Right Hand Drive TJ Build Thread - Page 27 - JeepForum.com
post #391 of 463 Old 03-05-2012, 06:56 AM Thread Starter
NotURMailman
NotURMailman's Avatar
Do the ecteds at least still function as LSDs?
They appear to, that is why I believe the magnets have either failed or broken, but the coils are not open, they read a small amount of resistance (less than one ohm). I am not sure what they should read, and they could be shorted and not creating a magnetic field. However, they are not dead shorted to ground, as they have not blown the fuses. It could still be worn clutches that are working to a point but allowing slippage. I know I was mired down in nastiness on the last trip and locked front and rear and only got one tire on each axle to spin. I was not in a bad bind on any rocks or anything, just in some slop.
equipped... And loving it!
I drive on the right side, what's wrong with you?
It's difficult to take you seriously. It's like you're an easily perturbed autistic teenager who's drunk typing the whole time.
NotURMailman is offline
post #392 of 463 Old 03-05-2012, 06:58 AM Thread Starter
NotURMailman
Still not totally decided on what direction to go if I ditch the Ecteds. I may go Detroit rear and ARB front... decisions, decisions....
post #393 of 463 Old 03-05-2012, 07:01 AM Thread Starter
NotURMailman
That sucks! I had surgery 5 months back and have to do it again in 2 days.I'll have to take off another 6 weeks from work to recover.I hope they get it right this time. Good luck!
Thanks. Finally know what the cause is. Genetic abnomally. Looks like blood thinners for life. Which promises to be fun, since after helping install some Metal Cloak fenders this weeken I cam home covered in bruises.
post #394 of 463 Old 03-05-2012, 07:12 AM
TheBoogieman
Disturbed
TheBoogieman's Avatar
At least you know the cause.My 17 year old (at the time)neighbor inherited a similar problem from his mother.He avoided getting into fist or knife fights.He's around 38 now and doing well.Just be careful with getting cuts on those blood thinners.
TheBoogieman is offline
post #395 of 463 Old 03-05-2012, 07:41 AM Thread Starter
NotURMailman
E-mailed Auburn support and got an out-of-office auto reply. That doesn't inspire confidence, then again I suppose everyone needs vacation time, but you would think they would have more than one person handling support e-mails.
post #396 of 463 Old 03-05-2012, 10:40 AM Thread Starter
NotURMailman
Hey... someone (cough...cough...Blaine). If I build the HP30 I'm gona go ahead and go to coil overs. Possible to get 6" uptrale and 6" downtravel in the front with 35s without going sky high at stock axle width? And any recomendations on spring rates and valving? I have done tons of research, but would like t hear input from someone who has been there and done that!
So, really anyone who has gone this route.
FYI - I have a 1.25" BL and have my eye on the aluminum PSC DeFenders with 3" flares.
post #397 of 463 Old 03-06-2012, 09:26 AM Thread Starter
NotURMailman
Still no response from Auburn... not looking good there. Oh well, guess I'll start on the HP 30 and plan on an ARB.
post #398 of 463 Old 03-08-2012, 08:46 AM Thread Starter
NotURMailman
I think I may ditch the HP30 and build an HP44.
post #399 of 463 Old 03-23-2012, 09:39 PM
TJRHD
How are things with you? How is the locker situation going?
NOT A HATER
TJRHD is offline
post #400 of 463 Old 03-29-2012, 09:21 AM Thread Starter
NotURMailman
No replies from Auburn via phone or e-mail. looks like I'll plan to build a new front axle and re-do the rear with ARBs.
post #401 of 463 Old 03-31-2012, 04:47 PM Thread Starter
NotURMailman
Finaly got the winch all buttoned up with the hoop, lights, new fairlead, and synthetic Viking line.
Now I just need to get the new compressor swapped in for the old burnt our QuikAir.
post #402 of 463 Old 06-25-2012, 02:58 PM Thread Starter
NotURMailman
Haven't been on the Jeep much. Got a lot of other projects going, and work keeps me on the road a lot. But, I did decide on an eLocker in front and an ARB in the rear (going to stick with the LP30 for now). Got the eLocker in yesterday, the rear will have to wait while I put some funding into other things. The install went pretty smooth for the most part. But, if I ever go into the front axle again... it is coming out from under the Jeep! Trying to put the diff in place and use a case spreader while laying on my side under the Jeep is not worth it.
