#91 | |
MAIL Crawler.
are both of your knuckles reverse tapered? are those inserts in them? then you probably got my old knuckles. i am running rustys steering conversion on top of my knuckles and used some goferit off road inserts. is the "shelf" pretty mangled on both knuckles? then, ya, those used to be mine.
*98 RHD TJ: swapped 4.0L/AX-15/Dana 300, 4.88, AEV 3", LP9"/S88, Grizzly/Detroit, OTK steering, 35" muds... 84:1. *85 CJ-7: GM350/NV4500/D300, SOA on Wags, LP44/9", Aussies, 37" MT/Rs, Staun beadlocks, hi-steer, 110:1... in pieces. NEW and USED parts for sale. PM me. |
#92 | |
Straight Up Fool!
Yes, both are reversed tapered. No, they aren't your old knuckles. They are the original knuckles. Blaine did the reverse tapers for me. I wouldn't know about the pad contact slide, as Van has machined them to take his 15" brake kit.
My RHD TJ - Savvy equipped... And loving it! - Durty Rok Carolina Offroad I drive on the right side, what's wrong with you? Quote:
#93 | |
Straight Up Fool!
![]() ![]() ![]() That's all...
#94 | |
Straight Up Fool!
Got a pressent from brown santa yesterday...
#95 | |
Straight Up Fool!
I was out in the shop Friday night until about 9:30. I put some bend in the drag link to reduce that horrible angle on the tie rod end at the passenger side knuckle. Then I got the sway bas link brackets on the alxe fabbed up and welded on.
Here is a really bad side view of it on the axle (I keep taking pics while the paint is still wet... DOH!) ![]() And here is a slightly better shot from the front. I hope they don't hit the spring under flex. ![]() And here are a few before they were on the axle. I notched the corner of the angle out and set the mounting ear in so I could weld it front and back. ![]() ![]() ![]()
#96 | |
Straight Up Fool!
I went back out Saturday from around 10:00am to 8:30pm.
I went to put the brakes on and... hey the rotors don't fit the hub. So I called Van and he asked didn't I read the directions. I said I would have if they had sent me any. He e-mailed it them to me on the spot and gave me his cell phone number incase I had any more problems.I fogot to mention that Friday night I also fabbed up my super short sway bar links, only to find out they were way to hard to connect and disconnect. So I deciede to fix that next. I ended up with a combonation of the new style one piece links that are pinned to the axle brackets and the old style three piece style links. The top uses the old style with the end pinned into a tube and the bottom is pinned to the axle bracket. This way I disconnect the top and then it's easy to pull the bottom off of the pin and store inside the Jeep. I just have to fab up the brackets to clip the tops to to keep the sway bar up while off road. Sorry I didn't take a single picture on Saturday... (I'll try to remedy that later)
#97 | |
Straight Up Fool!
On Sunday I woke up hacking and sneezing. I went oput to the shop for about thirty minutes and decided it wouldn't do me any good to stay out there in the cold and get seriously sick. It's supposed to warm up a lot this week. I got a lot done and I am very close....
#98 | |
Straight Up Fool!
Almost forgot... tha mailman brought me my Savvy tail lights on Saturday. they look freaking great! I can't wait to get them on!
#99 | |
Straight Up Fool!
The front suspension of this thing has got to be one of the most crowded systems I've ever seen! I still have to figure out where to fab up the axle end steering stabiliser bracket. I'm starrting to think I would have been better off building my own triangulated four or three link with coil overs...
#100 | |
Straight Up Fool!
Last night:
set the toe in to 1/8" centered the steering wheel centered the axles under the Jeep fabbed up some brackets and welded them to the coil towers to secure the sway bar when disconnected So close now! ![]()
#101 |
nice build! very jelious of the vanco and savvy gear. did you figure out what to do about your rear shocks contacting your spring perches? i just grinded mine down and flipped the shocks around so the thicker side was on bottom.
99 XJ Sport - 3" lift, 31 BFG At's -DD 94 XJ Sport - 5" Lift, Locked on Swampers and beaten I Just dropped in to see what condition my condition was in... |
#102 | |
Straight Up Fool!
Thanks!
I have inverted shocks, mounting the body down would have made it much worse and the shocks weren't designed to run that way. I installed some shock mount extensions and ground the pee out of the spring perches. I still haven't actually installed any of the Savvy stuff, but I'm itching to get it on. I was really wanting to have the corners powder coated and was going to hold off installing them until I had. But it looks like funding for that is way off, so I may just rattle can them and put them on. Touch up would be a snap, and it's not like I have to worry about rust if they get scratched or chipped.
#103 | |
Straight Up Fool!
Last night I torqued every bolt on the front end, mounted my steering stabilizer -
...Let me tell you that was a PITA. There isn't any more room for one more thing in that front suspension. I've never seen such a crowded mess in my life. I ended up mounting it, realizing it was going to snap a grease fitting off of my drag link, and mounting it again. I'm going to be a bit anxious until I can get it up here to work and flex the front out with a fork lift to see if eveythinr can move without parts crashing into each other... - ,connected the front brake hoses to the hard lines, and blead the brakes. I'm sure I did something else, but let's be honest, who cares? Tonight I am going to check every thing over really good, grease the front end, mount my other front tire assembly, and take her for a short test cruise! I'll still have a few things to do: corners, tail lights, roll cage, bed liner, safety harnesses, and the last two bead locks. But, I'll just be glad to be able to drive her again!
#104 | |
Straight Up Fool!
I finally got her rolling! There's still a lot of work to do, but I'm so glad to be able to drive her. Those flares are going to have to go. The tires will have them ripped clean off in short order. I'll have to make or buy some front tube fenders and rear tube flares. I'll most likely go ahead and trim those in the mean time.
#105 |
MAIL Crawler.
up close pics of your crowded front end requested.
might want to check out these tube flares. they are about as cheap as they come.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
