Replacing stock O/D off and Rear Wiper Switches - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Replacing stock O/D off and Rear Wiper Switches
FLASH SALE! Open thread to reveil the Newest Sale @ ROCKRIFS: Wrangler RGB Multicolor Fog Light LEDs: Awesome EffectIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 02-16-2015, 05:39 PM   #1
Madden_07
Hey everyone,
So I've been cleaning up some of my previous electrical work and I was wondering if it was possible to replace the stock O/D off and rear wiper switches with aftermarket ones like you'd find at OTRATTW. Thanks!
"Roads? Where we're going we don't need roads!"
-Dr. Emmett Brown
Madden_07 is offline   Reply With Quote Quick reply to this message
Unread 02-17-2015, 02:51 AM   #2
jon1371usmc
What is OTRATTW?
jon1371usmc is offline   Reply With Quote Quick reply to this message
Unread 02-17-2015, 03:03 AM   #3
Jonny Jeep
Jonny Jeep's Avatar
Originally Posted by jon1371usmc View Post
What is OTRATTW?
OTRATTW.net
I have no idea how well those switches fit, but I'm sure I've seen pics of that type of switch in the stock location.
Online factory service manuals and parts lists - http://www.jeep4x4center.com/knowledge-base/index.htm
If it doesn't work properly, look for the service manual link at the bottom of the page.
Jonny Jeep is offline   Reply With Quote Quick reply to this message
Unread 02-17-2015, 03:08 AM   #4
jon1371usmc
Originally Posted by Jonny Jeep View Post
OTRATTW.net
Never thought to Google it, just figured it was some weird acronym.
Unread 02-17-2015, 09:08 AM   #5
Madden_07
OTRATTW.net
I already have two of those switches in the factory location, I just need to know if I can use them to wire up the O/D off and rear wiper
-Dr. Emmett Brown
Unread 02-17-2015, 10:22 AM   #6
biffgnar
biffgnar's Avatar
I can tell you that the Contura II & IIIs don't fit the OEM hole precisely. They are a little big. A little work with a router/grinding stone on a dremel though and you can make them fit. No idea about the Vs or the Xs.
Thank you Dave Cole, Dynomax, Falken and all the Spec Class sponsors!!
biffgnar is offline   Reply With Quote Quick reply to this message
Unread 02-17-2015, 11:00 AM   #7
1 Long CJ
Haven't looked at the drawing but it would depend on whether the switch sends a constant signal (probably a ground) or a momentary signal to the PCM. If the Overdrive push button is Push on/Push off then a regular SPST switch would work. Rear defrost would probably be the same. Rear wiper would probably need a Off/On/On switch.
Life is short. Play hard.
1979 CJ5, 1982 CJ8, 2004 WJ, 2006 LJ Rubicon
1 Long CJ is offline   Reply With Quote Quick reply to this message
