Ride quality after LA suspension - JeepForum.com
post #1 of 16 Old 01-30-2008, 05:30 PM Thread Starter
doc_floyd
doc_floyd's Avatar
I just installed a RE LA kit - on but 3.5" of lift -- without changing the earlier springs or shocks. My '03 Rubicon drives like a 10-ton truck and will beat you to death, even hitting small bumps on pavement.
We intend to add RE monotube shocks. But, is there anything inherent in adding a LA suspension that would change a relatively tolerable and smooth highway ride to being extremely rough? Is there anything inherent in the geometry of a LA suspension that requires softer shocks or springs?
'03 Rubicon -
3" lift, 1" BL, RE LA upgrade, armored, winch, recovery gear...
... all equipment normally needed for Houston traffic
doc_floyd is offline
post #2 of 16 Old 01-30-2008, 05:40 PM
themaniam1
themaniam1's Avatar
Sorry but I haven't a clue why it would ride rougher. Maybe you do not have enough lift. I love our LA lifts. They made our ride much better, I would even go so far as to say good or better then the factory. I have been telling everyone that a LA will improve your ride and articulation at the same time, at it did on our two Jeeps.
Also have a '06 Rubi LJ, Auto
themaniam1 is offline
post #3 of 16 Old 01-30-2008, 05:46 PM
BozoWise
BozoWise's Avatar
Due to control arm angles you usually see a much better ride out of a long arm when you approach 4.5-6" of lift. At this lift height the control arm angle is more closer in relation to a stock setup.
I have never seen a LA lift not improve ride, but I also have never seen one under 4.5" of true lift.
My 1 ton TJ build project "Evil Monkey":
BozoWise is offline
post #4 of 16 Old 01-30-2008, 06:14 PM
elkfan2
elkfan2's Avatar
Maybe bumpstops are too long and you're bottoming out on them.
elkfan2 is offline
post #5 of 16 Old 01-30-2008, 07:02 PM
rubiweeler
Mine rides as good as it did stock, what kind of shocks and springs do you have?
Superior axles doesn't honor their warranty. Don't buy from them.
rubiweeler is offline
post #6 of 16 Old 01-30-2008, 07:32 PM
bustedtj
did you get it aligned caster can cause a rough ride
2000 sport 4.0 .... stuff (0lllllll0)
Originally Posted by Contra View Post
but my most hated thing on a jeep is the decal that says "flip me over if you can read this" on the windshield
bustedtj is offline
post #7 of 16 Old 01-30-2008, 07:36 PM
newbs
Jeepaholic
Mine rides much better after the LA upgrade.
newbs is offline
post #8 of 16 Old 01-30-2008, 07:40 PM
chandlerr
chandlerr's Avatar
the smaller lift than normal LA should not make it rougher, in fact, it would probably make it smoother since the angle of the control arms is really what will change the ride (although choice of bushings in the control arms could translate more vibrations as well, but with the RE kit, that's not an issue)
2004 Black Rocky Mountain Edition, Clayton 4 Linked w/ 4" Pro Comp Springs, 37" Iroks (lost to Mexico. RIP Krystal)
2006 Black LJ Rubicon, stock suspension w/ 33's
chandlerr is offline
post #9 of 16 Old 01-30-2008, 07:55 PM
jays-tj
When is it enough?
jays-tj's Avatar
Mine seems to ride as good or better as it did before I lifted it.
5.5" RELA
NorCal Crawlers W6JLO
jays-tj is offline
post #10 of 16 Old 01-30-2008, 08:23 PM
ThUmPeRcOn
So you did not install new springs or shocks but used the OEM ones you had? Or did I read it wrong? "without changing the earlier springs or shocks". Also not sure if it makes allot of difference but I see a 1" bl and no mml? If adding a 3.5 suspention lift with OEM springs and shocks would that not hold back the lift from it's intended purpose?
The original point and click interface was a Smith & Wesson.
ThUmPeRcOn is offline
post #11 of 16 Old 01-30-2008, 09:16 PM Thread Starter
doc_floyd
doc_floyd's Avatar
The springs were 3.5 to start with and probably have sagged to about 3. The shocks were not known to offer the best ride. Now, however, it is astoundingly bad, like a 10-ton truck and must be bottoming out on the stops, i.e. the springs are too short, or the shocks are terrible -- so we will start with new shocks and shock exstention brackets. I will follow-up in about a week when the new shocks arrive. Oh, there is a 1"mml as well.
'03 Rubicon -
post #12 of 16 Old 01-30-2008, 09:35 PM
ThUmPeRcOn
Have not done my lift yet still reading and learning! P.s. I do however enjoy your choice of music. Not all the time but when working on something or traveling 15th, 16th, 17th, and 18th also romantic classics... My grandfather turned me onto Mozart, Bach, Beethoven at a young age. I am listening to Antonio Bertali as we speak Chiacona A Violino solo... Reminds me of my Grandfather and some great times.
post #13 of 16 Old 01-30-2008, 10:18 PM
fromme
fromme's Avatar
1977 CJ7
What kind of bushings are in the control arms? Poly on both ends? One end Johnny Joint? Heim on 1 or both ends? Believe it or not, that can make a huge difference in ride. Most people talk about shocks and springs when discussing ride quality, but I'm telling ya that having CAs with the Currie type JJ (or something similar) can have just as much if not more effect on the ride. I've actually found poly bushings at both ends to provide the worst ride.
"The Wicked Flee When No Man Pursueth, But The Righteous Are Bold As A Lion."
fromme is offline
post #14 of 16 Old 01-30-2008, 10:31 PM
bman9089
bman9089's Avatar
How's that?
"The American Republic will endure, until politicians realize they can bribe the people with their own money." -- Alexis de Tocqueville
“Sometimes I wonder whether the world is being run by smart people who are putting us on or by imbeciles who really mean it” -- Mark Twain
Romans 12:5 | 1 Peter 3:15 | Matthew 9:37-38
bman9089 is offline
post #15 of 16 Old 01-31-2008, 12:38 AM
TrippinBimmer
On Mine the Front was smoother then the rear until I put a full size spare and High Clearance control arm brackets...
TrippinBimmer is offline
Suspension Opinion - Ride Quality... steevireno TJ Wrangler Technical Forum 15 01-28-2008 08:17 AM
Best suspension for quality ride gtedeschi1 YJ Wrangler Technical Forum 7 07-20-2007 02:50 PM
What to do about bad ride quality Jr KLR TJ Wrangler Technical Forum 10 08-19-2005 07:33 AM
Ride quality 04TJFan TJ Wrangler Technical Forum 3 03-04-2005 05:12 PM
BDS quality and ride blacktj TJ Wrangler Technical Forum 2 11-14-2002 01:14 PM