I was a tad aggravated with the fact that the D30 eLocker uses a non standard bearing, which is not included with the locker. At least ARB has the decency to supply the bearing since they are not standard parts.
I settled on the eLocker for the front due to the fact that the collar type engagement on the D30 units is reportedly very strong and reliable. The pin style used in the D44 does not seem to be as such, therefor I will be using an ARB in the rear.
Other than that the only mods have been rearranging the front fenders with a rock face at Coal Creek, flattening my RR shock into a "D" shape, and folding the tailpipe around the rear axle tube.
I'm not going to spend money replacing the shocks in their current configuration. After this trip I will install Currie rear spring with corrected factory upper spring buckets, and outboarded 12" Fox shocks. At the same time I may or may not re-engineer the rear arms and link mounts.
Also decided on the Corbeau Baja JP seats, I'll get them eventually.
The longer I spend doing things other than working on the Jeep, the longer my wishlist of parts gets...
post #403 of 463 Old 04-24-2013, 02:33 PM Thread Starter
NotURMailman
The front end is basically done. I just need to install the 7/16 nutserts in the spring pads for the Currie bump stops and bolt everything together.
Custom tie rod fabbed. Shock mounts welded in (upper and lower).
Reserviors mounted.
Anti-rock installed.
Currie springs and bump stops ready to go in.
I have everything I need for a factory rear disc brake conversion sitting on my couch, including bearing retainer plates and Wizard caliper flip brackets.
My new Corbeau Baja JP seats are sitting at the warehouse waiting for me to pick them up.
The black Rock Monster wheels and Poison Spyder hood panel are in route.
I refuse to touch anything else until I get the front end buttoned up and break in the new Black Magic pads in the front.
It WILL be ready with seats and rear disc brakes by July for a trip to Coal Creek!
Jeez... I have my work cut out for me!
Oh, and I need to finish moving the front turn signals to the grille as well as replace the tailpipe and soft top frame.
post #404 of 463 Old 06-24-2013, 06:13 AM Thread Starter
NotURMailman
Ok, so the front suspension is all buttoned up and dialed in. Without the springs I can cycle either side or both sides of the front axle from full droop to full bump with no binding. I have 5 1/4" of up-travel from ride height, that may decrease slightly when the springs settle. I feel it is pretty well balanced with the 11" travel shocks. I currently have the AntiRock at the next to last hole. I may adjust it from there if I feel it is needed. It is technically driveable once I put the front tires back on.
I didn't put the tires on because I really want the tires on the RockMonsters before I bolt them back up.
I can't wait to drive it with the decent springs and shocks that are properly matched up front. It will certainly be a different experience.
I still have the new suspension seats, the PSI hood panel, the rear disc brake conversion kit, and quite a few little things to do. But, none of that is required to drive it or wheel it.
I'm afraid the battery may be shot, I haven't had any luck charging it so far. I'm giving it one last try and then I will just go buy a Die Hard platinum and move on.
I can't post pictures from work, but I will try to remember to get some up from home.
post #405 of 463 Old 06-24-2013, 10:19 AM Thread Starter
NotURMailman
Almost forgot, I got a mil sirplus H1 intake bonnet so I can get rid of the ARB tree magnet snorkel.
And I got a pair of JKS mini skids for the LCA brackets that I need to weld on.
Right Hand Drive YJ berndog89 YJ Wrangler Technical Forum 12 10-01-2009 05:49 AM
08 Right Hand Drive JK RIOGRANDE JK Wrangler Technical Forum 18 09-09-2009 11:32 PM
Right Hand Drive ErniBigb JK Wrangler Technical Forum 20 01-26-2008 08:00 AM
right hand drive jk available in 08 brundz JK Wrangler Technical Forum 9 07-07-2007 02:14 PM
Right Hand Drive? tomw JK Wrangler Technical Forum 2 07-04-2006 06:03 PM
