Revival attempt - JeepForum.com
post #1 of 5 Old 08-10-2008, 06:02 AM Thread Starter
Moses2564
Revival attempt
So, my ARB air compressor has called it quits. For whatever reason, she quit working about a month ago, and I can't quite figure out why. I've checked all of the electrical lines, and the in-line fuse for shorts or burn-outs, and it all seems fine. As far as I'm aware, the compressor is a sealed unit, so I shouldn't have to worry about it being packed with mud, right?
The compressor sits where the A/C pump pulley would sit (directly above the idler pulley).
The only thing is that without the compressor, my ARB locker will not work (no air), and I can't air down my tires on the trail without having a fill-up station near by.
So, does anyone have any ideas as to what might be the problem, or do you think I should just buy a replacement and use the existing lines?
2000 Solar Yellow TJ
2000 Ford F250 Super Duty
2006 Volvo S40
1997 Arctic Cat ZRT 600
Moses2564 is offline
post #2 of 5 Old 08-10-2008, 08:06 AM
Bmel17
how old is it? if its a year or 2 call ARB and ***** about it crapping out. it should have a warranty if its newer. if its old, stuff happens and get yourself a new one.
06 TJ Black GOLDEN EAGLE Edition
96 Buick Creep Wagon
08 HD Nightster
Bmel17 is offline
post #3 of 5 Old 08-10-2008, 01:12 PM
Doctor7474
Compressing gas produces a large amount of heat. If its packed with mud the heat can not escape. If its been packed with mud for a while it's probably burnt up.
Doctor7474 is offline
post #4 of 5 Old 08-10-2008, 01:20 PM
Stu Olson
Stu Olson's Avatar
And you verified that the power relay that controls the compressor is functioning correctly? And the switch that enables the compressor relay is working correctly?
There is more to the ARB compressor than the fuse and the wiring.
Stu Olson
ARB Locked & Loaded
Stu Olson is offline
post #5 of 5 Old 08-11-2008, 01:08 PM Thread Starter
Moses2564
No, I haven't verified the power relay, but the switch is working properly. I just dug out the manual, which gives an exploded view of the air compressor. I'm going to check the power relay, and the intake valves, along with the air filter.
Thanks for your help guys.
2006 Volvo S40
Gettin' things a rollin' - Yj revival Jkanly YJ Wrangler Technical Forum 9 09-16-2008 09:48 PM
Fender Flare Revival! (PICS) C2U5H TJ Wrangler Technical Forum 30 04-13-2007 03:15 PM
attempt #3 stl_07 JK Wrangler Technical Forum 9 11-15-2006 09:34 AM
Rear SOA attempt admar2 YJ Wrangler Technical Forum 25 08-08-2006 11:15 PM
Revival of armor string Djreid TJ Wrangler Technical Forum 4 02-20-2004 02:19 PM
