Riddler diff cover or Warn diff skid plate? - JeepForum.com
post #1 of 17 Old 05-22-2010, 12:23 PM Thread Starter
fduncan
Please help me decide which one for the FRONT dana 44 axle on my 2006 rubicon. I've heard a lot about people having clearance issues with a lot of the aftermarket covers. You guys advice would be much appreciated!
fduncan is offline
post #2 of 17 Old 05-22-2010, 02:40 PM
TJamz
I say Riddler. I believe they have one of the lowest profiles available for a aftermarket diff cover, I have one on my 8.8 w/ plenty of clearance of the gas tank oem skid. There's a thread on here somewhere that offers different cover depths.
Edit: Here it is;
Riddler: 2-7/8"
Solid: 2-7/8"
Rockcrusher: 3-1/4"
Ruff Stuff Specialties: 3-9/16"
TJamz is offline
post #3 of 17 Old 05-22-2010, 02:45 PM
TJamz
TJamz is offline
post #4 of 17 Old 05-22-2010, 03:06 PM
Tinga
YouTube - ROKMEN Riddler Differential Cover Overview
Girls like STROKIN too!
http://www.jeepforum.com/forum/f153/1971-jeepster-commando-1380633/
Tinga is offline
post #5 of 17 Old 05-22-2010, 03:20 PM
rkwfxd
I am going with the Riddler for sure but I have a D30.
rkwfxd is offline
post #6 of 17 Old 05-22-2010, 03:35 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
I love my riddler cover. I just hate the track bar that doesn't clear it.
go with the skid or a Barnett cover if you plan to run less than 4" of lift.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #7 of 17 Old 05-22-2010, 03:40 PM
biffgnar
biffgnar's Avatar
Fixed it for you
Romney in 2020!
biffgnar is offline
post #8 of 17 Old 05-22-2010, 03:44 PM
Hendrix
TJOTY 2013
Hendrix's Avatar
I would go for the Riddler. I love mine. Looks great and is Indestructable.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #9 of 17 Old 05-22-2010, 03:53 PM Thread Starter
fduncan
I'm only running about an inch of lift and don't really intend on going any higher. At least not anytime real soon, so maybe the Warn skid would be the best on the front, then go with the Riddler on the rear.
fduncan is offline
post #10 of 17 Old 05-22-2010, 03:56 PM
Unlimited04
that may be true for 8.8... but for the D30 and D44, Riddler makes the biggest cover on the market. in fact, the stock mount on the frame actually hits the Riddler D44 cover at 1.75" bumpstops - with the track bar completely removed. it also hits all aftermarket track bars with less than 3" of bumpstop.
start reading...
http://www.jeepforum.com/forum/f9/tj...it-fit-738948/
when i was at stock height the D44 Riddler rubbed the gas tank at full compression. not bad...but enough to scratch paint off the cover & the Kilby skid (which has more clearance than the stock skid)
Useful Write-Ups:
Funny:
post #11 of 17 Old 05-22-2010, 04:15 PM Thread Starter
fduncan
What about the SOLID or Rockcrusher covers on the rear? Maybe I should just go with the Warn skids on the front and back? I know I'll have to rinse the mud out of the Warn skids, that's why I was wanting a cover for the rear. The front will be pretty easy to rinse out but the rear has the gas tank in the way. But I don't want any rubbing issues.
fduncan is offline
post #12 of 17 Old 05-22-2010, 05:10 PM
TJamz
Oooooh. My bad. I just assumed that they are all the same depth. Sorry. My bad. Noted.
TJamz is offline
post #13 of 17 Old 05-22-2010, 05:45 PM
marylandjeeper
i have a warn on the front and have beat the **** out of it and its held up great. it has big drain holes so when you get back from wheeling you can hose it out pretty easily. my only advice would be to get rid of the allen head bolts it comes with and use some slightly longer hex head bolts. i ground the bottom allen bolt down on rocks so bad that the hole where the allen key goes was ground in half. the skid is very nice though.
Originally Posted by provelogear
Everything we sell is US Chinese made! I'm Chinese so it is Made in the USA by a China Man! HAHAHAHAH!
Originally Posted by IKate
It's not "made BY chinese" that's the issue, it's "Made in China" that's the problem - now you behave yourself.
marylandjeeper is offline
post #14 of 17 Old 05-22-2010, 05:45 PM
marylandjeeper
oh and its made in the usa as well, which is a plus in my book.
post #15 of 17 Old 05-22-2010, 05:59 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
I've had a Warn differential skid on the front axle for 6 years. Works well for me...
Knuckelhead is offline
Rugged Ridge Diff Skid vs. Riddler diff Cover 1398653 TJ Wrangler Technical Forum 3 01-10-2010 03:50 PM
Just got my Riddler diff cover for the D44. If I am going to.... Pine Knot TJ Wrangler Technical Forum 4 03-01-2009 05:17 PM
How is the Warn Diff Skid Plate? Thunderstrike TJ Wrangler Technical Forum 1 01-30-2006 10:38 PM
Warn D30 skid plate install & diff fluid change Windsor TJ Wrangler Technical Forum 5 05-25-2005 07:20 AM
Warn Diff Skid Plate Install SpitNine TJ Wrangler Technical Forum 1 05-22-2003 09:55 AM
