Reverse light/rear turn signal wiring - JeepForum.com
post #1 of 10 Old 12-17-2007, 09:03 PM Thread Starter
csxfbird
Hey guys, now that I'm on break from school, I've been spending some time fixing the wiring issues the Jeep has. The previous owner was an airman and was stationed in London for a time, so he had to rewire the running lights and signals to conform to the laws over there. They require all vehicles to have yellow or amber turn signals to the rear, so what he did was disconnect the reverse lights, and rewired the reverse lights to be turn signals...the rear running and brake lights work normally, but instead of the red light being the signal, the revere light is. Does anyone have a diagram for the rear lighting on the Jeep? I noticed a purple wire had been cut and spliced into on the driver rear of the Jeep, but it got dark before I could mess with it anymore. Thanks.
csxfbird is offline
post #2 of 10 Old 12-17-2007, 10:22 PM
Stu Olson
Stu Olson's Avatar
The 2nd paragraph contains the wire colors you asked about.
http://www.stu-offroad.com/electrical/led1/led-2.htm
Stu Olson
ARB Locked & Loaded
Stu Olson is offline
post #3 of 10 Old 12-18-2007, 01:44 AM Thread Starter
csxfbird
Awesome, thank you. Now it's a matter of figuring out how to "un-rig" the wiring job the previous owner did.
csxfbird is offline
post #4 of 10 Old 12-18-2007, 05:29 AM
Davejb
In order for the rear amber turn signals to not come on when the brakes were applied, he had to have run a new wire from the turn signal switch to each rear light. Also the former turn rear signal wires were probably moved to the brake light switch, that's how I would have done it anyway. There should be only 3 wires running to the stock lights, for parking, brake/turn signal, and reverse.
2006 Wrangler Unlimited
Vote Quimby
Davejb is offline
post #5 of 10 Old 12-18-2007, 11:19 AM Thread Starter
csxfbird
Now that you mention it, I traced a couple of wires that were ran along the driver side floor of the Jeep, and I noticed they went up into the dash, so that's probably exactly what he did. One was a red wire (which he added) spliced into the purple/black wire (stock wire). So you think it's just a matter of removing the new wires he ran and reconnecting the stock wires?
csxfbird is offline
post #6 of 10 Old 12-18-2007, 01:55 PM
Davejb
Sounds like it. The new turn signal wires he ran to the rear are probably connected to the front turn signal wires at the switch, you'll have to reconnect the factory rear wiring to the proper rear wires on the switch to get both turn and brake lights functioning properly again.
Vote Quimby
Davejb is offline
post #7 of 10 Old 12-18-2007, 03:14 PM
Jonny Jeep
Jonny Jeep's Avatar
The US wiring has the feed from the stop lamp switch feeding through the direction indicator switch. In our RHD models the feed to the stop lamps does not go to the indicator switch, it goes directly to the rear lamps. That should be the extra wires you have, if they've done it the simplest way, and the wires with the red stripe at the rear should have been moved to the indicator bulbs in the reverse lamp position. The white/tan wire running from your stop lamp switch must have been cut before it gets to the direction switch. Find that splice and reinstate the original wire.
The wires at the rear will need to be rearranged so that the extra wire is disconnected and the indicator feed connected back to the stop/turn bulb. The reverse bulb can then be connected back in place. It should be disconnected at the moment unless auxilliary reverse lamps have been fitted.
I got rid of my original UK rear lamp fittings and fitted US ones connected as described in the original post, and with reverse lamps fitted to the rear bumper. Had cops following me before as they couldn't see my orange bulbs and figured I must have illegal red indicators. Only saw the amber bulbs in the reverse light place when I pulled off the road.
Jonny Jeep is offline
post #8 of 10 Old 12-27-2007, 01:25 AM Thread Starter
csxfbird
Well you guys were absolutely right. The previous owner cut both rear turn signal wires and fed them into the rear brake light wire, new wires were ran to the rear, and the reverse light wire was disconnected and spliced at the rear of the Jeep. I got the reverse lights working, but it got cold, so I'll finish it tomorrow, lol. I finished soldering and heat shrinking all the wires in back, now it's just a matter of fixing the wires underneath the column. Wouldn't be too bad if the previous owner hadn't cut them almost unusably short. Sigh...few things annoy me worse than fixing hacked wiring harnesses.
csxfbird is offline
post #9 of 10 Old 05-20-2010, 04:15 PM
bigred13
I am actually trying to get the oposite result. I am trying to get my US Jeep to pass the MOT. I have completed everything but the rear turn signal. I am a little hesitant to start cutting wires until I get a little more info. I can really seem to find the brake wire in order to seperate the turn signal. Does anyone have a diagram?
bigred13 is offline
post #10 of 10 Old 05-21-2010, 11:57 AM
Jonny Jeep
Jonny Jeep's Avatar
Hi bigred.
See your other post in the JK section. I've linked to a diagram for you and found what should be the JK wire colours for you to make it easier.
LED turn signal wiring help detroitmurph TJ Wrangler Technical Forum 1 07-06-2009 04:55 PM
Driver side rear turn signal -- no signal --chris-- YJ Wrangler Technical Forum 5 02-23-2008 07:43 PM
Electrical problem, turn signal/marker light wiring jeeptillidie TJ Wrangler Technical Forum 13 01-30-2008 10:41 AM
Turn Signal Wiring bblhead TJ Wrangler Technical Forum 2 07-25-2007 12:13 PM
Right rear tail light, no stop or turn signal Sbeltinc TJ Wrangler Technical Forum 8 06-20-2007 11:09 AM
