Right rear wheel got hit- what to check for damage - JeepForum.com
post #1 of 6 Old 11-11-2007, 08:19 AM Thread Starter
Vacant Stare
My Jeep got hit on the right rear wheel last wedensday. An 82 year old man merging in to my lane from the right failed to notice the yield sign or my 4000 lb vehicle. It wasn't too hard a hit- I didn't spin out, but the wheel was destroyed and the tire went flat instantly. It looked like the axle might have been driven sideways.
Aside from control arm mounts and the trackbar mounts, what are some (perhaps hidden) things I should have checked out? Could the internals of the differential be damaged, for example? Wheel bearings?
Vacant Stare is offline
post #2 of 6 Old 11-11-2007, 08:24 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
If you have the 35, it's possible the crosspin could have taken a hit in the diff and bent slightly. Won't hurt much until you need to remove an axle and can't get the pin out.
If it was a 44, the bearings pressed onto the shaft up against a shoulder. The preload is built in so you would know if there was an issue pretty fast as the bearing would fail.
Other than that, you need to make sure the axle is still centered.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #3 of 6 Old 11-11-2007, 08:29 AM
Savvy
Vendor
Savvy's Avatar
2014 JK Wrangler
My 98 was hit like that and the upper control arm mount was nearly ripped off and the control arms (stock) were slightly mangled.
SAVVY OFF ROAD - Winner of the King of the Hammers Everyman Challenge FIVE years in a row!
Email me for the fastest response:
Like us on Facebook
The ONLY place to get Savvy/Currie Lifts and parts! The best price and support!
Now with Lifetime Guarantee
2003 TJ Project Unrolled
Savvy is offline
post #4 of 6 Old 11-11-2007, 08:32 AM Thread Starter
Vacant Stare
Did you have it fixed?
post #5 of 6 Old 11-20-2007, 07:36 AM Thread Starter
Vacant Stare
well, I was pretty lucky I guess. The guy managed to hit just my wheel- no damage to the body on either side of the wheel opening. I expected the axle trackbar mount to be tweaked, but it's fine.
Part of me was hoping the damage was more extensive so I could use it as an excuse to install the long arm kit I was trying to sell at the time. I had painted my steelies to match the body, but I'm out of that paint, so instead I'm thinking about painting a big bullseye on the replacement cragar soft 8 his insurance company is buying me
post #6 of 6 Old 11-20-2007, 11:57 AM
Jerky bump
Better make sure the axle tube isn't bent, too.
Jerky bump is offline
Jeep got hit.(Again) how to check for damage GRN_BEAST95 Wrangler General Discussion 5 02-28-2010 11:53 AM
Rear end damage TheBoogieman TJ Wrangler Technical Forum 13 01-27-2010 06:36 PM
How to Repair Rear Damage 97 TJ tornik550 TJ Wrangler Technical Forum 9 11-18-2009 06:06 AM
What to check for in a side impact to rear wheel? STW TJ Wrangler Technical Forum 1 12-08-2007 04:51 PM
