replacing pcm - JeepForum.com
post #1 of 2 Old 08-09-2006, 11:55 PM Thread Starter
greensahara
replacing pcm
i belive i need a new pcm not 100% sure my jeep will idle usually fine sometimes it will idle up and down. my gauges will some times jump around . i pulled up engine codes 11 and 12 before but today i tried to drive down the street and it died then wouldn't start i discoed my battery - cable retightened then positive and retightened and then was able to start it and limp home i then pulled codes 11 12 23 24 22 42 which sounds like low voltage to my sensors . and pcm power was lost. i guess it could be a short somewhere. i have 2 batteries (custom bracket) and clean connections. any body ever swap pcm i have a friend with a 97 also same setup as mine 4.0 5spd should i swap them any special thing i need to do when swapping pcms?
97 tj sahara 4'' rough country 37'' mtr's
greensahara is offline
post #2 of 2 Old 08-13-2006, 09:59 PM Thread Starter
greensahara
i found a wire that was shorting out but now it wont star
replacing amp 08saharajk JK Wrangler Technical Forum 3 11-16-2008 11:28 PM
Replacing 4 cyc in '97' TJ ftdranger TJ Wrangler Technical Forum 3 07-14-2007 10:55 AM
Replacing the ol' 4.2 98XJFire YJ Wrangler Technical Forum 4 12-15-2003 06:41 PM
replacing sub matt0360 TJ Wrangler Technical Forum 1 05-05-2003 10:54 PM
