Reprogramming the computer for larger tires - JeepForum.com
post #1 of 19 Old 06-09-2012, 09:51 AM Thread Starter
BioTex
1979 CJ7
A friend of mine swears that when you change tire size, you need to go to the dealership to have them reprogram the computer to re-educate it for optimal mileage. I'm calling BS, but....
It kind of makes sense, but then again if the speedo is calibrated, isn't that enough? What's the true scoop?
Currently:
79 CJ7 "CJ Express" 4.2L, NV4500, D44 rear
69 800 with SBC, SM465, NP205, 14BT
BioTex is offline
post #2 of 19 Old 06-09-2012, 09:55 AM
Ironhead
looks like you have a rubi, so its an electronic signal.
many aftermarket options,
speedo healer
yellow box
truspeed
and many more.
or you could go to a dealer, i've heard the snap on scanner works as well
your speed is used by the ecu to make calculations, so it is a good idea to do it
Ironhead is online now
post #3 of 19 Old 06-09-2012, 10:40 AM Thread Starter
BioTex
1979 CJ7
speedo healer
yellow box
truspeed
and many more.
We're not talking just reprogramming the speedo here. He swears some of the other sensors are involved. Don't know which ones, but he's saying there is more to reprogram than just the speedo. I haven't done my speedo yet because I'm about to change tire size.
Currently:
BioTex is offline
post #4 of 19 Old 06-09-2012, 10:43 AM
Ironhead
i'm pretty sure your friend is wrong. what other sensors would control speed other than your speed sending unit? the ones i listed plug in in-line and change the output signal, telling your ecu the correct speed
post #5 of 19 Old 06-09-2012, 10:53 AM Thread Starter
BioTex
1979 CJ7
I'm with you on this line of thinking, but since I come from a non computer era, I just don't yet have the experience to know for sure.
It seems to me that the computer only needs to know the correct speed, and rpm to couple with the MAP, O2, TPS, CPS inputs, and the air/fuel will be optimized. I'm sure there are others, but these are the ones I'm familliar with so far.
I'm thinking some dealership gave him a line of crap just to overcharge him for recalibrating his speedo.
Now another question. If the dealer reprograms it, it is not the same as aftermarket options is it? They provide a hardware solution that stays on the Jeep correct. It is not reprogramming so to speak, but rather correcting the signal right?
Currently:
BioTex is offline
post #6 of 19 Old 06-09-2012, 10:56 AM
Ironhead
no, they re-program the ecu, and there are lots of stories about the re-programming not sticking and having to go back multiple times.
the hardware option allows for easy re-calibration if you change tire size or re-gear
post #7 of 19 Old 06-09-2012, 11:13 AM
Best4x4
When I had access to a Jeep programmer (DRB3 I believe) yes you can go into the PCM and change the tire size from 245/75R16 to 33x12.5R15, and you can also change the gear ratio. This is only on a Rubicon, but 03-06 Rubicon's can be programmed at the dealer for larger tires/gears.
