Right rear tire extends Ĺ inch farther out than left after 2 inch lift. - JeepForum.com
post #1 of 10 Old 06-28-2006, 01:01 PM Thread Starter
blang158
I have a 2006 Wrangler X to which I added a 2Ē Skyjacker lift right after I drove it off the lot. Iím no heavy mechanic- this is my third Jeep but the first I have modified much- the lift appeared to go well, projected time was 6 hours per the directions and it took me 8 hours. During the lift I replaced the stock wheels with 32x11.50 Goodrich ATs on 15x8 Outlaw Iís, which extend the tires beyond the stock fender flare. When completed, I noticed that the right rear tire extends about Ĺ inch farther out than the other tires. Given the heaviness of the transverse member connecting the frame to the rear end, I cannot figure out how this could have been caused by something I did during the lift. I never noticed it with the stock tires which donít extend past the flares. I swapped with the spare and it showed the same thing, so its not the rims/tires. I measured distances-to-frame and thereís about Ĺ inch difference between outer rear axle components and their respective side frame. The Jeep tracks fine on a straightway and the rear driveshaft doesnít appear to have an angle on it. The bottom of the righthand coilspring does look like itís a bit skewed outward. Any ideas? Do I just live with it? And did I violate every warranty in the book by lifting a brand new Jeep, which would prevent me from bringing it to the dealership?
blang158 is offline
post #2 of 10 Old 06-28-2006, 01:04 PM
Dukes69
Dukes69's Avatar
buy an ajustable track bar, install and adjust as needed.
AIM: Dukes69
Ya Savvy?
Dukes69 is offline
post #3 of 10 Old 06-28-2006, 01:05 PM
thejafe
thejafe's Avatar
This is normal when lifting a Jeep. You need either an adjustable rear track bar or this bracket to re-center your axle:
http://www.rubiconexpress.com/dynami...p?folderid=196
thejafe is offline
post #4 of 10 Old 06-28-2006, 01:11 PM
Divinitous
Disgruntled Jeepforum'er
Divinitous's Avatar
they show that bracket to be for 3-4.5" lift. I'd just splurge on an adjustable rear trackbar.
-Ryan
Google Voice (or the number Grape calls when drunk): 845-476-8182
Originally Posted by Enzo Ferrari
"The Jeep is Americas only real sports car!"
Originally Posted by MrBlaine
"Jeeps do not make jeepers, jeepers make Jeeps."
Divinitous is offline
post #5 of 10 Old 06-28-2006, 01:12 PM
Border Dave
Got Sand?
Border Dave's Avatar
As long as your tires aren't making contact with your spring perches, just leave it alone.
Border Dave is offline
post #6 of 10 Old 06-28-2006, 01:39 PM
mdm
Farm Wheeler
The right end of the rear track bar is attached to the frame and the left end is attached to the axle. When you raise the frame this makes the track bar pull the axle to the right. The same thing happens on the front except in the opposite direction. (Did I just say all this backwards? Long day.)
The small amount you are off-center is acceptable to many. If it is bothering you, the suggestions referring to a relocation bracket or an adjustable track bar will fix it for you.
mdm is offline
post #7 of 10 Old 06-28-2006, 02:04 PM
thejafe
thejafe's Avatar
woops, sorry 'bout that... then you need the OME bracket:
http://www.quadratec.com/products/16090_100.htm
Might not be a bad idea to go with the adjustable rear trackbar instead considering that installing the relocation bracket is a PITA.
thejafe is offline
post #8 of 10 Old 06-28-2006, 02:06 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Its much easier to just weld that bracket on if you take that route.
Wheelin98TJ is offline
post #9 of 10 Old 06-28-2006, 02:45 PM
Border Dave
Got Sand?
Until you realize that the bracket causes more problems than it solves and want to take it back off.
post #10 of 10 Old 07-05-2006, 01:15 PM Thread Starter
blang158
Thanks to all who replied- installed adjustable rear track bar this weekend- no problems- misalignment solved.
blang158 is offline
1 inch body lift, 3/4 inch front spacer, 33's? vanner77 JK Wrangler Technical Forum 5 08-17-2009 03:38 PM
4 inch Suspension Lift 2 inch body = Slip Yoke/Driveshaft? ECUSAE20 TJ Wrangler Technical Forum 11 05-08-2009 11:12 PM
2003 rubicon: 1 inch body lift and 2 inch coil spacer lift. tire size? Bobski TJ Wrangler Technical Forum 6 10-05-2008 07:38 PM
Procomp 4 inch front 2 inch rear lift enigma5300 JK Wrangler Technical Forum 2 07-26-2007 08:48 PM
(help) One rear wheel extends out farther than the other woodb TJ Wrangler Technical Forum 4 03-12-2007 06:45 PM
