Right tire rubs - JeepForum.com
post #1 of 25 Old 02-23-2013, 08:49 AM Thread Starter
crimsonjeeper
Right tire rubs
Hey y'all, I was looking at a 2004 rubicon to buy at a dealership, but while test driving, if you turn the wheel all the way one direction the right tire rubs. Why would it be just one size? Now the carfax shows the previous owner had an accident that damaged the right fender. It looks normal when looking at it, except the front bumper on that side bends forward a bit. How much would it cost to fix this and what exactly is it? Thanks
crimsonjeeper is offline
post #2 of 25 Old 02-23-2013, 08:50 AM
The_Dealer
2003 KJ Liberty
Is the steering wheel centered? Does the tie rod look bent
My build
http://www.jeepforum.com/forum/f22/the_dealers-soft-core-build-1476982/
The_Dealer is offline
post #3 of 25 Old 02-23-2013, 08:57 AM Thread Starter
crimsonjeeper
I'm not sure... I didn't notice the steering wheel not being straight. I'm going back today so ill definitely check that out and tge tie rod when I get there. Anything else I should look for? Thank you for a quick response
post #4 of 25 Old 02-23-2013, 12:52 PM
doclouie
Something is bent somewhere. I would not touch it unless you can find out what is bent or broken and then we can let you know what it will cost to fix.
2000 Sahara, 3.5" Rubicon Express Lift, 1" spring spacer & 1" Body Lift, 35" BFG Mud tires, Front & Rear ARB, Rancho 9000 shocks, UCF Ultra High Belly Up Skid.
doclouie is offline
post #5 of 25 Old 02-23-2013, 12:54 PM
biffgnar
biffgnar's Avatar
Is it lifted at all?
Romney in 2020!
biffgnar is online now
post #6 of 25 Old 02-23-2013, 02:10 PM
TheBoogieman
Disturbed
TheBoogieman's Avatar
Fenders are dirt cheap and Carfax never applies to Jeeps.I fix crap myself and Carfax doesn't show anything.
TheBoogieman is offline
post #7 of 25 Old 02-23-2013, 02:48 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Apparently in this case it does...
Knuckelhead is offline
post #8 of 25 Old 02-23-2013, 07:09 PM
The_Dealer
2003 KJ Liberty
I've had that happen on some ifs rigs after I replaced the tre's. I'm sure it could be possible on a sfa rig. Drivers re threaded in too far and pass side not enough. Find a like spot on both tires(way easier with street tires, I keep 2 on hand for driveway allignments) and see if there's more then 1/8" difference. Take the measurements in front, and behind the tire. Could just be an alignment problem, or a bent rim.
On a not so optimistic side, could be a bent axle, control arm or worse
My build
post #9 of 25 Old 02-24-2013, 08:33 AM
biffgnar
biffgnar's Avatar
It is not really the same on an SFA. Lateral axle location is determined primarily by the trackbar. Although lateral location of the axle is why I asked whether the jeep has been lifted at all. If it has and nothing was done to the track bar then the right front tire would be pulled closer to the frame and could potentially rub.
Romney in 2020!
post #10 of 25 Old 02-24-2013, 09:23 AM
TJDaveX
X2. OP, Answer the question!
TJDaveX is offline
post #11 of 25 Old 02-25-2013, 10:30 AM Thread Starter
crimsonjeeper
Ok I checked it out again, and it looks like it is rubbing the lower control arm, not the fender. Don't know how I missed that. They are paying to have whatever it is fixed at a front end shop. I will check it out after they fix it.
post #12 of 25 Old 02-25-2013, 10:32 AM Thread Starter
crimsonjeeper
Any ideas on what it is after that? I am obviously no expert. Is this something they can fix up and it be all good or is it a major ordeal?
post #13 of 25 Old 02-25-2013, 10:33 AM Thread Starter
crimsonjeeper
And to answer if it was lifted, they say it is 2 inches and the tires are a little over 32s.
post #14 of 25 Old 02-25-2013, 10:36 AM
biffgnar
biffgnar's Avatar
How wide are the tires? What rims are the tires on?
Sounds like front axle just not centered. They'll likely just redrill the hole and reuse the stock trackbar (v. adding an adjustable track bar) to move it over.
Or they may just put a few washers under the steering stops to slightly reduce the turning radius and tell you its fixed.
Romney in 2020!
post #15 of 25 Old 02-25-2013, 11:31 AM Thread Starter
crimsonjeeper
Ok, sounds good. I'm not sure the exact tire size. Either 275/75/r17 or 265/75r17 I believe. Not positive. Ill check today
damage , fender , rubbing , rubicon , tj
