Ring & Pinion Reverse Rotation?? - JeepForum.com
post #1 of 8 Old 10-17-2010, 11:55 AM Thread Starter
0llll0
How do I tell if I need a reverse rotation ring and pinion?? I'm looking at Superior's 4.88 gears but I don't know how to tell which one to buy. Do I need the master install also? Not quite sure what all this means. Need help....
0llll0 is offline
post #2 of 8 Old 10-17-2010, 12:00 PM
Dogman
Dogman's Avatar
You would need RR gears in a high pinion axle. It looks like you have stock low pinion, so you need standard rotation.
John 3:17
Dogman is offline
post #3 of 8 Old 10-17-2010, 12:10 PM Thread Starter
0llll0
Right now I have the stock gears (3.07) with a dana 30 and 35.
0llll0 is offline
post #4 of 8 Old 10-17-2010, 12:17 PM
Dogman
Dogman's Avatar
I forgot in my first reply, but yes, you need master install kits which includes everything that you need for the install.
It would probably be best to purchase this stuff through the installer so they can't try to blame parts in a warranty situation.
John 3:17
Dogman is offline
post #5 of 8 Old 10-17-2010, 12:17 PM
flatlander757
You need standard cut gears... NOT reverse cut.
Low pinion = standard
High pinion = reverse cut.
Note that while some companies call them reverse "rotation" they are wrong... they don't actually rotate the opposite way... the teeth are cut with the spiraling out going the opposite way on the ring and pinion.
Look at this pic... the left is low pinion(standard cut), the right is high pinion(reverse cut):
SOLDThe lumbering steel-laden pig - 2003 TJ - 40" LTBs - D60/D70HD - 5.86s - Detroit lockers - 110" wheelbase
Originally Posted by 2006 Sport
Being able to make vroom vroom noises in Tonys Jeep was the highlight of my life.
Currently Jeepless.
flatlander757 is offline
post #6 of 8 Old 10-17-2010, 12:17 PM
otisdog
2008 WK
standard rotation.
Jim
08 Grand Cherokee Overland
otisdog is offline
post #7 of 8 Old 10-17-2010, 01:34 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
I called BS to the owner's face at a popular drivetrain company. I snidely pointed out that they don't rotate in reverse.
He stopped cold in his tracks, gave me a steely eyed glare and politely asked me how does the HP gear set work if you don't "REVERSE THE ROTATION OF THE WAY THE PINION TEETH SPIRAL AROUND THE HEAD?"
Fair enough, reverse rotation it is.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #8 of 8 Old 10-17-2010, 01:55 PM
BlueFlame
BlueFlame's Avatar
I've had 8 or 9 rigs regeared over the years, and among my friends we can claim probably 50-60.
It has been my experience that the very best way to go about regearing is get estimates from shops for what you want, all done. Call them up and say "how much to put 4.88s in both ends of my TJ?" Specify a brand of parts if you have a preference (I never have, I only deal with reputable shops and don't care what brand the gears are, never been a problem.)
I've always found it's harder to get a shop to install parts I carry in, plus they may have a familiarity with certain brands (and have extra parts like shims already on hand) plus they (should) get better pricing on the parts than you can and can pass some savings on to you if they are so inclined.
Few years ago I got a Yota regeared by a repuatable local shop for less than the on-line price of the parts! He wanted my business. I used the savings to install a rear Trutrac - the total was still less than the quote from the "most popular" shop in town for gears only!
(Before anyone asks, quote for 5.29s in both ends was $650 total, and with rear Truetrac came to $1100. The "popular shop" wanted $1200 for gears only and $1800 with Truetrac!)
That rig is still out there after 7 years now, no problems.
BlueFlame is offline
Dana 30 Reverse ring & pinion or not, which do I need? scuba5904 YJ Wrangler Technical Forum 12 05-11-2010 08:27 AM
standard or reverse rotation for the dana 30 jeepy-chan TJ Wrangler Technical Forum 2 04-16-2009 08:54 AM
JK X - Standard or Reverse Cut Rotation? Meir10 JK Wrangler Technical Forum 5 12-07-2007 09:35 AM
Reverse rotation ring and pinion divco13 TJ Wrangler Technical Forum 4 06-01-2007 09:57 AM
reverse rotation gears? copeland TJ Wrangler Technical Forum 5 06-06-2003 10:42 PM
