results of the ZJ lift (on the tj) are in
| TJ WW2WW rockers on sale with free gaskets this month. | DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97- | JcrOffroad new Crusader TJ/YJ/CJ Bumpers available!! |
#1 | |
I bought two front coils from a v8 ZJ oday, installed them on the front of my tj, .....
instant 3 inch lift......... took my front springs from my tj, put them in the rears..... instant 3 inch lift...... the tj rides great, (except for needing longer shocks) total cost..... 72.00 including tax now i need shocks to fit, any sugestions? once again i am on a budget but need to replace them soon..... thx Aaron
#2 |
I have a set of BDS shocks that I have used for about 3000 miles. They came with my bds 3 inch kit. I'll sell them to you for half of what they go new plus shipping. I think they run about 120 new. I'll have to check. My new OME shocks are on their way.
2002 Sport: I6, 4.56 gears, SYE, RE 3.5", 305 BFF MTs.5-spd,d30/d44. 2004 Grand: I6, wife's 1998 XJ: My daily driver. I6 "The Second Amendment is not about duck hunting, and I know I'm not going to make very many friends saying this, but it's about our right, all of our right to be able to protect ourselves from all of you guys up there." - Dr. Suzanna Gratia Hupp, appearing before Representative Charles Schumer's committee hearings on the assault weapons ban |
#3 |
You got any pics? Very interested in seeing the finished product.
Jimmy 97 Sport 5sp, 2"BB w/DT3's, AR-767, 32" Mud Rovers 01 Sport 5sp, stock 03 Rubicon |
#4 |
where did you get the front coils from for that price? what years work? i thought the front and rear coils on our tj's where a diferent diameter and spring rate? how much will that affect its rear flex and load capacity...do you know???
2002 TJ Blk, 4.0, 5spd, dual top/doors, Dana 30/44, 6", 35's, 4.88s, locked f/r, air, KC lights, CB, PSC rockers/cage/corners, m8000, flat fenders, custom front bumper, TXT rear 2003 F350 diesel....tow rig [COLOR=blue]NEJEEPZ[/COLOR] [URL=http://community.webshots.com/user/2k2blktj]My Jeep[/URL] |
#5 |
i got the idea from jeepsunlmited.com.....
but i have been told it has been written up in jp and petersons before too... the front tj coil is alot taller and wider, when comparing side by side the springs are about 6 inches taller, but once you get them in, the weight of the jeep brings hem down to about a 3 inch lift..... as far i havent gotten to try to flex them as i need to put new shocks on, (the stock shocks are fully extended just sitting there) but we suspect that the flex will be incredible ![]() cargo capacity i am not too worried about as these are the springs that were holding up the engine before ..... so i think they will be ok.... i got the springs from a junkyard here in town, bj's but the persn who did it on JU got new ones from napa..... the ride is stiffer is suspect because of needing shocks ![]() that tied in with my flat fenders and my jeep looks so mean, i will try to post pics later... ![]() |
#6 |
definetly post pics and a write up of how it rides, likes, dislikes, if it works i mean why wouldn't more poeple do it?
For info on outdoor adventures in South Carolina check out OffroadSC.com |
#7 |
pics should be on tomorrow..... but here is the little write up
you buy the zj springs... remove your front springs install new front zj springs... install new shocks (i havent doen this yet) put tires back on lift up rear end , remove all tires disconnect shocks and sway bars now the hard part, use a coil spring compressor and compress the spring install the front tj spring in the rear of your tj install the other spring, using a spring compressor, it will be very tight install new shocks, and hook sway bar back in reinstall tire get an alignment the easiest part is the zj springs, while they dont look like they are any taller (maybe only a inch or so) they dont compress as far giving the extra lift..... The ride on the jeep is going to be about the same in the front, and perhaps a little springier in the rear.... travel i'm not sure as i need to install new shocks still (i love it mine are fully extended right now .. |
#8 |
Would the shocks from a RE budget boost work with this? I think they are DT's.
Thanks. Chad. |
#9 |
I can't believe it worked. I def want to see pics. and yes the DT shocks from the RE budget boost will work, but those shocks are quite possibly the worst shocks in the world and putting them on a 3" lifted TJ will just make them that much worse.
2000 Sahara that is for sale. |
#10 |
I just bought 4 - DT3000s off of Bob Supplee for 147 shipped
They were for a 2" BB but I'm sure that he has some that will work! Bob Supplee, 405-799-8977
'84 CJ-7 Junkyard TBI 360/T18/D300, 4" 4WDH Lift, D44 front with ARB and HS/D44 Rear w/ Detroit, 4.56s, 36" Iroks, TFI, TJ flares, Homemade rocker guards and bumpers with swing out, Optima Yellow Top, M8000, York OBA, 6pt cage "when you're up to your *** in alligators, it is hard to remember that your original intention is to drain the swamp" Last edited by mxg342; 04-14-2003 at 09:45 AM.. |
#11 |
I stand corrected. I was pretty sure that way of lifting a tj wouldn't work out.
I know the original rear springs have tapered coils on top & bottom, but the fronts only taper at the top. How well did the front springs fit in the rear? What keeps them centered? |
#12 |
at the top they are centered the same way the frotns are, on the bottom the are centered in the pan naturally, same was as stock.... you see the orignal rear are tapered on top and bottom, the fromts are tapered at the top, but not at the bottom, so the bottom mounting plate is very wide allowing it to accomidate a non tapered spring, it fits perfectly, i am uploading pics now....
please notice the rear spring bows slightly out ( i had to compress it pretty good to use original shocks) but when the new ones come in should be fine also the tires are 31x10.50x15's http://www.imagestation.com/album/?id=4290353041 ![]() Last edited by asjeep; 04-14-2003 at 12:38 PM.. |
#13 |
and roughneck, i am corrected all the time on here, lol
#15 |
Will this setup work with the RE budget boost? What year XJ do these springs need to come from?
Thanks. Chad. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
