Right Hand Drive TJ Build Thread - Page 8 - JeepForum.com
post #106 of 463 Old 10-30-2009, 11:04 AM Thread Starter
NotURMailman
I'll try to get you some good pics this weekend. For now I'm going to trim the snot out of the pocket flares. If I go with tube flares later I'll most likely just make them.
equipped... And loving it!
I drive on the right side, what's wrong with you?
It's difficult to take you seriously. It's like you're an easily perturbed autistic teenager who's drunk typing the whole time.
NotURMailman is offline
post #107 of 463 Old 11-02-2009, 08:12 AM Thread Starter
NotURMailman
Hardly got to touch her this weekend. I did get to modify the front frame end track bar bracket. I did some quick geometry calculations and found that the frame end of my track bar was 1 3/4" inches too high with the steering on top of the knuckles. The modified bracket is quite possible one of the ugliest things I have ever seen, but I have no doubts it will hold up. My only concern is the leverage on it from it being so long. I may end up making some sort of support across to the opposite side frame rail, but I will most likely wait to do that until I take the time to remove the spring and shock on the side so I can cut the whole brakcet assembly off of the frame and start from scratch. The tarck bar bracket is going to be 1/2 - 3/4" from the sway bar link bracket, and I am not 100% convinced that it won't contact the axle tube under full suspension compression on that side. I will have to investiaget that futher after I get the new sway bar link brackets welded on.
post #108 of 463 Old 12-02-2009, 02:42 PM
EvilM0nkey
EvilM0nkey's Avatar
Holy crap! Is this even the same Jeep?
Looks good!
EvilM0nkey is offline
post #109 of 463 Old 12-04-2009, 04:55 AM Thread Starter
NotURMailman
Thanks Ross! Her maiden voyage will be this weekend. She's on the trailer outside of my office now just waiting for me to get off work and head to Uwharrie. They're calling for some nasty weather so it should be a good way to break her in.
I trimmed the snot out of the flares to keep the tire from ripping them off during stuff. I'll get some pictures up when I can. Hopefully I'll have some good wheeling pics when I get back!
post #110 of 463 Old 12-07-2009, 05:33 AM Thread Starter
NotURMailman
She did great at URE! Had to winch up the first ledge on the back side of Daniel (it was slick and nasty from all of the rain, and I ddin't pick the best line). Didn't like no sway bar and 6psi of tire pressure on the off camber stuff, my butt chewed on my seat fabric too much! I'm thinking daul rate Sway Lok, not decided yet... suggestions?
post #111 of 463 Old 12-08-2009, 05:11 AM Thread Starter
NotURMailman
Here are the few shots we got. Including the goofball poser shots (couldn't resist).
UREDec09_1.jpg   UREDec09_2.jpg   UREDec09_DR.jpg   UREDec09_pos1.jpg   UREDec09_pos2.JPG
post #112 of 463 Old 12-08-2009, 05:11 AM Thread Starter
NotURMailman
And the rest...
post #113 of 463 Old 12-08-2009, 06:47 AM
cmoore
cmoore's Avatar
looks good mang.
98 XJ:4.0, AW4, HP30/8.25 4.56 Spartan/LSD, alloy shafts & joints, HD steer, SYE/CV, skids, RADesigns gated shifter, RE mix n match lift, 35"mt/rs, THOR guards F&R, weld-in custom rockers & stiffeners, custom front bumper, orfab rear bumper, THOR cowl induction, on board air, on board welder, etc
cmoore is offline
post #114 of 463 Old 12-08-2009, 02:40 PM Thread Starter
NotURMailman
Originally Posted by cmoore View Post
looks good mang.
Thanks!
post #115 of 463 Old 12-11-2009, 08:02 PM
EvilM0nkey
EvilM0nkey's Avatar
I see you decided to throw on a hard top and doors this time!
Big difference in the performance too!
post #116 of 463 Old 01-14-2010, 07:01 PM
Dwatts5250
1997 XJ Cherokee
I just saw a Yellow hardtop Right hand driver TJ on a used car lot $14,999 for it. Im tempted to get it, but how hard is it to drive on the streets, being that you are sitting opposite of "norm"?
"A veteran is someone who, at one point in his life wrote a blank check made payable to 'The United States of America' for an amount of up to and including my life. That is Honor, and there are way too many people in this country who no longer understand it."
Dwatts5250 is offline
post #117 of 463 Old 01-15-2010, 04:45 AM Thread Starter
NotURMailman
That all depends on you, it doesn't bother me at all. In fact I like it better. That seems alfully high on the price though! I got mine for $10,000 out the door and the woman that had it before me never even took the plastic film off of the carpet, it was the cleanest 50,000 mile vehicle I've ever seen...
post #118 of 463 Old 01-15-2010, 04:47 AM Thread Starter
NotURMailman
Wow! Looking at those photos side by side really puts it into perspective...
post #119 of 463 Old 01-15-2010, 05:20 AM
cmoore
cmoore's Avatar
One might say the difference is day and night. Jeep looks good bro . What's next?
cmoore is offline
post #120 of 463 Old 01-24-2010, 06:20 PM Thread Starter
NotURMailman
Got my tail lights off, license plate off, gas filler neck mount off, flares off, and inner fender liners out. Then I got the holes drilled and nutserts installed (thanks Gerald!) and the corners primed and painted. Now I just need the paint to dry and I'll have Savvy corners and tail lights finally installed!
Right Hand Drive YJ berndog89 YJ Wrangler Technical Forum 12 10-01-2009 05:49 AM
08 Right Hand Drive JK RIOGRANDE JK Wrangler Technical Forum 18 09-09-2009 11:32 PM
Right Hand Drive ErniBigb JK Wrangler Technical Forum 20 01-26-2008 08:00 AM
right hand drive jk available in 08 brundz JK Wrangler Technical Forum 9 07-07-2007 02:14 PM
Right Hand Drive? tomw JK Wrangler Technical Forum 2 07-04-2006 06:03 PM
