rock crawling question. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > rock crawling question.
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineHMF Fabrication 50" Light Bar Mounts for CJ/YJ Made IDISCOUNT LOCKER and AXLE SHAFT Days Sales at Baseline 4x4
Unread 01-30-2007, 12:53 PM   #1
soronacrawler
For some reason every time when i start to crawl up the face of a rock, and im at very low rpms of course, i start to get this weird sound mixed with a lil shimmying that the jeep does before it begins to go up the rock.. i was wondering if anyone knows wat exactly is the problem.
im running stock gears, no locker, 33 mt's and a 5 inch lift....
soronacrawler is offline   Reply With Quote
Unread 01-30-2007, 12:59 PM   #2
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
Are you in 4Lo when doing your rock crawling? What axle ratio are you running with those 33" tires?
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote
Unread 01-30-2007, 01:01 PM   #3
soronacrawler
ya im in 4lo, and im running the stock gears that are fit for 30's.. im pretty sure its 3.73....
Unread 01-30-2007, 01:04 PM   #4
Jerry Bransford
Well, you're a bit undergeared for 33" tires and rock crawling with your 3.73 ratio so that bit of noise is probably just a tad of extra strain on everything. 4.56 would be ideal for your 33" tires if your TJ has a manual transmission.
Getting Savvy...
Unread 01-30-2007, 01:21 PM   #5
soronacrawler
yea thats wat i figured the problem was coming from... wtb new gears
now only if i knew how to put them in myself i could save tons
Unread 01-30-2007, 01:32 PM   #6
TJgreg
sounds like the vehicle is about to stall. more skinny pedal
(just a little bit)
Semper Fi
TJgreg is offline   Reply With Quote
Unread 01-30-2007, 01:40 PM   #7
soronacrawler
the thing is you cant give it much skinny pedal at all if your articulating up rocks..... so im guessing ill just have to deal with it until i get new gears or every rock crawlers dream an ATLAS
