PM
wushaw
Rockin jeep
wushaw's Avatar
Good question. Get 4 qts and fill it and more than likely you will have extra for future use.
wushaw is offline
post #4 of 10 Old 01-21-2012, 10:57 PM Thread Starter
RockMonster
it takes more fluid than that, i had it written down but seem to have misplaced the paper. I think it was 3.somthing... dam ill just call in the morning.
post #5 of 10 Old 01-21-2012, 11:03 PM Thread Starter
RockMonster
Its hard to just "fill it" because the optimal fluid level is between the 2 fill plugs
I got the numbers from currie when I first bought the axle.
post #6 of 10 Old 01-22-2012, 04:56 PM
wushaw
Rockin jeep
wushaw's Avatar
So if you put in a known quanity and get a pinion seal leak down the line somewhere do ya drain it and put back in a known quanity everytime ya get a little leak so you know its full?
wushaw is offline
post #7 of 10 Old 01-22-2012, 05:25 PM Thread Starter
RockMonster
Yep, it gets changed allot. not that big of a deal but i should just make a dipsick for it.
post #8 of 10 Old 01-22-2012, 06:35 PM
wushaw
Rockin jeep
wushaw's Avatar
That would be a good idea with it set-up that way.
wushaw is offline
post #9 of 10 Old 01-23-2012, 01:55 PM Thread Starter
RockMonster
so I called currie and the answer I got was about 3.75 quarts... that seemed a little much so I emaild them and the answer I got was 3 quarts.... maby they dont even know?
post #10 of 10 Old 01-23-2012, 02:01 PM
wushaw
Rockin jeep
wushaw's Avatar
LOL...that is funny
wushaw is offline
Rock Jock suspension anyone DYNOGUY JK Wrangler Technical Forum 5 11-13-2011 11:45 PM
Rock Jock 60- Air or Electric bklynsal TJ Wrangler Technical Forum 43 06-07-2011 11:59 PM
Rock Jock 60 by G2 bklynsal TJ Wrangler Technical Forum 12 11-28-2010 10:12 PM
G2 Rock Jock 60's 44thumper TJ Wrangler Technical Forum 25 07-21-2010 05:25 PM
Currie Rock Jock 60 on TJ TJeepPir TJ Wrangler Technical Forum 8 11-21-2004 08:15 AM
