Right tire rubs - Page 2 - JeepForum.com
post #16 of 25 Old 02-25-2013, 10:51 AM Thread Starter
crimsonjeeper
Could it just be that they messed up the backspacing?
crimsonjeeper is offline
post #17 of 25 Old 02-25-2013, 10:57 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
you haven't told us what wheels are on it, nor posted pics, or given us any other way to help you with that question.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #18 of 25 Old 02-25-2013, 11:44 AM
MrDubbe
The jeep probably needs a adj trackbar. I have a 2" lift and my axle is about a half inch pushed over on the driver side. At least with a adj trackbar both tires will probably rub
Love is like a fart if you push to hard it's probably shee-it!
MrDubbe is offline
post #19 of 25 Old 02-25-2013, 12:09 PM
Unlimited04
or even smash your diff or tie-rod!
Useful Write-Ups:
Funny:
post #20 of 25 Old 02-25-2013, 04:19 PM Thread Starter
crimsonjeeper
Alright they got it back from the shop an said it was the tie rod and they had it replaced and a wheel alignment, so I'm thinking good it should be good to go. I started the test drive and sure enough I turned it full lock right and it rubbed just like before. Still no rub on left. They tried to make it sound like it was normal for a jeep with oversize tires. Still, it is 255/75/r17 on 2 inch lift. It should work, right? I left with no jeep. I feel sad.
post #21 of 25 Old 02-25-2013, 04:33 PM
biffgnar
biffgnar's Avatar
What do they say was wrong with the tie rod? It was bent?
The answer is what we told you already. Axle is slightly off center from the lift. They either need to drill a new hole and move the stock track bar, install an adjustable trackbar or put a washer or two under the steering stops.
Romney in 2020!
biffgnar is offline
post #22 of 25 Old 02-25-2013, 04:59 PM
The_Dealer
2003 KJ Liberty
With only a 2" lift it shouldn't be that far off. Mine has never rubbed, even with 33x10.50's on just a bb
My build
http://www.jeepforum.com/forum/f22/the_dealers-soft-core-build-1476982/
The_Dealer is offline
post #23 of 25 Old 02-25-2013, 05:07 PM Thread Starter
crimsonjeeper
How much would that cost?
post #24 of 25 Old 02-25-2013, 05:29 PM
biffgnar
biffgnar's Avatar
Drilling a new hole = free
Washers on steering stops = maybe $1
Adjustable trackbar = $300 area
Romney in 2020!
biffgnar is offline
post #25 of 25 Old 02-25-2013, 07:13 PM
The_Dealer
2003 KJ Liberty
So use the tire rub problem as a negotiation. **** its a rubi. If it drives straight and doesn't chew up tires rock it, you have plenty of time to figure it out later. Upgrade a little at a time amd eventually it will be fixed
My build
damage , fender , rubbing , rubicon , tj
