Replacing steering gear box - JeepForum.com
post #1 of 22 Old 07-07-2010, 10:08 AM Thread Starter
BChamberlin
BChamberlin's Avatar
Does anyone know of a good write up or video of how to replace the steering gear box on a 99 Wrangler? I have the Haynes manual which is pretty straight forward. I'm leaking fluid pretty badly but I'm not entirely sure where it's coming from. I have a new box and was going to just put that on but now I'm wondering if it's not something more simple. Where do these things start to leak? I was going to power wash the area to see if I can get a better idea where it's leaking from. Could it be the pump instead of the box? I get a puddle and have to refill at least once every 2 weeks.
2008 Wrangler X
BChamberlin is offline
post #2 of 22 Old 07-07-2010, 10:17 AM
Jon-joN
deffinatly check that its the box first not the pump, the box normally starts leaking around the seal where the pitman arm is. and it is very simple to change, the 3 bolts on the side and the nuts where the steering shaft goes in and she'll pull right off. make sure your steering wheels locked so it doesnt overspin and break the clockspring.
Jon-joN is offline
post #3 of 22 Old 07-07-2010, 10:53 AM Thread Starter
BChamberlin
It ain't that damn simple. LOL! I tried replacing the box once before and couldn't even get that nut off. I was going to try with a cheater bar but haven't gotten around to it. I tried with a 100 pound compressor and that didn't work.
2008 Wrangler X
post #4 of 22 Old 07-07-2010, 10:59 AM
Hinch45
I just replaced my steering box. NEVER AGAIN. yes it saved money doing it myself. But getting the pitman arm off, then back on is the biggest PITA. We tried using a pitman arm puller and it helped a little but we ended up using a 24in Pipe wrench with both me and my father bracing our feet against the wheels and pulling with everything we got. Then you have to deal with the fluid lines and the steering column etc. This is also not something that you can say "well thats good enough" It's your steering. That was not worth it. If I need it again I am bringing it to a shop.
Hinch45 is offline
post #5 of 22 Old 07-07-2010, 11:02 AM Thread Starter
BChamberlin
Eck, was that a good idea pushing against the wheel like that? I thought you had to be careful about turning your wheels.
2008 Wrangler X
post #6 of 22 Old 07-07-2010, 11:18 AM
DanZ51
I submitted an article for the Tech forum http://www.jeepforum.com/forum/f140/:// but I see it still hasn't been posted yet (moderator must be busy wheelin' )
Anyway, removing the box is easy enough. Mine was a later Mercedes (ZF) box as yours is a Saginaw but they should come out the same way.
-To eliminate alignment headaches: lock your steering wheel (remove the key), and try not to move your front wheels. I recommend using ramps, as opposed to using jack stands, so the steering shaft goes back on exactly the same way it came off.
-Pull the cotter pin and unbolt the drag link Tie Rod End (TRE). Use a "TRE puller" or "pickle fork" and pop the TRE out.
-If you have to remove the Pitman Arm from your steering box (to put it on your new box) now's the time get it off. Beg, Borrow, Steal a pitman arm puller! These can be tough to pull off. Even with the puller, it may take several applications of heat (torch), penetrant, BFH, and sweat. If your new box has a pitman arm you just bypassed the biggest PITA of the process.
-loosen the steering shaft coupler (collar) on the steering shaft.
-Unbolt the bottom two (rearmost) steering box mount bolts from the frame rail. Loosen the upper (forward) bolt, so now the box is loose. I find it easiest to pivot the box down a little to access the power steering line fittings and slide the steering shaft coupler off.
-Have a drain pan ready, pull your power steering hoses off. Remove the steering shaft coupler bolt, and slide the coupler off the box input shaft (mine needed coaxing with a pickle fork).
-Remove your remaining box mount bolt from the frame rail, and be ready to catch it.