05 Electric Lime Green LJ with a 4spd Auto, 2.5inch Suspension Lift, OME Shocks, OME Steering Stabilizer, 32inch BFG M/T's on 17inch Moab's using Spidertrax Spacers, UCF Aluminum TC Skid, Novak Cable Shifter, Brown Dog MML, Rokmen 1/2 BL, Banks CAI, Diehard Platinum Marine Battery, JW Speaker 8700 LED Head Lights, Safari Nets, G.E.A.R Overhead Console/G.E.A.R Tailgate Storage, Rugged Ridge XHD Front Bumper, Warn Gas Tank Skid, Mopar Rock Crawler Rear Bumper, Warn XD9000i Winch with Warn Wireless Remote, and a Uniden 880 CB Radio
Best4x4 is offline
post #8 of 19 Old 06-09-2012, 01:15 PM
Y1ann188
AEV procal will do everything you need, its only 129 bucks and its plug and play after a beep from the horn n and you can reuse it after switching tire size or gears
'03 TJ 4.0L NV3550 D30/D44 4.5" RE LA 4.56s, TW DS/AA SYE 35" BFG KM2's Bilstien 5150s JCR Offroad Stubby Winch Front Bumper JCR Offroad Rear Bumper BTF Rock Sliders Warn XD9000i KC Lights Kilby Skids
XD9000i FOR SALE === $950 OBO
Y1ann188 is offline
post #9 of 19 Old 06-09-2012, 01:45 PM
wolfcreek
I called my local dealer about this and they flat out refused, saying they would only re-program it to another factory tire size
wolfcreek is offline
post #10 of 19 Old 06-09-2012, 01:51 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Your friend is wrong on everything but it needing to be reprogrammed to recalibrate the speedometer. The dealer can only reprogram your Rubicon for larger tires, nothing else. None of the other sensors need anything done or reprogrammed, the computer has an adaptive learning ability so it relearns everything it needs to on its own. But better than paying the dealer to reprogram the computer to recalibrate the speedometer, just install an electronic speedometer calibrator. That way you can recalibrate it yourself as you change tire sizes. Like this one... http://www.dakotadigital.com/index.cfm/page/ptype=product/product_id=126/category_id=287/home_id=59/mode=prod/prd126.htm
Gone on vacation until August 25.
Jerry Bransford is offline
post #11 of 19 Old 06-09-2012, 02:06 PM
TheBoogieman
The Devil's Advocate
TheBoogieman's Avatar
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
TheBoogieman is offline
post #12 of 19 Old 06-09-2012, 02:15 PM Thread Starter
BioTex
1979 CJ7
Thanks for the tip, I'll check into it. I will end up with a mounted set of 33's, and a set of 35's, so nice to be able to recalibrate on the fly.
I kind of felt like he was wrong, but thought I better check on it anyways. So much new stuff to learn, but it is all good.
Currently:
BioTex is offline
post #13 of 19 Old 06-09-2012, 03:31 PM
Best4x4
TheBoogieman when I had the DRB3 in my hands and I changed the tire size on my Rubicon from 245/75R16 to 33x12.50R15. One of the tabs on the list was gear ratio. It of coarse had mine set at 4.10, but it had the options for 3.73 and 4.56. I was the Co Organizer of HJP and we had a DRB3 in our club. Not sure where that scantool is now, but I had it for over 3 weeks and I went through all the options. Most were blocked out due to it not being connected to the main PC, but Tire Size/Gear Ratio were two of the options I remember seeing. I was also able to see the boo boo the local Jeep dealership did when they replaced my PCM after getting countless P0700 faults. The idiots never put the correct mileage on the new PCM. While I had the DRB3 I corrected that so that both the gauge cluster/PCM had the same exact mileage readings.
Best4x4 is offline
post #14 of 19 Old 06-09-2012, 05:40 PM
1999TJRED85000
I didn;t mention to you, that SpeedoHealer has two setting so you can press one button and switch between tire sizes. Convenient for your application.
http://www.healtech-electronics.com/
F U
1999TJRED85000 is offline
post #15 of 19 Old 06-09-2012, 06:28 PM
SlackJaw
baby jeep
SlackJaw's Avatar
Hey, I'm only running 31s. Are any of these solutions worth any amount of benefit that I might see?
Thanks in advance.
Sent from my Android using JeepForum
Can you afford the car? Have I provided you all the information you need on the car? Do you like the car? Then buy the car.
SlackJaw is offline
reflash computer for larger tires? secretspy711 JK Wrangler Technical Forum 18 10-25-2011 06:23 PM
Larger Tires vs 4.0L H.O. JohnFM3 YJ Wrangler Technical Forum 27 11-19-2009 01:02 PM
Why larger tires? Zeee JK Wrangler Technical Forum 8 10-27-2007 12:22 PM
Jeep computer reprogramming (ECU, TCM, PCM) Snydermann TJ Wrangler Technical Forum 3 03-26-2007 08:24 PM
ABS and larger tires 04JeepTJ TJ Wrangler Technical Forum 13 01-23-2004 08:06 AM
