ring gear torque - JeepForum.com
post #1 of 32 Old 04-25-2013, 09:25 PM Thread Starter
snookhansel
ring gear torque
I recently started a re gear. I haven't even got far and already have questions. Here's what i got. Motive gear and usa standard master install kit. So I just bolted up my ring gear to my new carrier. Motive gear instructions state ring gear bolts to 55 to 60 flb's. So I set to 58. No biggie right. Well as I go digging through the rest of my parts I noticed a bag of bolts that must have come with my new carrier. These bolts are the same size and grade as my master install bolts. Right on the bag it says torque gear bolts to 75 to 85 flb's. 55 to 60 seems to be correct from research. Am I ok? Over thinking? Should I pull the bolts and replace and re torque using the other bolts?
snookhansel is offline
post #2 of 32 Old 04-25-2013, 09:31 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
which axle? follow the spicer or ford instructions, whatever the case may be.
ratmonkey is offline
post #3 of 32 Old 04-25-2013, 09:41 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
What size are the bolts?
Both 3/8 and 7/16 are used.
Wheelin98TJ is offline
post #4 of 32 Old 04-25-2013, 10:03 PM Thread Starter
snookhansel
3/8. The thing is both sets of bolts are the same size and grade. Only difference is one set came with the install kit and the other with the carrier.
post #5 of 32 Old 04-25-2013, 10:04 PM Thread Starter
snookhansel
Originally Posted by ratmonkey View Post
which axle? Follow the spicer or ford instructions, whatever the case may be.
d30
post #6 of 32 Old 04-25-2013, 10:30 PM
freeskier93
Did you apply red locktite?
Go by the specs given by the gear manufacturer, not the carrier. My gears are Nitro, their spec is 55 ft/lbs. That's what I did and they've been fine.
freeskier93 is offline
post #7 of 32 Old 04-25-2013, 11:59 PM
JohnnyWhitehead
2011 JK Wrangler
I just changed the ring and pinion in my Jeep today. The FSM said the D30 torque to 80 FT lbs and the D44 torque to 100 FT lbs.
GEAUX TIGERS!!!!
JohnnyWhitehead is offline
post #8 of 32 Old 04-26-2013, 12:07 AM
686keydragon
Agree... When I did my locker in my D30 the specs were to tighten the ring gear bolts to 80 ft lbs.
2002 TJ, 2.5L, 4" lift, 33" dunlop mud rovers, xrc8 winch, aussie locked d30, a-z fabrication ww2ww sliders, mounted mv-50 compressor, SirGcal sub box
686keydragon is offline
post #9 of 32 Old 04-26-2013, 05:16 AM Thread Starter
snookhansel
Yes on locktite. This seems like s logical answer.
post #10 of 32 Old 04-26-2013, 07:44 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Yep there are two sizes of ring gear bolts, only use the higher ft.lbs. figure with the larger size bolt. And DON'T FORGET the Locktite on the ring gear bolts!
Jerry Bransford is offline
post #11 of 32 Old 04-26-2013, 07:45 AM
rchase559
The FSM is wrong. Well I know atleast for the D44 it is. 100 lb-ft is way too much for the size of bolt used. There are people who have sheared them at less than that.
From what I've seen when looking through Spicer's information, 50 lb-ft is used for 3/8 and 75 lb-ft for 7/16.
rchase559 is offline
post #12 of 32 Old 04-26-2013, 07:55 AM
Jerry Bransford
Administrator
This is straight from the FSM
Dana 30
"Ring Gear Bolt . . . . . . .95-122 N-m (70-90 ft. lbs .)
Dana 44
"Bolts, Ring Gear. . . . . . . . . . . . 108 N-m (80 ft. lbs.)"
I think you probably misread the D44 spec.
post #13 of 32 Old 04-26-2013, 08:17 AM Thread Starter
snookhansel
I also cleaned bolts and holes with acetone before locktite and toeque was applied. I generally have a good feel when tightening bolts and wouldn't think these particular bolts would make it to 80.
post #14 of 32 Old 04-26-2013, 08:19 AM
rchase559
Dana 30
Dana 44
Jerry, I think some of the FSM are printed incorrectly. I've seen the torque specs he posted in them before. Either way its wrong and the bolts should not be tighten that much
post #15 of 32 Old 04-26-2013, 09:00 AM
ftgiles
Torque specs differ depending on the threads being wet or dry and wet with what.
ftgiles is offline