"I will always be an American Soldier"
DanZ51 is offline
post #7 of 22 Old 07-07-2010, 11:19 AM
skinton
The 3 bolts that hold the box on were the easy part. I replace the pitman arm too and didn't bother taking it off the steering box when I returned the old steering box to the store. I bend two pitman arm pullers trying to get it off and gave up. Also, the hydraulic line that go between the pump and the gearbox were seized. I replaced both of those as well.
It might be worth your while to plan on replacing all of the above parts and save some headaches.
1998 TJ Sport, 4.0L - 5 spd -Suffering from frame rot
2006 Grand Cherokee Overland (5.7L HEMI)
HEMI Club Member #53
2003 M-B C240 4matic
skinton is offline
post #8 of 22 Old 07-07-2010, 01:14 PM
Rjnol
Jeep TJ Web Site of Stu Olson - N7QJP
thats what i used to replace my stock steering gear box, it took me 1.5 hrs to do and im just a shade tree mechanic.
I had to put some heat on the pitman arm to get it loose but other then that it wasnt difficult at all. I would suggest having someone help you as it makes getting the box back on easier.
Rjnol is offline
post #9 of 22 Old 07-07-2010, 01:19 PM
Hinch45
Theres an idea. If having a shop do all the work is to expensive. Then see what it would cost to buy a new pitman arm and have a shop put it on the steering box before you install it. Then install the steering box yourself. Might save a few bucks.
Hinch45 is offline
post #10 of 22 Old 07-07-2010, 01:30 PM Thread Starter
BChamberlin
I can't even get to the arm.... I'm still stuck trying to get the damn first nut off. I haven't tried lately though. I'm still trying to find out where I'm leaking.
2008 Wrangler X
post #11 of 22 Old 07-07-2010, 01:50 PM
Jon-joN
ive done 3 this past year for freinds and myself and the only problem is the pitman arm and if you can get your hands on a press you can do the swap in under an hour. btw on my personal swap i used an xj box and used the pitman arm that was on there. yes, it is longer and there is no need for that without alot of lift, but i havent had any problems at all even under full flex.
Jon-joN is offline
post #12 of 22 Old 07-07-2010, 01:51 PM Thread Starter
BChamberlin
I have the pulled but like I said, havne't gotten to that part yet. I need to get that god awful nut off first.
2008 Wrangler X
post #13 of 22 Old 07-07-2010, 05:51 PM
Hinch45
I pb blastered it for 2 weeks, went through 2 cans and it was still a tough nut. Like I said HUGE Pipe wrench.
Hinch45 is offline
post #14 of 22 Old 07-07-2010, 06:02 PM
wushaw
Rockin jeep
wushaw's Avatar
Having the correct tools for the job is priceless.
wushaw is offline
post #15 of 22 Old 07-07-2010, 06:10 PM
durango-bob
2006 WK
I've been able to get the nut off easily with the correct socket, a breaker bar, and a 4' pipe over the breaker bar. Use these tools with the Jeep sitting with its wheels on the ground and have at it. I've done several and this always works. I've always had more trouble getting the pitman arm off even with the proper puller. I even broke a puller once. Tightening the puller with an impact and then wacking the arm with a hammer seems to be the fastest method.
durango-bob is offline
replacement , steering , box , TJ
Replacing jeep steering box with a Durango Steering box? Beefstew TJ Wrangler Technical Forum 171 05-22-2012 09:17 AM
Slight hitch in steering after power steering gear replacement. chip80 TJ Wrangler Technical Forum 2 10-04-2009 01:49 PM
replacing steering gear box in 97 Tj TJchuckTN TJ Wrangler Technical Forum 2 03-31-2009 12:56 PM
Replacing seals in power steering gear box ciscore TJ Wrangler Technical Forum 5 02-09-2009 07:36 PM
Replacing NSG360 6th gear - possible? LaJeepermln TJ Wrangler Technical Forum 2 06-30-2008 01:49 PM
