Roaring grinding noise - JeepForum.com
 5Likes
  • 1 Post By JEK3
  • 1 Post By UnlimtedRubi06
  • 1 Post By JEK3
  • 1 Post By JEK3
  • 1 Post By JEK3
post #1 of 15 Old 08-18-2017, 11:17 PM Thread Starter
Clodhopper
06 TJ Rubicon has noise coming from drive train that sounds like forward of transmission. Through all gears but goes away when clutch is pushed in. 4.0, 5 speed manual (AX15) that replaced NSG 370 that died, 241OR transfer case. Any ideas?
Sent from my XT1254 using Tapatalk
Clodhopper is offline
post #2 of 15 Old 08-19-2017, 12:15 PM Thread Starter
Clodhopper
Ok, someone has to have an idea or suggestion here!
post #3 of 15 Old 08-19-2017, 02:35 PM
Poppy360
Poppy360's Avatar
Describe the noise...
Sent from my iPhone using Tapatalk
'98 TJ Sport 4.0L
RE 3.5" Long Arm w/ 1"BL; 35" KM2's; 8.8; HP30; 4.88's; Dual ARB's; Warn HS9500i; OME Shocks; CO2; Fully Armored; ORO U-Turn Steering; LoD Rear Bumper/Tire Carrier; Durango Steering Box; Heated Seats
Poppy360 is offline
post #4 of 15 Old 08-19-2017, 05:55 PM
JEK3
JEK3's Avatar
Noises underneath often sound like they're coming from a different spot than where they are actually coming from.
I had a "roaring grinding noise" not too long ago that was actually a failed u-joint in the double-cardan side of my rear driveshaft. This could be what you have (it could go away when you push in the clutch because you are taking all load off the driveline). My recommendation to you would be to remove your rear driveshaft, and drive around in front wheel drive (need to put it in 4Hi to do this) and see if the noise goes away.
Clodhopper likes this.
JEK3 is offline
post #5 of 15 Old 08-19-2017, 06:21 PM Thread Starter
Clodhopper
Kinda like a growl, goes away completely when I push in the clutch!
post #6 of 15 Old 08-19-2017, 06:23 PM Thread Starter
Clodhopper
Not real loud. By the way, have new clutch, throwout bearing, pilot bearing and trannie!
post #7 of 15 Old 08-19-2017, 06:24 PM
UnlimtedRubi06
Check driveshaft double Cardon joints.
Sent from my SM-G950U using Tapatalk
UnlimtedRubi06 is offline
post #8 of 15 Old 08-19-2017, 06:27 PM Thread Starter
Clodhopper
And front driveshaft is removed!
post #9 of 15 Old 08-19-2017, 08:57 PM Thread Starter
Clodhopper
Have a fairly new "Tom Woods" rear DS (less than 2k miles but I'll check it.....thanks!
post #10 of 15 Old 08-20-2017, 12:23 AM
JEK3
JEK3's Avatar
Can't hurt to rule out the easy things.
JEK3 is offline
post #11 of 15 Old 08-20-2017, 12:37 AM Thread Starter
Clodhopper
Yep, that one's easy and quick!
post #12 of 15 Old 08-20-2017, 02:17 PM
JEK3
JEK3's Avatar
Free, too! Except for a little time, that is.
JEK3 is offline
post #13 of 15 Old 08-20-2017, 10:17 PM Thread Starter
Clodhopper
Ta Daa! Centering ball on the double carden joint of the rear driveshaft! Felt kinda loose when I removed the shaft, drove it and it was quiet as a mouse (well, as quiet as my jeep is gonna get but no roaring/grinding noise)! Thanks guys (especially JEK3), now to fix it!
post #14 of 15 Old 08-21-2017, 06:05 AM
JEK3
JEK3's Avatar
Denny's Driveshaft sells kits with all the parts you need (Spicer brand) at reasonable prices.
JEK3 is offline
post #15 of 15 Old 08-22-2017, 01:13 PM
TJnBC
It is strange that is was the driveshaft, especially after this comment. The shaft spins even in neutral (or with clutch pressed). Must have only been doing it with a bit of load.
I would have suspected faulty Throwout bearing if noise goes away with Clutch pressed.
2006 LJR...the madness begins again
TJnBC is offline
